LG fridge 2-3 yrs old top fridge bottom pull out freezer.
Fan motor starts running loud and soon enough ER shows up on the display and the unit shuts down. fixed so far by blowing a hair dryer on the back wall of the freezer which gets rid of frost and poof works fine for a couple of weeks then its a do over.
could it be related to my ice maker leaking a bit when it fills - i imagine a small puddle of water on the frz'r interior floor contributes to the frost build up but not sure if related or part of the problem.
Tech came out months ago - said I needed a new condenser- $1000 or something - he also said a new cond'sr was not guaranteed to fix the issue - i sent him packing 2 seconds later -
i was also told to cool the condenser using wet bath towels & a fan, did it, but results are the same as the blow dryer "solution" works for awhile (weeks) then ER comes back & it shuts off. i have no idea how hot cond'sr should be - i can lay my hand on it w/out melting my hand but it's temp is uncomfortable afer a bit.
Its not a power issue, surge, brownout, or fluctuation - i changed outlets and put a batt back up unit in, didnt matter
ER showed up again.
SO ............any ideas?
condensers really are hot or warm.the freezing/icing is caused of blocked air passages or blocked air circulation.resetting the defrost timer sometimes do the trick.have you check your defrost timer?also, the bi-metal disk inside the evaporator or freezer is malfunctioning.this bi-metal controls the fan blower.if its open the fan is not functioning or vice-versa.have a tech to check this two parts.if not then clogging/holes in the tubes or worst motor problem. but first try the defrost timer by rotating the its knob.
Was this helpful?
Yes
No
Popular Solutions for LG LRBN20510WW Bottom Freezer
Problems with LG LRBN20510WW Bottom Freezer Refrigerator. Left freezer door cracked open for 4 days,...
(More)
Problems with LG LRBN20510WW Bottom Freezer Refrigerator. Left freezer door cracked open for 4 days, came back and light was dead. Followed instructions to change bulb and it still does not work. Any suggestions?
every12 hours or so refrig shuts down and temp controls lock in at 567 unplug and plug back in and...
(More)
EVERY12 HOURS OR SO REFRIG SHUTS DOWN AND TEMP CONTROLS LOCK IN AT 567 UNPLUG AND PLUG BACK IN AND WORKS FINE
My bottom freezer LG rdn 22734 has stopped cooling. I would like to try to reset the defrost timer...
(More)
My bottom freezer LG rdn 22734 has stopped cooling. I would like to try to reset the defrost timer before calling the repair service, but I cannot find it.
freezer doesn't get cold enough to freeze , and now the refrigerator is doing the same. The...
(More)
freezer doesn't get cold enough to freeze , and now the refrigerator is doing the same. The refrigerator is under 2 years old.
