Question about Yamaha 5.1-Ch. Surround Sound Home Theater Speaker System
Need help with my suround sound system
My surround sound system was work fine until i detached it from my cable box and attached it to my dvd player after I was done using my dvd player I tried 2 hook it up to my cable box again but now I went through all the inputs and none of the seem to be working
Can hardly hear the voices when watching a movie. the surround sounds great just can't hear the voices, it's very muffled.
Posted on Aug 22, 2009
    Sergeant:
    Champion:
  • 255 Answers
Try wiggling the cords.i think it's open from the inside of the cord.sometimes attaching and pulling cords is the cause of no sound at all.check your cords for open.you can use a battery and a small lamp and wires.make a circuit of a lamp.then, get one wire from the small flashbulb and use it as a probe.the wire from the battery is the other.hook it up to your cords touching the one end ,like completing the circuit.if the bulb lights up it means it's ok and if not, your cord is open.
Posted on May 15, 2009
I've bought a panasonic sound surround dvd player and want to link it to a sky+ box and tv so that sky will play in sound surround. Can you advise on the wiring configuration please?
look at the back of your tv does it have a audio out RCA jack?
it should do plug in the surround sound into that using RCA cables
if your tv does not have audio out RCA jack then you can
get a adapter which makes scart connectors turn into RCA jacks get that off ebay
plug the yellow line to the tv and connect the red and white to suround sound
but with this there are a few problems sound will only come out when surround sound is turned on and skys sound will never play out the tv
if you switch to a PS3 or something it will not play suround sound
yuo best option is the RCA plugs in the back of the tv
because you have not written the model number of the tv or the suround sound i cant help any further
Jan 12, 2010 | Panasonic Home Theater System System
Can't get surround sound while playing the PS3. The surround works while watching cable
your suround sound system has been wired up so only cable plays throgh speakers
does your tv have a audio out RCA jack?
if so then connect the home theater to that
i cant help anymore because i dont know the suround sound model number ot what tv
Jan 11, 2010 | Audio Players & Recorders
I want to have tv go through surround sterio
you need a optical cable to play tvs sound in suround sound
but that depends on if your suround sound has a optical in
your tv does not have phono terminal for audio out
Jan 01, 2010 | LG 42PG20 42 in. Plasma HDTV
I can only get the suround sound to work a dvd playing and not though tv
is the surround system connected to the cable box. normally its the aux input. if your using a optical cable it should say digital in. try inputing your surround system to either one. the wires should be output from the source(tv,cable box) to the input of your surround system
Oct 22, 2009 | Philips HTS3357/05 Theater System
No suround when watching tv with sky + box,
You will need a DVD player with an optical output, as the sky engineer said. A Co-axial S/PDIF output could also work if your surround sound has that input, however not all units transmit surround encoded sound through the Co-Axial output. Only option really is to upgrade if that doesn't work
Mar 05, 2009 | Televison & Video
Surround sound to work with sky+
hi yes it is....
wot u need to do is.....our red and white audio leads go from sky box to dvd box...we then put our dvd player onto video 1 using function button on remote
hope this helps
Feb 20, 2009 | Sony DAV-S300 System
I have an old Zenith Digital Surround System the Receivver is a Model Z763B with a DVD Player/Recorder connected. When I play a DVD or VHS the sound can be heard through the TV and the Sound System,...
I have the same A/V receiver and in my setup there is an audio output (red and white able) coming from DVD player directly into Zenith Z763B. The video from DVD Player goes to TV input (yellow cable).
There might be alternatives to the setup mentioned above but I like to watch movie in a surround sound, rather than output from TV.
Jan 07, 2009 | Audio Players & Recorders
Hooking up sony dav-hdx 475 with digital cable box and hdtv
Plug the digital cable box audio strait into the dvd player. Plug video from the digital box into your tv.
Thats what i did and it works perfectly.
Jan 04, 2009 | Sony DAV-HDX500 System
SETTING UP TJE PANASONIC DMR TO OTHER COMPONENTS
if studio audio facility in tv there [are] hence remaining to install just input channel of output but if there is no having to suround efec,thank.........
www.modifmax.com.
Feb 08, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
Yamaha 5.1-Ch. Surround Sound Home Theater Speaker System Logo
341 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
