How do I replace the rear axle seal on my 95 roadmaster?
I heard metal on metal and found gear lube on my Left rear wheel. I checked the differential and couldn't feel any gear lube. I have added almost two bottles, the nosie went away, but the gear lube is leaking out, what will I need to correct this, how long should I plan to spend doing it? Thanks for your help
its not that big of a job block your front wheels raise the rear end and support with two jack stands remove your tires drain your rear differential and remove the differential cover remove the 10mm bolt that holds the stud in place when you remove the stud the side gears will fall out giving you room to push the axles forward so you can remove the retainers once the retainer is removed you can remove the axle just watch the spider gear doesn't fall out of the differential do the same for the other axle once the axles are removed use a seal puller to remove the old seals and a seal installer tool to press the new ones in place both tools are available at any local auto parts jobber. After installing the new seals put some white lithium grease in the seal and install the axles line the axle with your spider gear and push all the way forward then install your retainer and pull the axle back seating the retainer do the same with the other axle after that is done install one side gear push you stud in place and line it up with the other side gear be very careful if there are shims on any of the gears keep them with that gear and make sure they go back in the place they came from try to mark them with a paint marker before removing. After installing the stud with the gears install your bolt I would use lock tight blue on the bolt and clean the rear cover put your permatex blue on the cover, bolt it up and fill the rear differential with quality 85w90 gear oil make sure if your vehicle calls for a friction modifier add that to the mix if you don't you will get allot of chatter possibly damage to the clutch pack and don't believe lube adds when they say modifier not needed if you use there lube That is a Royal mistake I replaced all the fluids with the brand boasting that's all you need and in one weeks time my rear clutch pack was chattering like a kid out in the cold I then added the friction modifier and problem solved it went away, Your done good luck and God Bless
Raise the vehicle and properly support it. Remove the wheel and drum. Remove the rear diff cover, have a drain pan underneath to catch the gear oil. Place the trans in nuetral, chalk the front wheels to keep vehicle from moving if you forget to put it back into park befor you lower the vehicle. Rotat the differential until you see the bolt that holds the diff pin in place. Remove the bolt, 5/16 or 8 mm I believe. You can then remove the diff pin, do not rotate the diff with the diff pin removed! Push the axle in, you can then remove the C-clip that holds the axle to the side gear, it will usuall drop or just fall out. Pull the axle out of the rear diff and replace the seal.
Put everything back together. Use black or grey RTV to reseal the diff cover making sure o clean up both surfaces as best you can. Put trans in park. Lower the vehicle. Remove the fill plug from the side of the differential and fill with gear lube until lube comes out the hole. Reinstall the plug and your good to go.
Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
conventional axle or limited slip? Get axle code off door sticker.
SECTION 205-02: Rear Drive Axle/Differential - Ford 8.8-Inch Ring Gear
1998 Explorer/Mountaineer Workshop Manual
IN-VEHICLE REPAIR
Rear Wheel Bearing and Axle Shaft Oil Seal -4.0L SOHC and 4.0L EI, Conventional
Special Tool(s)
Axle Seal Replacer T83T-1175-A
Axle Wheel Bearing Puller T83T-1225-A
Axle Wheel Bearing Replacer T83T-1225-B
Driver Handle T80T-4000-W
Impact Slide Hammer T50T-100-A Removal
Remove the axle shaft; refer to Axle Shaft in this section.
Axle Shaft
Removal
CAUTION: Do not use heat to loosen a seized lug nut. Heat can damage the wheel (1007) and the rear wheel bearings (1225). Loosen the lug nuts (1012).
Remove the center cap.
With the weight of the vehicle on the wheels, loosen the lug nuts.
Raise and support the vehicle.
Remove the wheel and tire assembly.
Remove the lug nuts.
Remove the axle housing cover (4033).
Loosen the axle housing cover bolts (4346) and drain the rear axle (4001).
Remove the axle housing cover bolts.
Remove the axle housing cover.
Remove the rear disc brake rotors (2C026); refer to Section 206-04 .
