Question about IBM ThinkPad R51 Notebook
In my pc costrast is full & one small box come in my pc screen
Actually whenever i work on my pc one small box come in my pc in center position on this
box the message come
constrast 100. if click
on this small box no any
think happend.how to solve
this problem.plz help me.
2001 yukon xl which fuse is the sunroof fuse
In the under hood junction box , fuse CTSY LP 15 amp . Instrument fuse panel PWR WDO CB 25amp .
Sunroof Motor Synchronization
Synchronization will be necessary anytime the sunroof module battery positive voltage circuit is interrupted. The sunroof module will be synchronized when the controller learns the full vent position. The sunroof system will ignore any open request until the system has been synchronized.
To synchronize the sunroof:
  1. Turn ON the ignition, with the engine OFF.
  2. Using the close/tilt up portion of the sunroof switch, operate the sunroof glass until it reaches the full vent position.
  3. Verify that the system operates normally.
Once the sunroof glass reaches the full vent position, the actual position is stored in the memory of the sunroof module. The sunroof module will stop the motor one motor revolution before the defined actual positions
Hope this help ! good luck !
Dec 24, 2014 | 2001 GMC Yukon XL
The touch screen on my minolta 350 can't be displayed whenever i press exactly on the written box but below the written box it can normal be displayed, i figure out it must need some adjusts to put it...
Initial Mode Function Setting Procedure
1. Remove the Compact Flash Cover [1].
2. Press the Warm Restart switch [2].
3. When "." appears at the center on the left-hand side of the screen, enter "3" from the
10-Key Pad.
4. Enter the 8-digit service code and touch [END]. (Default value: 00000000)
Touch Panel Adjustment
Functions • To adjust the position of the Touch Panel display
Use
• Make this adjustment if the Touch Panel is slow to respond to a pressing action.
• When the control panel is replaced.
Adjustment
Procedure
1. Touch [Touch Panel Adjustment] from the Initial mode screen.
2. Following the arrow mark, touch the four points (+) sequentially on the screen using a
pen.
NOTE
• Be sure to touch the very center of each point.
• Use care not to damage the screen surface with the tip of the pen.
Feb 12, 2014 | Konica Minolta Office Equipment & Supplies
When i open Cue Club in win7 (laptop model-acer aspire 5738z), it opens in a small square screen rather than full square screen. my pc's resolution is set as maximum. can any one suggest how to play the...
Check the in game options of the game itself. Somewhere in there should be a check box option allowing you to choose between full screen and windowed mode.
If there is no option, then find the shortcut to the game, and right click on it. Then click on properties. On the command line (that leads to the actual game file) go to the end and see if it has -window at the end of it. (might look like c:\program files\egames\cue.exe - window) if you see that window part (or win in some cases) then delete that and see if that helps.
Don't forget to Rate :)
Aug 13, 2010 | eGames Cue Club for Windows
HP Deskjet F4280 scanning problem
reload the whole HP software package in this PC
no PC stated nor full model number
no OS stated, what Op sys is it windows 10>? what/?
why not ask hp this. on there forum , warning the same questions will be asked, or all answers will be wrong
ask here, REAL HP, we are not HP here, we are chat box (dumbb)
https://h30434.www3.hp.com/
Aug 07, 2017 | HP DeskJet F4280 All In One Printer InkJet
My i68phone screen it dosent work what can i do
try and calibrate your screen.
Please use the stylus to calibrate!
The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until
"Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions
on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first
see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and
eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen,
immediately press the side volume button in the down position. A white calibration screen should now
show & you can calibrate the touch screen using the stylus. Try to tap as close to the center of the little
pulsating icons as possible, as this will more accurately calibrate your touch screen. If the calibration
screen didn't come up using that method, then you can get to it from the Main menu screen.
Select "Settings", then select "Pen calibration", & follow the previous instruction.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
Mar 04, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Pc display
This maybe due to lack of Video Card/Monitor drivers or the resolution is set to a small size. You will have to find out which video card you have, and if you have an LCD sometimes they come with drivers (Samsung LCDs have drivers). To find out what video card you have, you can usually go off the model name and number of your computer and get the drivers from your manufacturer's website. If it is a home built computer, you will have to look at the card/motherboard model and serial numbers to figure out the video card they use. Normally XP has a default video driver and it should not do a miniature resolution, but it happens sometimes.
Nov 03, 2008 | Computers & Internet
Window xp display
This should be your graphics card driver is not it. The original installation of hardware drivers may be better.
If that is not what system you set up the software in question. Can be re-systems.
http://www.notebooks-driver.com
Toshiba Satellite 17" L355-S7812 Gaming Resolution Problem
This is a common problem with Toshiba Notebooks. Their driver is locked onto Intel version 13.29 which is a buggy driver that has an issue keeping the aspect ratio settings in the control panel. You will want to download Intel's 15.9 drivers (the zip file for developers) and force that driver to install on the notebook by manually installing the driver in the device manager.
Another fix is to enable hot keys in the intel graphics control panel and press control , shift , f11 when the game starts to change the aspect ratios of the screen.
Its annoying yes and I wish i would have known about this myself before purchasing a toshiba sattlelite.
Jun 05, 2008 | Computers & Internet
IBM ThinkPad R51 Notebook Logo
43 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
