Question about Intel D845GVSR Motherboard
Command prompt & cmd is not working
Hi...
I m using winxp(prof)Sp2. I want to work in command prompt or cmd but it was not working ,than after Quick heal virus updated, I check for virus not found. my pc I cleaned virus through Native boot .Than after I checked found the same, cmd flash for secand and gone.the is in network.network drive cmd command shoutcut run.
please do needful
  • fougzki May 11, 2010
    Seems like virus is still in your system try avira free antivirus and malwarebytes.
  • Intel Master
  • 4,806 Answers
Hi there.
Hit ctrl, alt, del to start task manager, in the top left hand corner click on file, then click on new task (run) in the box type cmd and it should run from there.
Good luck and thanks for using FixYa!!
Posted on May 15, 2009
Smc router says limited connectivity and won't work.
I experienced the same issue before with my route,try doing these steps im sure this will work somehow. (flush the DNS cache)
How to do it:
If you are using Windows 2000/XP operating sysytem
-Fire up a Command Prompt (Start Menu>Accessories) and execute the command
ipconfig -flushdns
if you get 'could not flush dns' or message saying dns resolver cache could not be flushed.
If it is XP SP2 then go to Start > Run > CMD > type netsh winsock reset > enter, restart as prompted, if still no connection then go to Start, Control Panel (Network and Internet Connections then Network Connections -or- straight to Network Connections, double click on the Local Area Connection in use (usually the one that says Connected) and pick Support. Try the Repair button after Winsock fix. Use that winsock fix only if you are using SP2.
go to "start, control panel, administration tools,services,then look for DNS Client, and make sure it's started, and set to manual.
May 30, 2011 | SMC (SMC7004AWBR) Router
Tip
CMD Prompt here, add to folder context menu windows xp
Add the open cmd prompt to folder context menus also drives and MY Computer
Copy what's in the code area to notepad and save as cmd here. reg
CODE
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\Drive\Shell\cmd]
@="Command Prompt"
[HKEY_CLASSES_ROOT\Drive\shell\cmd\command]
@="cmd.exe /k \"cd %L\ ""
[HKEY_CLASSES_ROOT\Directory\Shell\cmd]
@="Command Prompt"
[HKEY_CLASSES_ROOT\Directory\Shell\cmd\command]
@= "cmd.exe /k \ "cd %L\ ""
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\cmd]
@="Command Prompt"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\cmd\command]
@="cmd.exe /k \"cd %L""
on Jan 06, 2010 | Computers & Internet
Hi, i am using dell insprion 1525 laptop. i am faceing problem in netwoek drivers . i am not able to install network drivers and at lan card palce i am getting red light please help me .. praveen kumar
Boot the computer in Safe Mode with Networking and see if it connects that way. If not, try this fix.
TCP/IP stack repair options for use with Windows XP with SP2/SP3.
Start, Run, CMD to open a command prompt:
In the command prompt window that opens, type type the following commands:
Note: Type only the text in bold for the following commands.
Reset TCP/IP stack to installation defaults, type: netsh int ip reset reset.log
Reset WINSOCK entries to installation defaults, type: netsh winsock reset catalog
Reboot the machine.
Download Network driver :- R161378.EXE on support.dell.com
Jan 16, 2010 | Dell Computers & Internet
Windows explorer
Try this. Open Start>>Run and type cmd and press enter. This will open a command prompt window. On this command prompt window type the following steps.
type cd
type attrib -r -h -s autorun.inf
type del autorun.inf
now type d: and press enter for d: drive partition. Now repeat steps 3 and 4. Similarly repeat step 5 for all your hard disk partition.
Restart your system
Dec 23, 2009 | Microsoft Windows XP Professional SP2
My (Win XP SP2) command prompt does not work
First off, lets try a few things. This will help us narrow it down:
  • Try typing other known commands to see if they work (ipconfig for example)
  • Do a search on your computer for cmd.exe (you should only have 1, and it should be in the system32 folder.)
  • try typing cmd.exe instead of just cmd.
Give those a shot and report back. Depending on which one of these give you a problem, it could point to the correct fix.
The reason I say this is that your easiest solution may be to upgrade to SP3. The only times I've ever heard someone having this problem was also in SP2.
Jul 27, 2009 | Microsoft Windows XP Professional with...
My toshiba has no sound
there is some system files are missing .
Go to start menu then type in run "cmd"
then ou see command prompt.type there "sfc /scannow"
then it scan for corrrupt system files when it need winxp source put the winxp disk in cd-rom then it get files.
Jul 15, 2009 | Toshiba Satellite A75-S213 Notebook
Command prompt not working properly
  1. Select Start>Run...
  2. Type cmd
  3. Click OK
  4. The Windows Command prompt screen appears
  5. Type cd\
  6. Press [Enter]
  7. You are now at the C: root directory
  8. Type Time
  9. Press [Enter]
The system will show you the current system time and ask you to edit the time entry. If you press Enter without typing anything, it will keep the current time.
Jun 12, 2009 | Microsoft Windows XP Professional with...
Windows XP SP2 Repair
Solution: Rename the C:\WINDOWS\SYSTEM32\CATROOT2 folder to something such as catold to prevent WinXP's Setup program from locating the folder and halting the installation. If you are still in Setup, press SHIFT-F10 to launch a command prompt from within Setup. At the command prompt, type cd\win dows\System32 to open the System32 folder and then type rename CATROOT2 catold, press ENTER, restart the computer, and attempt the upgrade again.
If you cannot reach a command prompt from Setup, reboot the computer from a Win95, Win98, or WinMe startup disk and rename the folder from the command prompt. You can also launch a command prompt by booting from the WinXP installation CD and running the Recovery Console.
Mar 25, 2009 | Toshiba Satellite 5105-S501 Notebook
HP LAPTOP DV9000 WLAN stopped working
Sounds like your wireless adapter has died you need to replace this ....
Nov 11, 2008 | HP Pavilion dv9000z Notebook
All needed drivers for WinXp.
The Toshiba website had directions for getting drivers. You will need to provide your model number and follow links to get help. Good luck
Feb 18, 2008 | Toshiba Satellite A135 Notebook
Intel D845GVSR Motherboard Logo
168 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
