Question about Samsung 7.3 Cu. Ft. Electric Dryer
Samsung dv4006 dryer belt
Posted by majid2 on May 15, 2009
THIS IS MANUFACTUR OF BELT WEB SIDE
http://megadyne.it/ist/index.php?p=home
LETS ALL SEND A E-MAIL TO THIS CAFTORY, TO FIND OUT WHERE WE CAN FINE ORIGINAL BELT
MEGADYNE PIII 1975 H7
Plll Household Application
1975 Effective Length
H PV Section
7 Number of ribs
After four new belts.
There is only one solution , load the dryer into a UPS truck and ship it back to Samsung . Put a note inside and tell them to stick to TV's and stay out of the appliance business .This is the cheapest solution short of filling up the landfill . Believe me this is a lot cheaper than buying belts
Cam
Posted on Aug 03, 2009
  • 41 Answers
See:
http://www.fixya.com/support/t1210394-samsung_dv4006_dryer_belt
Posted on Jul 10, 2009
Rockworth 1.5 hp 6ltr oil free compressor drive belt replacement
You could try this link.
This is for megadyne tb2 310 belt (nlh6ltCOM)
http://www.solenttools.co.uk/performance-power-drive-belts/performance-power-compressor-drive-belt-nlh6ltcom-2051157-331171-.php
Feb 19, 2013 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Take back off to get the belt
I have never worked on one like this but I would be willing to guess that you go in through the front on this model. Might be a good time to forward your question to my group of sublime appliane amigos to take a gander at:
These are the muthas of all appliance tech web sites known to mankind:
Post your model number to any of these fine forums for
a simple answer that will save you lots of money:
http://appliancejunk.com/forums/index.php?referredby=858
http://forum.appliancepartspros.com/
http://applianceguru.com/
Jun 09, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Replacing belt, can't seem to get belt tight. Need to know how to wrap belt around pulleys.
You can find the belt routing for your Maytag here:
http://www.repair-help.com/kb/index.php?article=105
If it won't tension, perhaps you have the wrong belt. The correct belt can be purchased from your local source or this website.
For those of you with other Brands of dryers start here:
http://www.repair-help.com/kb/index.php?category=13
Note: After unplugging dryer; The belts for most regular dryers are accessed by removing the front panel.
Wash and Dry and put the clothes line away!
Apr 25, 2009 | Dryers
Possible replacement belt quality problem for the Samsung DV4006 / DV4006J / DV4015J / DV665JW and the Maytag MDE2400AZW dryers:
The original belt for the Samsung DV4006 / DV4006J / DV4015J / DV665JW dryers is a Megadyne 1975 H7. The part number is DC66-00121A, but when ordered, a Dongil 7PH1975 belt may be shipped instead of the original Megadyne. The Maytag MDE2400AZW dryer uses the same belt. The part number is 35001010, but when ordered, a Dongil 7PH1975 belt may be shipped. It seems that the Dongil belts are inadequate for these dryers. They delaminate and may fail prematurely. Even new, they cause a thumping sound each time the seam goes over the motor pulley. Other than Megadyne, another good belt is the Hutchinson 1975H7. The appliance part number is 1258288107.
Where to get an original Megadyne 1975 H7 belt:
eBay member 'appliance-parts' in Colorado, USA has emailed me that their Samsung DC66-00121A belts are Megadyne. Website: http://appliancefactory.com Email address: partsonline@appliancefactory.com
eBay member 'ladydi1975' in Ohio, USA has emailed me that their Maytag 35001010 belts are Megadyne. eBay store: Discount Appliance Parts.
Where to get a Hutchinson 1975H7 belt:
eBay member: 'zodiac300_0' in Brighton, United Kingdom. I have ordered a 1975H7 belt from them and received a Hutchinson.
Other possible causes for belt failure:
--Motor pulley designed too small. The belt may be flexed beyond it's minimum rated radius.
--Excessive heat in the dryer due to lint in the vent line or vent line too long. The Dongil belt may be less heat resistant than the Megadyne.
--Worn drum bushing DC66-00062A.
--Metal burrs on the steel motor pulley. Deburr by inserting a small screwdriver in each groove while the motor is turning without the belt.
--Belt on the wrong track. The motor pulley has nine grooves and the belt has seven ribs. The belt must be in the middle. It's easy to place it one groove forward or backward by error.
--Small scratches on the drum where the belt contacts it. The scratches may be like small knives and damage the belt. Sand with a fine sandpaper.
--Idler pulley damaged or bearing worn.
How to replace the belt:
--Remove top cover.
--Remove vent panel (in back).
--Unclip door switch from front panel.
--Disconnect wire harness from door switch.
--Unscrew panel left of control console (from behind the panel).
--Unclip panel left of control console (from behind the panel).
--Unscrew control console.
--Unclip plastic panel on bottom, front
--Remove screws behind door. Remove door.
--Unscrew large front panel, remove.
--Inspect vent line for lint buildup, drum bushing (back of dryer) for wear, motor pulley for burrs and debris, drum for scratches, and idler pulley/bearing for damage.
--Vacuum all lint.
--Install belt around drum, idler pulley, and motor pulley. The ribbed side of the belt contacts the drum. The flat side of the belt contacts the idler pulley. Press on idler pulley to stretch the spring, and line up the seven belt ribs in the center of the nine motor pulley grooves.
--Reassemble.
Nov 06, 2008 | Samsung 7.3 Cu. Ft. Electric Dryer
Dyrer belt will not tight up even from back side it way to loose
You must elaborate and tell us more info.
Brand, Model year or age of fryer.
What you did and what was your problem????
We can not assist you without as much info as you can give us!
huuum
A waiting your post!
Oct 08, 2008 | GE DSKP233EWWH Electric Portable Dryer
Samsung DV4006 dryer heats but does NOT turn
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Sounds like you need the belt replaced !
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 27, 2008 | Dryers
Maytag gas dryer belt routing and mounting of tensioner on ModelMGD5700TQ0
I have found a link that should provide you with the belt routing diagram you are looking for.
Any trouble,post me back.
Dave E. (Illeagle)
May 31, 2008 | Maytag PYE2300AY Electric Dryer
I need a belt for my samsung dv 4006 dryer
Yes!
Global electronic supplies Inc
5600 Timberlea BLVD
Mississauga ON
L4W 4M6
1-800-668-8776
Feb 15, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Samsung 7.3 Cu. Ft. Electric Dryer Logo
894 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
