Rinnai econoheat 850
When i hold down the button to light the heater it wont stop down it clicks and does everything but goes back up and wont stay on thanks
    Scholar:
  • 41 Answers
sounds like it has a faulty button. The "on" button on that model has a button on the front side which should hold the on button down after igniting. Check and make sure that it is there. I think it is a spring loaded button - maybe the spring has dis-lodged itself. If the button is faulty yhou can only replace it.
Hope this Helps
Regards
Bryan
Posted on May 22, 2009
Pilot comes on but when you let the button go it turns out.I have replaced thermocouple but to no avail. Please help.WHAT NEXT
Posted on Jul 14, 2011
I have a 30000 btu rinnai floor heater mod 630530. The pilot wont stay lit . I have installed a new thermo couple . please help
be sure the thermocouple is in the pilot's flame and hold down the pilot lighting button long enough to heat it before trying to operate the heater...20 to 30 seconds should be enough. If this doesn't work, you may have a bad gas valve
Feb 21, 2015 | Rinnai Heating & Cooling
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light will stay lit as long as i hold down the knob, but when knob released, light goes out....... i have a wall mount model# GWRN30t
Normally when you release the knob it work the same as a two way switch ,which mean gas will stop flowing through the small pilot channel and will flow to large channel where it will continue to burn.
In your case, you have to strip down the regulator switch and look where the gas passage is glogged.
Oct 05, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
What causes a diffrence in glow colour?
Normally purple/blue on the radiants indicates low gas pressure, could also be dust slowing gas velocity into burner and/or an aeration problem. Get it checked out properly.
Jul 07, 2009 | Heating & Cooling
Rinnai burner goes out when ignition button is released
The thermocouple [s] require replacement, or in my experience try servicing the unit first. There is an injector for the main pilot and a secondary injector for the flame thrower ignition. Both of these are prone to blocking due to dust and can be enough to shut the unit down. Although usually this is thermocouple related as you are manually keeping the unit running when you hold down the button, if the tcouple is broken it wont send enough millivolts to hold the magnetic valve open when you release the button.
Cheers
May 16, 2009 | Rinnai Heating & Cooling
Pilot lights but when ignition pops back up the flame goes out
will either be the unitrol control box or the thermocouple, when you push down you are holding two magnets together and waiting for a small charge to be created from the probe in the flame , if this is not working you have no charge and the magnets won;t stick to allow the valve to open, change the thermo and see if that works first, its way cheaper than a new controler
Nov 25, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Rinnai Econoheat 850 gas heater
Hi Daryl,
It needs a service. The jets carbon up and when they heat up they stop the gas getting through. If you take it to a Gas Shop they will charge you around 90-00 to service it and all they will do is blow it out with compressed air. If you can get hold of an Air Compressor with an Air Blower on the end you can blow it out yourself. Remove the Gas Hose from the back and place the Air Blower into the hole where the gas goes through and hold down the ignitor switch to open up the jets. Give it a good blow out. Once you have done that give the candles a blow as they eget dirty also. You will see a white dust more than likely come out of them. If you want to give it a good clean out remove the cowling and clean (blow out) the inside of the Heater. The cowling from memory has only about 6 or 8 screws holding it on. That should take the top and sides off. I can't remember if you can remove the lower vent on that model - if so it will only be either 2 or 4 screws. Hope this Helps.
Regards
Bryan
Jun 17, 2008 | Heating & Cooling
Heating & Cooling Logo
290 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
