Question about Sony STR-DE595 5-Channel Amplifier
No sound from the amp.
The amplifier swtches on, but theres no sound coming. It's about 8yrs old, bought from Morkels. I took it to Earlybird where it was rejected 'cause they can't solve the problem. I just want to know where I can take it to or what to do.
  • Alan  Serna
    Alan Serna May 11, 2010
    is it sony?have you tried bringing it to its service center?is the speaker ok?
2 Suggested Answers
SOURCE: Not receiving sound output through amplifier with HDMI fitted!
go on to you'r settings and fix output to hdmi cable if you haven't done it already
Posted on Jun 05, 2009
I bought a new 1200 watt xplod amp and pluged it to a 1200 watt double coil sub with my alpine headunit the head unit is too old so i got a new xplod head unit but now i got a really freak low sound...
personally I would probaly contact the place where you bought the equipment, providing you have connected everything up correctly, it sounds like the amp is faulty
May 05, 2011 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Hi I just bought 1080 blueray recorder and 6500 samsung tv.hooked up dmi cables to tv to denon amp and blueray to tv .had great picture and sound from denon amp.now can only get sound from tv.not sure...
Check your Denon amplifier with other input such as, input from ipod sound to amplifier or any source that provides sound to your amplifier. If you have a built in tuner in your amplifier, Does the sound comes out? If it does then check your dvd setting, e.g 5.1 channel surrounding etc. If there is no sound from amplifier, check your amp with qualified service tech.
Jan 17, 2011 | Samsung Televison & Video
I JUST GOT A 98 CATERA , IT DIDN'T HAVE A RADIO IN IT , SO I ORDERED ONE OFF EBAY ,PUT IT IN ,TOOK TO DEALER TO HAVE IT UNLOCKED & PROGRAMED , AND IT COMES ON ,SHOWS THE STATIONS & THE CLOCK WORKS...
If the system you bought is marked BOSE, it does not have any onboard amplifier power. The only powered radios for the Catera are units which only have AM/FM/Tape, all the CD units are Bose systems which used separate amps mounted on a tray in the trunk.
Dec 28, 2010 | 1998 Cadillac Catera
My Jl Audio 500/1, power light comes on but no power to subs
maybe it dont have enough to push it ,,did you try it before you buy it?
Mar 01, 2010 | Jl Audio 500/1 Car Audio Amplifier
I just bought a 98 concorde lxi and no sound coming out of the speakers, radio comes on and shows channels just no sounds
Hello georgouseyes,
The problem could be in the output from your receiver to the amp or in the amp itself.
First check to see if the amp powers up. If it doesn't, check the main power fuse (usually located under the hood near the battery). Also check the power and ground connections on both ends.
If the main fuse checks OK, check both onboard fuses. There's 2 35A fuses on the far right.
If the amp powers up OK and the onboard fuses are not defective, it's possibly the output from your receiver or line output converter. Replace the RCA cables with a known good pair. If there's still no sound, I'd suspect that the amp itself is defective.
Hope this helps.
Oct 17, 2009 | Infinity 475A Car Audio Amplifier
I have a Kenwood KAC 6201 and I cannot get it to start!
Make sure you have voltage to both the main power input and remote. Without remote power the amp will not turn on. If you check with a light or meter and you positively have voltage to both power inputs and a good ground, and you still have no power, the amp is defective. I hope this helps...
Oct 17, 2008 | Kenwood KAC 6201 Car Audio Amplifier
My Alpine m450 amp light is on but no sound
make sure your RCA's are plugged into the input and not the pass through
Mar 28, 2008 | Alpine MRP-M450 Car Audio Amplifier
Over current light comes on.
Over-current lights are often caused by speaker wiring or impedance problems. If you're trying to use the amplifier in bridged mode to both subs, that may be causing the problem; re-wire the speakers so that each sub is connected to one amplifier channel. If you still get the over-current light, disconnect all speaker wiring from the amp and see if it still occurs. If it does, there's an internal problem with the amp. If it doesn't, then there's still a wiring problem with the subs. You may have a defective sub, or a speaker wire shorted against another wire or terminal.
Jun 23, 2007 | Sony XM-1502SX Car Audio Amplifier
Ultimate TA2600
If you took it to a shop, why didnt they troubleshoot the amp. Ihe amp is in protection mode because of a componet falure in the driver or output stage in the amp.
Aug 08, 2006 | Ultimate Sound TA2600 Car Audio Amplifier
Sony STR-DE595 5-Channel Amplifier Logo
76 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