CAUTION: Once the differential pinion shaft (4211) has been removed, turning the differential case (4204) or an axle shaft (4234) will cause the differential pinion gears (4215) to fall out of the assembly. This could result in chipped or damaged components. Remove the differential pinion shaft.
Remove the differential pinion shaft lock bolt.
CAUTION: Do not damage the rubber O-rings in the U-washer grooves. Remove the U-washers (4N237).
Push the axle shafts inboard.
Remove the U-washers.
Reinstall the differential pinion shaft.
Install the differential pinion shaft.
Install the differential pinion shaft lock bolt finger-tight.
CAUTION: Do not damage the inner wheel bearing oil seal (1177). Remove the two axle shafts.
Installation
Lubricate the lip of the inner wheel bearing oil seal.
Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
CAUTION: Once the differential pinion shaft has been removed, turning the differential case or an axle shaft will cause the differential pinion gears to fall out of the assembly. This could result in chipped or damaged components. Remove the differential pinion shaft.
CAUTION: Do not damage the inner wheel bearing oil seal. Install the two axle shafts.
CAUTION: Do not damage the rubber O-rings in the U-washer grooves. Install the U-washers.
Position the two U-washers on the button end of the axle shafts.
Pull the axle shafts outward.
Align the hole in the differential pinion shaft with the differential pinion shaft lock bolt hole.
Install the differential pinion shaft lock bolt.
Install the rear disc brake rotors; refer to Section 206-04 .
Install the axle housing cover and fill the rear axle housing (4010) with 2.4 liters (5.5 pints) of specified lubricant; refer to Axle Housing Cover in this section.
WARNING: Always remove any corrosion, dirt or foreign material that may be present on the mounting surfaces of the wheel or the surface of the wheel hub or rear disc brake rotor that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the lug nut to loosen and the wheel to come off while the vehicle is in motion, causing loss of control. Clean the wheel hub and mounting surfaces.
Install the tire and wheel assembly.
Position the tire and wheel assembly.
Install the lug nuts and lower the vehicle.
Tighten the lug nuts.
Install the center cap.
CAUTION: Never remove the axle shaft oil seal by itself. Always remove the rear wheel bearing and the axle shaft oil seal at the same time. NOTE: If the axle shaft oil seal is leaking, the axle housing vent may be plugged with debris. Use Impact Slide Hammer and Axle Wheel Bearing Puller to remove the rear wheel bearing and the axle shaft oil seal.
Installation
Lubricate the new rear wheel bearing.
Use Thermally Stable Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
Use Axle Wheel Bearing Replacer with Driver Handle to install the rear wheel bearing.
Lubricate the lip of the new axle shaft oil seal.
Use Axle Seal Replacer with Driver Handle to install the axle shaft oil seal.
Install the axle shaft; refer to Axle Shaft in this section.
Working through cover opening, remove differential pinion shaft lock pin and remove differential pinion shaft and differential pinion gears (4215).
NOTE: THIS IS FREE INFORMATION!!!!
Remove rear brake anti-lock sensor . Push axle shaft inward until u-washers at button end of the axle shaft are clear of side gear recess.
CAUTION: Do not damage inner wheel bearing oil seals when removing axle shafts from rear axle housing. In addition, axle shafts should be completely removed from rear axle housing.
Remove u-washers and pull axle shafts out of the rear axle housing.
If what you see leaking is very oily and does not evaporate, likely it is an axle seal. If there are no leaks in the brake system, that's the only thing back there that can leak. If the axle bearing is going away, it can damage the seal so make sure you look for small shiny metal flakes behind the seal when you replace it or you will be doing the job again very soon. Can't remember...that IS rear wheel drive right?
