Question about Honeywell HZ-709 Oil Filled Radiator Heater
Heater When I turn on my unit it shows an "F" and the unit turns off. Does anyone know what that might mean or how to help me to get it working. Thanks Sheryl Ann
  • 1 more comment
  • Anonymous Nov 05, 2007
    The problem I have is that when I turn the unit on, the display shows an 'F' and then it immediately shuts off. The first winter we had it, it worked fine. The problem started in its second year of use. It would work for a time but then shut off. And now coming into this third winter, it won't work at all. I've searched files for an operator's manual but can't locate it. Does anyone know where I can find one on line? It was a gift and I also don't have a record of the warranty mailing - that I usually do - but can't locate on this one. Francie
  • sdbeag Dec 19, 2007
    I have the exact same issue! After switching it on I hold down the middle button and after a few goes (with it switching itself off a few times) with me still holding down that center button when I switch it on, a number comes up (presumably a temperature) and the heater works for a while.
    It requires far more patience than I have. The design is seriously flawed. And I have no idea how to soulder wires together myself like the person who responded to your message before. Good for him! Just my luck, I no longer have the receipt. I will never buy a honeywell again! Thanks for posting.
  • sayedz Mar 25, 2008
    Problem: firs let's identify the problem, there is a sensor on the inside panel, made originally for safety if you tipped the heater off, it kill the power causing it to turn off...after a year of so that sensor get a little rusty/dirty causing it not to work correctly...
    let's find out how to fix that annoying turn off..
    tool needed, a phillip screw driver.. electrical tape or soldering unit..
    fixing it: take out the top and bottom screws, to open the panel. after you open the panel you'll see a metal bar screwed to the front controller...take all 6 screws out...the front panel comes off....then there is about 4 screws holding an inner box, open that up..
    inside there, you;ll see lots of wires...look for 2 small blue wire running together to a black sensor that make noise everytime you move it....
    disabling the sensor
    2 ways you can do this..
    -you can cut the wire off using a scissor, and connect the blue wires together, use the tape to tape them.
    or
    - you can solder them together on the back of sensor panel...
    there you go problem solved...
I had the exact same problem with the HZ-710 - it has the same controls and design. The manufacturer (KAZ) www.kaz.com indicates on their website that there are no parts available for these heaters - I suspect that it is cheaper to replace these inexpensive heaters than to have it fixed. There sevice phone is 800-477-0457
or email: ConsumerRelations@kaz.com
I discovered that my heater had a defective auto-shutoff sensor - there's two sensors that are wired in tandom - both need to have a connection to complete the circuit - I'm not sure if it was the sensors or the incredibly sloppy wire connection that was causing the problem - I disconnected the sensors and permanently soldered the wire connection myself. The unit works fine now.
Even though I voided the warranty - to me it was worth it not to hassle with any (non) customer service - for I suspect they would send me a note that stated the following - "At KAZ we pride ourselves in quality manufacturing and are sorry for any incovenience that you may have.blah, blah, blah, blah, blahhhhh, bla-bla-bla, buuuhlaaaa, blah, blah, blah, um, blah, blah, blahhhhh, b-b-b-b-lah, la, la, blah!
Posted on Dec 09, 2007
Thank you, thank you sayedz! We took my heater apart, somewhat like what you said - got enough from your post to figure it out, eliminated the bad tip-over sensor and now my heater is working! I'm so happy and WARM. We just used the tape version. I don't have children in the home, just pets, but I only use this heater in my office during the hours that I'm in there, so I don't think I'll have any safety concerns with not having that sensor intact.
I really appreciate you taking the time to explain how to fix it.
Posted on Nov 17, 2008
Heater less than 1 year old. Worked fine 3 days ago; tried turning on tonight and got a "E01" in display. Anyone know what that might mean?
E01 is low system voltage. This can be caused by 3 things. Either the incoming power is incorrect, the heater is connected to wrong voltage, or the tranformer is not outputting the correct voltage.
Check voltages going into the heater, if these are all correct, then replace the transformer
Feb 06, 2011 | Pentair Minimax NT Heater
HEATING UNIT IS POPPING THE 220 CIRCUIT BREAKER.
If its a resistance heater (electric heat) chances are you have a shorted out heater element. This is the most common problem with these units. You can disconnect the 220 going to the elements and turn the unit on and see if it still pops a breaker. If it don't then you know its the heater elements their selfs. If it still pops a breaker then look for a wire that go hot and shorted to either the case or another wire.
Take caution when working on 220 volt equipment as you will get shocked. You should never touch anything inside the unit unless you have pulled the power to it (Turned it off via breaker or plug or what ever means it has to connect the unit to the household electric.).
Hope that helps you.
Jan 27, 2011 | AdobeAir Heating & Cooling
I have an error EE 2 on my lazer 56 toyostove Does anyone know what that means?
EE 2 means its not getting fuel, your flame sensor could be dirty, or there could be a problem with the circuit board. The heater goes thru a 3 min warm-up/purge before the pump comes on. If the pump is making a loud ticking sound then it isn't getting fuel. You should then check your filter and the strainer in the fuel sump. If the pump isn't making a noise you could check the flame rod and clean it with some steel wool. You should check to make sure the igniter is working also. After you turn your heater on the cover on the igniter will start to get warm and will get very hot before the purge is done so use caution. Hope this helps.
Apr 03, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
I have a digital thermostat that upon return from vacation the backlight is not lit and the functions don't work. The heater unit fan was on during the vacation and the only way to turn it off is to...
Batteries dead????? Most thermostats have batteries inside , replace them....is the Furnace switch/breaker on ??...Some thermostats use the furnace power to function
Oct 25, 2009 | Heating & Cooling
1998 BMW 328i heater/AC blower is not running
You have clean the blower unit , may be its dirty then . and then check the blower resistor unit for malfunction.
Aug 04, 2009 | BMW 328 Cars & Trucks
Pentair Minimax Nt heater wont turn on and heat,
Bad thermistor. The yellow wire that plugs into the control board. Lick finger and touch prongs. Heater should come on
May 29, 2009 | Pentair Minimax NT Heater
I have an icon similar to a fire flame showing on my honeywell Energy star thermastat for my home central ac and heating unit. what does this mean because my heat has stopped working
hi this is mr.grzz, well to answer your question, the little icon on your t-stat that shows a little flame means that your t-stat is calling for heat, there in lies the problem your t-stat is doing what it is supossed to do, your problem lies with the furnace, it could be a nuber of things wrong, but first and formost, try turning the power off to the furnace at the breaker panel, wait for about 30 seconds, then turn the power back on, this resets the circuit board, see if that will help your furnace to run, but there is a reason behind why your furnace failed, if this does the trick, then great, if not please fell free to come back and let us know what the furnace is doing after it trys to start up, thanks for your question, hope that helps, mr.grzz
Jan 20, 2009 | Heating & Cooling
Fan and light no longer turn on
possibly the thermal overload sensor failed internally? as indicated in the instructions there is a overload sensor and thay will typically fail in others appliances.
Oct 30, 2008 | Reiker RRC120004 Brushed Steel Ceiling Fan
Honeywell HZ-709 Oil Filled Radiator Heater Logo
907 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
