Disk error hi, please help me, MP4 Player, appears to me ''disk error''. I tried toformat it several times in the FAT partition but nothing. Also I usedthe program that you recommend the site but also did not help. Whetherwe can someone send a new firmware or assistance with this problem. MP4 player is Lisong design Firmware LSC_25109V_B1C 15.01.2009. 9.5.54 thanks
  • bglavan May 17, 2009
    i dont find link for this firmware, can you write link where i download this file.
    thanks advance
  • 61 Answers
Search for its firmware files on the web...and overwrite it on the existing...
Posted on May 15, 2009
I loaded some pictures in my touchmate neno mp4 player then connected the cord to another computer to send the pictures there. then i deleted the pictures,other songs and videos.somedays later i noticed...
Try to do the following and see if it work..
steps:
1.plug your pen drive in your computer.
2.then open Control panel.
3. open administrative tools.
4.open Computer Management
5. a window label computer management will appear.
6. click disk management
7.locate you pen-drive and select delete partition or format it fat 32 or other format convenient for your usage.
ok
hope this will help
cheers
uttam
Jan 21, 2010 | Audiovox MP4128 MP3 Player
Infitek MP4 Player
Did the device came with a CD? If yes, install the driver from the CD to your computer, so that way the MP4 will be recognize by the PC.
Once you see the MP4 showing on your PC, right click on your mouse and go to format. On file format you should you should see FAT or FAT 32, try FAT32.
Good Luck.
Jan 30, 2008 | Audio Players & Recorders
Tip
FORMAT ERROR IN MP3 PLAYER
if You are experiencing "Format Error" messages when adding or accessing music/videos on your player. this could be as a result of a corrupt memory region or not having the required or supposed memory size of the player(actual memory)
what you do you should format:
formating Ensures that what you have bought, is of the actual memory capacity.
. 1. You will not lose any firmware/theme related files.
2. You will not accidentally kill your player whilst doing so (unless you unplug or disconnect your player during the format process).
follow the step below to guide you
STEP 1
Back Up All Your Data Before Proceeding! This Guide Will Clear Everything In Your Player's Memory Chip!
Install MP3 Utilities, any version will do. It usually comes on the CD with the player, or you can download version 3.68
Here, or version 4.03 Here, or version 4.05 Here. Any one of these will do. The Disk Tool Utility is the same.
STEP 2
Start up MP3 Utilities Disk Tool.
You will be shown a screen like this:
Ensure that you select LOW Format Type.
Next, go to the Partition and Encrypt tab as shown below.
Now, slide the Partition Slider all the way to the Right.
You will notice the "Setting encrypted disk capacity" increases, it is normal.IMPORTANT.IF YOUR MP4 PLAYER IS LIKE 2GB OR MORE MAKE SURE THE PARTITION AND ENCRYPT TAB WHEN YOU INCREASE IT SAYS YOUR PLAYERS MEMORY.FOR EXAMPLE.IF YOU HAVE A 4GB MP4 PLAYER AND YOU ARE SLIDING THE PARTITION AND ENCRYPT TAB MAKE SURE THAT WHEN THE NUMBER INCREASES IT SAYS SOMETHING LIKE 4000MB.IF IT DOESN'T DO THIS DO NOT REPEAT DO NOT DO THIS ENTIRE PROCESS.
*NOTE* Ensure That You Do Not Click The "Set Username And Password", Leave It UNTICKED.
Next, click on Start to begin the format and partition process. You will be presented with a dialog box like below, click on Yes to proceed.
It will take a few moments for the process to complete. You will notice that your player would disconnect from the computer, and then re-connect back again.
You will be presented with the "Complete setting disk partition!" dialog box like below.
STEP 3
Go to My Computer and check that now you will two memory drives for your player. You might need to click Refresh or press F5.
One of which would be small (about 17MB), and the other would be the remaining memory capacity.
Do not worry if it does not appear, just continue to with the guide.
then go back to the Partition and Encrypt tab.
Slide the Partition slider to the Left, and click on Start.
repeat the process and the "Complete setting disk partition!" dialog box would appear.
Check in My Computer that now you will only have One single memory drive for your player. Right click on it and select Properties, this is your actual real memory capacity.
Now check your player's Memory Info for the correct memory display.
To access this, go to your player's SYS TOOL >> MEMORY INFO.
Your player should display the actual memory size that you have just checked.
Check if the percentage is at 0%. If it is, you can skip Step 4 below, and continue to Step 5.
STEP 4
If your player's Memory Info does not show 0%, you will need to complete the below procedure.
Right click on your player's memory drive, and select Format.
Now a new windows format screen would appear.
Select FAT in the File System dropdown menu.
