Question about Logitech Z-5500 Computer Speakers
Sound Quit my logitech Z-5500 speaker system started making a crackling noise like a short would sound then it shut of the controller. Now the system is dead. Please advise
  • 3,866 Answers
Replace the logic supply board inside by finding someone on ebay with just the controller or take it to a repair shop is the only 2 solutions at this time for you, thanks and good luck..
Posted on May 15, 2009
Speaker leads shorted on right rear channel of Logitech Z-5500 system
First check the speakers by connecting to front connector if thr no sound then replace the speakers.If you here sound while swap the rear amp IC might be damaged replace the IC .
Dec 19, 2011 | Logitech Z-5500 Computer Speakers
Hi have recently purchased logitech 5500 system, it was working fine for a few days but now even with no sound running through it when you turn it on blast out a loud sreeching short out sound, just...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 25, 2011 | Logitech Z-5500 Computer Speakers
Hello there, I recently purchased a Logitech z-5500 speaker system online, I have plugged all the speakers and set it all up correctly. It makes sound when I pres the "Test" command on the...
verify if the computer has a digital output that matches your speakers (5.1 or 7.1). Also, verify that the cable leading from the PC to the main speaker box is OK. Also, the speakers may come with an installation CD, so you'll need to install the accompanying control application.
Jan 02, 2011 | Logitech Z-5500 Computer Speakers
I don't have a sound card.but how can i connect logitech Z-5500 speakers to my pc
Since Logitec Z-5500 is a 5.1 Speaker System you need to purchase a Sound Card to be able to connect it with your pc. You can get a Sound card starting with a price tag of 20 Pounds.
Hope this will help you solve your problem Best Regards NextDoorNerd
Jul 28, 2010 | Logitech Z-5500 Computer Speakers
My bass makes a crackling noise it never used to have this problem, i put this little faggy magnet near it and i think its the cause
Sounds like you turned your system up beyond it's capabilities... aka blown woofer. Buy a new sound system from www.pcrepairshop.org and that crackling noise will be gone for good, guaranteed!
Jul 10, 2010 | Logitech X-220 Computer Speakers
Repalcement Logitech Z5500 Control Center?
My Control center turns on but i can get any sound not even from the test system, Logitech cant help.
I went the a shop and check it on ther system still no sound :(
any ideas
Nov 17, 2008 | Logitech Z-5500 Computer Speakers
Crackling noise from subwoofer????
sgangsta91,
i think your speaker cannot support the sound that your computer produce. it means to say that, they are not compatible. specially when your computer sound interface that you used is 5.1 or 7.1 interface but your speaker specs is only for generic sound, you really hear a crackling sound and more if you set to higher volume.
but it can help if you only set your computer interface to generic sound or set only in lower volume it can help. because if you continue that way, your speaker can be seriously damaged that even at the lowest volume can hear the crackling sound.
or if you really want a fine good sound system then, buy a speaker that can interface with 5.1 or 7.1 or see manuals of your computer/motherboard. for recommended specs
aclamonte
Nov 07, 2008 | Logitech X-220 Computer Speakers
Logitech Z-5500
Well you have some options, you can either live with 2 speakers and change the settings back to default. Im assuming the colors you have are orange black and green. black= the surround sound speakers. orange= center and subwoofer. green=right left front
Now if u want true surround sound then you need to buy a new card that had all the ports for your speakers.
Oct 21, 2008 | Logitech Z-5500 Computer Speakers
Logitech 5500 Surround Sound controller
It 's not the fuse!!!! THAT fuse is only for SUB !!! if that fuse was the problem he wont have power at all.THE problem is with control center .I fix my control center changing 2 diodes ,but a friend of mine have exactly the same problem comming from some transistors with is located above that 2 diodes D700,D701(so he says) --- surf check google and you ll see a lot of customers with exactly same porblem AND THIS PROBLEM I THINK IS SOME DESIGN ERRORS THAT AREN'T FIX BY LOGITECH BEFORE SELLING THIS SYSTEM!!!!!!!!!
Jun 30, 2007 | Logitech Z-5500 Computer Speakers
Digital Sound Control Center
Suggest a problem with internal power connections open up the unit a check.
Logitech Z-5500 Computer Speakers Logo
324 people viewed this question
Top Logitech Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
JP Services
JP Services
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
