Question about GE (PSS26MSRSS) Side by Side Refrigerator
I replaced ge smartwater filter water and ice still taste bad
  • 1 more comment
  • pcagle1 May 15, 2009
    Thanks I placed a lemon in the freezer will let you know if it works.
  • pcagle1 May 16, 2009
    It's been 24 hrs water still tastes bad.
    Didn't work still tastes bad
    Sergeant:
    Champion:
  • 214 Answers
The taste is because of mixing of diffrent type of smell of your food materials......nothing to worry! just cut a lemon into two half and place it into your freezer and wait for about 8 hours......................have a nice day :-)
Posted on May 15, 2009
  • satya prakash sahoo May 16, 2009
    the taste is because of mixing of diffrent type of smell of your food materials......nothing to worry! just cut a lemon into two half and place it into your freezer and wait for about 8 hours......................have a nice day :-)
After replacing the cartridge, the water flow is extremely poor. After calling GE, I was told I may have a bad filter. Hope not at the price per filter they charge. Is there any other solution? Is it...
The GE GXRLQR is the correct *replacement* filter for the following "Smartwater" single stage filtration and exterior refrigerator icemaker systems:
  • GE GXRLQ
  • GE GX1S50F
  • GE GQ1S50F
This filter is rated for only 750 gallons / 6 months of use (typical fridge with ice maker & water service). Most home faucets will deliver about 6 gallons / minute which roughly translates to about 2 hours of running water.
The GE FQSLF works with the following for the following Dual Stage Under Sink filtration systems:
  • GE GQSL55F
  • GE GXSL55F
Because there are 2 filters, they will last nearly 2x as long as the GE GXRLQR. and would likely be better suited to serving a faucet which will pass much more water than a fridge ice maker & chilled water dispenser would.
The real question is: Which GE filtration SYSTEM (not filters) do you have?
Sep 09, 2013 | GE GXRLQR GE SmartWater Inline Filter...
The water in our area was flushed after the flushing we replaced the water filter because the water tasted foul. Well now the ice still taste foul. We have dumped the ice container serveral times and...
did you flush the refrigerator at all? Run water through it for about 10 minutes and that should do 2 things breakin your filter so it doesnt taste so foul. Also clear out any rust, dirt, or other contaminents that may be in your system after they flushed the water in your area.
Jun 17, 2008 | GE Refrigerators
GE fridge 1999 model. water started tasting funny. found black stuff in a peice of ice. Water in rest of house seems fine.
Hello there,
When your water starts tasting funny and you can see some kind of particles in the ice, then it means the water filter is dirty and needs to be changed. Try to get the water filter replaced and the funny taste will stop.
If you are having some kind of lime taste or mud taste, or lime deposits or mineral deposit, is simply means you will have to replace the water line and reservior.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Refrigerators
The water and ice taste bad. The filter is new
put a box or two arm in hammer baking soda in freezer water and ice tends to absorb different orders give it a few days should be ok good luck zap
Apr 12, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Jan 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Coffee taste bad
Coffee Tastes Bad- Cuisinart
1) Run 1 tsp lemon juice per 1 cup water through Cuisinart
2) Use filtered water
3) Replace the charcoal water filters every 3-4 mos
4) Use better coffee
-Tha Mp3 Doctor
Nov 12, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Bad water & ice cube taste
then change your filter. the new filter could be different with the old filter. check the new filter, see if there is odor removal and taste removal with it.
if not then get the filter with carbon filter, odor and taste removal.
then with a new filter, run about 5 gallons of water before using the water for drinking.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
208 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