If after completing Step 3, your player really does have 4GB of memory, then you need to select FAT32 instead. As FAT only supports upto 2GB.
Click on Start to begin on the format process.
A warning will appear for the format, click on OK to continue.
Wait for a few moments while Windows formats your player.
When completed, check your player's Memory Info again, it should display 0% now.
STEP 5
Once completed, start copying music/video files to your player and enjoy enjoy your player
on Dec 19, 2009 | Audio Players & Recorders
Mp4 player wont register as a device on my PC
Just follow these steps below:
To check if is really connected to your pc.
Go through: Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
You can try to format it with fat files system or the file system you are accustomed with if there is nothing important on it.
hope this help you
Regards
uttam
Jan 13, 2010 | Audio Players & Recorders
My mp3 is all ******** u know,whenever i put songs in it,FORMAT ERROR occurs when i play it,dont know what is ******* it up.if anyone can fix this problem please help.thanks.
STEP 1
STEP 2
STEP 3
STEP 4
STEP 5
Once completed, start copying music/video files to your player and enjoy enjoy your player. hope this helps
Dec 19, 2009 | Apple iPod nano
Format error in LG MP3 player CM60022 ACT_V9.1.52
first, go here and download the utility:
http://mp3-player-utilities.software.informer.com/
Then:
You will repeat the process and the "Complete setting disk partition!" dialog box would appear.
Then Format again your player on Windows..
Jul 21, 2008 | iLO (2 GB) MP3 Player
I keep getting Fat Error. I have not dropped the unit. This proplem has just started today. Now my computer will not recignize the player, F5 will not refresh the player. If there is anyway you can HELP...
This error means that the player's partition's got messed up. Is there a way you can force the player into Disk Mode? If so, try that. If it works, the computer would recognize it. You can then right click on the drive and select "Reformat". That should fix everything.
Apr 12, 2008 | Audio Players & Recorders
CRAIG MP4 plus video player- disk error message appears.
make sure the songs you download are right for your mp4 player because Limewire only plays mp3 songs. so i would go on the internet and find a music site that has mp4 songs
Jan 28, 2008 | iLO (2 GB) MP3 Player
Ipod 4gb error
I had the axact same problem and these instructions fixed it:
This guide is for you if:
1. You've bought a mpx player larger than 2 GigaBytes capacity (eg 4GB, 8GB, 60GB, etc). Not limiting to larger than 2GB, smaller capacity (eg 512MB, 1GB, etc) players are also subjected to possible memory hacks.
However, recently i've realised that the Actions chipset does support upto 4GB (2x2GB). Also, there were some unconfirmed news of genuine 4GB players.
2. You just bought a new player.
3. You are experiencing "Format Error" messages when adding or accessing music/videos on your player.
4. You are experiencing frequent Player Restarts (hanging on the hourglass) when playing certain songs.
5. Your player duplicates the music/video files that you add to it.
6. Your player does not allow you to move/delete files that you have copied to it.
If you fit any one of the above (or even all), then this guide is for you.
Why you should format:
1. Not formatting will only cause you ALOT of trouble and hassels in the future.
2. Not formatting increases the chance of killing your player in future, and you will need to perform the "Dead Player Recovery".
3. Ensures that what you have bought, is of the actual memory capacity.
4. If it is a gift for someone, you don't want them to come back to you with the above mentioned problems.
Common Myths regarding this formatting procedure:
On completion of this guide, should you end up with lesser memory than what you have paid for, it would be recommended to contact your seller for a full refund.
Also, take a minute to fill in an online petition against eBay, Paypal and fraudalent sellers who knows about this problem, but persists to trade with such fraud items for monetary gains.
http://www.mympxplayer.org/petition-stop...ay--vt3442.html
Every signature plays a significant factor, the more signatures we have, the better chance of eBay shutting down such sellers permanantly.
STEP 1
STEP 2
STEP 3
*note* it seems that some members reported that they do not see this extra drive appearing. Do not worry if it does not appear, just continue to proceed with the guide.
Now, go back to the Partition and Encrypt tab.
STEP 4
STEP 5
Once completed, sit back and start copying music/video files to your player and enjoy your stuff!
Dec 27, 2007 | iLO (2 GB) MP3 Player
Disk Error Message
the best thing to do is RE format the disc. i am currently having the same problem , witch i am tired of fixing them. if the item is from ebay : hong kong , i suggest you tell the buyer and complain. people will do anything for good feedback. saw formatting it will work. but you'll have the same problem in the future. either you copy all your music files to a folder. or buy one from Argos , woolworths etc etc...
Aug 30, 2007 | H&B MP401 MP3 Player
1,207 people viewed this question
 Grubhead
Grubhead