Not that difficult, raiseand support the rear of the truck and remove the wheels. Might as well replace both sides so you know you have new seals, remove the differential cover and drain the fluid. Once differential is opened and cleaned , remove the axle "C" clip that hold the axle in place and slide the axle out. Once the axle is out remove the wheel seal and clean around the area. This would be a good time to replace the wheel bearing too since you have access to them and there not that expensive. Install the new bearing and seal, note make sure you oiled the bearing and seal before installing it back and take care when installing the axle back in and "C: clip. Use RTV silicon gasket maker to seal the differential cover and wheels back on and lower. If your lazy like i am, you can drain the differential fluid and replace it with a 50/50 mix with gear oil and Lucas engine oil additives. That may stop the leak and get you a few more miles. You gear oil is (ford 75W-140) (Dana 80W-90)and the capacity is 2.6 liters and 3.5 liters if you have the 10.25 Ring gear. Good luck and hope this helps.
Not that difficult, raiseand support the rear of the truck and remove the wheels. Might as well replace both sides so you know you have new seals, remove the differential cover and drain the fluid. Once differential is opened and cleaned , remove the axle "C" clip that hold the axle in place and slide the axle out. Once the axle is out remove the wheel seal and clean around the area. This would be a good time to replace the wheel bearing too since you have access to them and there not that expensive. Install the new bearing and seal, note make sure you oiled the bearing and seal before installing it back and take care when installing the axle back in and "C: clip. Use RTV silicon gasket maker to seal the differential cover and wheels back on and lower. If your lazy like i am, you can drain the differential fluid and replace it with a 50/50 mix with gear oil and Lucas engine oil additives. That may stop the leak and get you a few more miles. You gear oil is 75W-90 and the capacity is 2.6 liters and 3.6 liters if you have the 11.50 Ring gear. Good luck and hope this helps.
Section 05-02A: Axle, Integral Carrier — 8.8-Inch Ring Gear
1994 Town Car, Crown Victoria/Grand Marquis. Workshop Manual
REMOVAL AND INSTALLATION
Axle Shaft
NOTE: Whenever replacing the rear axle lubricant, use Rear Axle Lubricant XY-90-QL (ESP-M2C154-A) or equivalent. Removal CAUTION: The rear brake anti-lock sensor must be removed before the axle shafts are removed. The rear brake anti-lock sensor is bolted on the rear disc brake caliper anchor plate.
Raise vehicle to desired working height. Refer to Section 00-02 . Remove rear wheel (1007) and tire assembly. Remove rear disc brake calipers (2552) and rear disc brake rotors (2C026) .
Clean all dirt from area of axle housing cover with a wire brush and/or cloth.
Drain rear axle lubricant by removing the axle housing cover .
Push flanged end of the axle shafts toward the center of the vehicle and remove the rear axle shaft retaining u-washer from the button end of the axle shaft .
Remove axle shaft from the rear axle housing , being careful not to damage the inner wheel bearing oil seal (1177) and rear brake anti-lock sensor ring.
Installation NOTE: Check for presence of rear axle shaft o-ring (4A332) on the spline end of the shaft and install if not present. CAUTION: Care must be taken not to let axle shaft splines damage oil seal or bearing assembly.
Carefully slide axle shaft into rear axle housing without damaging rear wheel bearing (1225) or rear brake anti-lock sensor indicator (2C189) . Start splines into side gear and push firmly until the button end of axle shaft can be seen in the differential case .
Install the rear axle shaft retaining u-washer on the button end of the axle shaft splines, then pull the shaft outboard until the shaft splines engage and the rear axle shaft retaining u-washer seats in the counterbore of the differential side gear .
Position the differential pinion shaft through the differential case and differential pinion gears , aligning the hole in the differential pinion shaft with the lock bolt hole. Apply Rear Axle Lubricant to differential pinion shaft lock pin . Install differential pinion shaft lock pin and tighten to 20-41 Nm (15-30 lb-ft).
CAUTION: Differential pinion shaft lock pin must be tightened to specification using Stud and Bearing Mount E0AZ-19554-BA (WSK-M2G349-A1) or equivalent.
NOTE: Axle housing cover must be installed within 15 minutes of application of the silicone rubber or new silicone rubber must be applied. CAUTION: Make sure machined surfaces on both axle housing cover and rear axle housing are clean before installing the new silicone sealant. Inside of axle must be covered when cleaning the machined surface to prevent axle contamination. Tighten the cover bolts in a crosswise pattern to ensure uniform draw on axle housing cover .
