STARTER PROBLEMS
It
can be faulty starter or there is loose connection from battery to starter. The
starter assembly gets power from battery. Check voltages at starter wires and
see if you are getting 12 volts or not. If not then its no power issue due to
low battery volt or no connection between battery to starter.
To
solve these problem, I suggest you to refer these direct help links:-----
Click
the link below: ------
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-starter-in-car.html
These
will help.
Thanks.
CAR STARTER REMOVAL? TESTING
One Wire From Starter Motor Goes To Solenoid And Other Goes
To BATTERY. Starter GETS 12 VOLT SUPPLY FROM BATTERY AND WITH THESE VOLTAGE
IT TURNS THE MOTOR AND THIS TRIGGERS THE STARTER SOLENOID AND YOUR VEHICLE
RUNS.============
For
your help there are few relatively help links showing how to remove and install
starter with proper instructions:-----
These
help links will help.
Click
the link below:-----
http://repairhelpcenter.blogspot.in/2012/06/2006-gm-montana-how-to-replace-starter.html
http://howtobyme.blogspot.in/2012/06/saturn-sl2-how-to-replace-starter-motor.html
Saturn
SL2 Starter Wiring Diagram?
http://schematicsdiagram.blogspot.in/2012/06/saturn-sl2-starter-wiring-diagram.html
• Oldsmobile
starter solenoid replacement procedure?...
• How
to replace Oldsmobile starter moor?
• Oldsmobile
starter motor testing?
Oldsmobile STARTER MOTOR NOISE DIAGNOSIS?
These
details will help.
Thanks.
RUNS.============
For
These
Click
How to test
starter solenoid?
http://schematicsdiagram.blogspot.com/2011/06/how-to-test-starter-solenoid.html
How to test cars
starter?
http://schematicsdiagram.blogspot.com/2011/06/how-to-test-cars-starter.html
How to replace
starter in car?
How to replace Starter on
Infiniti Q45?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-starter-on-infiniti-q45.html
2006 GM Montana: How to replace Starter
Solenoid?
Saturn SL2: How to replace
Starter Motor?
Saturn
• Oldsmobile
• How
• Oldsmobile
These
details will help.
Thanks.
Saturn SL2 Starter Wiring Diagram?
Oldsmobile starter solenoid replacement procedure?...
How to replace Oldsmobile starter moor?
Oldsmobile starter motor testing?
------------These details will help.Thanks.