Apply Silicone Rubber D6AZ-19562-AA or BA (ESB-M4G92-A or ESE-M4G195-A) or equivalent. Install axle housing cover and tighten retaining bolts to 28-38 Nm (38-52 lb-ft).
Add Motorcraft Rear Axle Lubricant XY-90-QL or KL (ESP-M2C154-A) or equivalent until it is 6-14mm (1/4-9/16 inch) below bottom of fill hole. Add 118.3 mL (4 oz) of Ford Additive Friction Modifier C8AZ-19B546-A (EST-M2C118-A) or equivalent to Traction-Lok axles. Install fill plug and tighten to 20-41 Nm (15-30 lb-ft).
Insert Rear Bearing Remover T85L-1225-AH in bore and position it behind bearing so tangs on tool engage bearing outer race. Remove rear wheel bearing and inner wheel bearing oil seal as a unit, using Impact Slide Hammer T50T-100-A.
Rear Disc Brake Caliper Anchor Plate
Lubricate the rear wheel bearing with Rear Axle Lubricant.
Install rear wheel bearing into the housing bore using Axle Tube Bearing Replacer T78P-1225-A.
CAUTION: Installation of rear wheel bearing or inner wheel bearing oil seal assembly without proper tool may result in an early bearing or seal failure. If inner wheel bearing oil seal becomes cocked in bore during installation, remove it and install a new one.
Install the inner wheel bearing oil seal using Axle Tube Seal Replacer T78P-1177-A. Use Premium Long-Life Grease XG-1-C or K (ESA-M1C75-B) or equivalent between the lips of the inner wheel bearing oil seal .
Wheel, brakes etc that are in way of pulling axle out have to come off. Drain rear end fluid, remove rear housing cover, remove bolt that holds pin in differential, remove differential pin, push in slightly on axle to remove "U" clip that holds shaft in, then slide shaft out. replace seal. Reverse procedure for re-install & fill with gear lube. If any questions, get back to us.
Raise and support the vehicle. For additional information, refer to Section 100-02 .
Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
Remove the differential housing cover (4033).
Loosen the bolts and drain the lubricant from the rear axle housing (4010).
Remove the bolts.
Remove the differential housing cover.
Remove the rear brake disc (2C026). For additional information, refer to Section 206-04 .
CAUTION: Turning the differential case (4204) or an axle shaft (4234) with the differential pinion shaft (4211) removed will cause the differential pinion gears (4215) to fall out of the assembly and damage the components. Remove the differential pinion shaft.
CAUTION: Do not damage the rubber O-ring in the U-washer groove.
Remove the U-washer (4N237).
Push the axle shaft inboard.
Remove the U-washer.
CAUTION: Do not damage the wheel bearing oil seal (1177). Remove the axle shaft.
----------------------------------------------------------------------------------------------------------------- Seal Removal
Remove the axle shaft (4334). For additional information, refer to Axle Shaft in this section.
CAUTION: Never remove the wheel bearing oil seal (1177) by itself. Always remove the rear wheel bearing (1225) and the inner wheel bearing oil seal at the same time. NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged with foreign material. Using the special tools, remove the rear wheel bearing and wheel bearing oil seal together.
Installation
For 4.0L SOHC and 4.0L EI with limited slip rear axles and 5.0L vehicles, use SAE 75W-140 High Performance Rear Axle Lubricant F1TZ-19580-B or equivalent meeting Ford specification WSL-M2C192-A.
For 4.0L SOHC and 4.0L EI with conventional rear axles, use SAE 80W-90 Premium Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
Using the special tools, install the rear wheel bearing.
Lubricate the lip of the new wheel bearing oil seal.
Using the special tools, install the wheel bearing oil seal.
Install the axle shaft. For additional information, refer to Axle Shaft in this section.
is this a posi-traction rear?
