Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
What components does microsoft base its authorisation on?
I'm thinking of upgrading my computer, but keeping the hard drive. If I change my mainboard does this nulify my Windows activation?
  • 433 Answers
It should not- as long as you have the COA on the computer. Since you will lose the oembin in the BIOS you will have to activate your copy again. It will as you to put the 25 num/alph sequence in and of course not like them. then they will provide you with an 800 number to call- stay on the line until you reach India -you read off about 8 set of numbers they give you eight sets of numbers and it is activated.
I hope you purchase a dell, so you have a disc to work with. Most of the others just stuff it on another particition and tell you to make a copy.
Any who, that about all of the procedure you will endure. (it is a little more elaborate not much)
Posted on May 15, 2009
  • Microsoft Master
  • 1,183 Answers
Yes , if you change the motherboard it would nullify the activation . You can reacctivate the windows by putting the product key again.
In some cases and reinstallation of windows is required because of change in motherboard components and drivers. So before upgrading do back up all information from the harddirve .
Thanks
proton
How to Upgrade a Laptop?
Laptops are poor candidates for upgrades, as they are built with such tight confines as to make many parts rather inaccessible. For the normal laptop, there are only three things that you may consider upgrading, and the CPU is not one of them. CPUs are often hard installed on mainboards and the BIOS in the mainboard is often customized for a specific one. Even where you may be able to upgrade, the upgrade option is usually not of sufficient difference to make the cost and effort worth it. You can usually upgrade the hard drive to something larger in capacity and faster in speed. You can upgrade the RAM to the maximum that the laptop allows (most do not come with the max originally to keep the cost lower). You can upgrade the Operating System and software when applicable for better performance. Graphics upgrades, for the most part, are not available, except maybe for some of the newer, higher-end gaming laptops. Most have the graphics integrated into the mainboard and most graphics share the system RAM. Hard drive and memory upgrades can usually be performed thru access doors on the outside of the case. I've seem a few instances where one of the memory modules was tucked internal to the device and it was necessary to remove the keyboard assembly to access it. I've never seem a laptop with more than two memory module slots.
Oct 18, 2016 | Computers & Internet
Upgraded motherboard and windows 7 in restore during startup
If you put in a hard drive that already had an OS on it and such, it won't work since the new computer has different parts from the last. You will have to buy Windows 7, or obtain windows through some method of your choice and do a clean install. Sorry buddy.
Feb 21, 2013 | MSI B75A-G43 Motherboard
Errror 85
How to fix the System error 85 has occurred?One thing to mention is that even though you may be mapping some drive letter to a network resource, the same drive letter for other Terminal Services sessions may work as expected.
Use another drive letter...
Another point is that a different drive letter that is not typically used also works as expected. If it is feasible for you, use different drive letter when mapping to your network resource.
Restart Terminal Services-based component...
If using another drive letter to map your network resource is not an option, you can try to correct the issue by restarting the Terminal Services-based component.
Restart Terminal Services...
Another way to fix the problem is to restart the whole Terminal Services service. You can do so by executing the following steps:
-> Go to the Start Menu
-> Run
-> Type services.msc and hit ENTER
-> Locate Terminal Services
-> Right click it and select RESTART
This should break the connection between the Terminal Services and the resource and make the network drive letter available for your use.
Upgrade Windows...
The good news is that some attempts have been made by Microsoft to handle this error message and the underlying causes by Windows. The System error 85 has occurred was often visible in Microsoft Windows 2000. The Service Pack 3 and Service Pack 4 include some fix for this.
Sep 06, 2012 | Foxconn Computers & Internet
Memory full and slow
If you go into your control panel and click on system, you will be able to see how much memory you have. www.crucial.com is a free program that you run and it will also tell you and then let you know how much memory you can upgrade too.
Mar 19, 2011 | Computers & Internet
Sir I bought Dell Optiplex GX 260 1.8 GHZ, 256 Ram 400 Bus speed 20 Gb hdd machins working very very slow and take more time (4 houre ) for reisntall Windows Xp ser pac 2 how can speed up my...
You can upgrade a PC but in my experience it is far better and is more cost effective to purchase a faster PC. Here is what you do, save all your personal important information from it's hard drive onto a USB flash drive. Now sell this computer and then using the money that you would have used to upgrade it buy a new computer.
You don't want to go lower than a single core 2.4GHz with 512mb RAM. However I do reccomend an AMD computer system. See if you can afford an Athlon 2 X2 250/255 they are very good and don't cost very much. Of course you will need to purchase new components, either from a local computer shop or on the net.
If you want to try to increase the speed of your current PC then you will need to upgrade the RAM to at least 512mb, make sure it is DDR400. The next thing to upgrade is the CPU, I think it is socket 478 so it might fit a 2.4GHz socket 478 CPU must check CPU and mainboard is the same socket or it will not work.
damnor01
Nov 13, 2010 | Dell OptiPlex GX260 PC Desktop
My gateway essential 400 cant run newer programs **** *** window 7... or explorer 8... or flashplayer 10... how can i upgrade my computer 2 make it run these programs ? a new hard drive ? or what do i do...
You can add hard drive if your system doesnt have enough space for the new programs. If the new programs installs well but is running slow or not starting, then you will have to upgrade your RAM and for better performance, fix one graphics card suitable for *********** board. If you can spend more, Upgrade *********** board and processor.
Thanks
Sherbaz
Sep 20, 2010 | Gateway Essential 400 PC Desktop
Have upgraded my computer from Microsoft Me to
If you have installed on an old computer then the amount of space required may not be enough due to the size of the hard drive. To run modern software etc. you will need at least 350Gb hard drive and run 2 to 3 Gb of RAM. And as systems move on these requirements will only get larger. If you have an old system you want to continue to use I would recomend using a LYNUX based program like DSL (Damn Small Lynux) download for free and can be run from a CD, freeing up more space on a small drive. Hope this helps ;)
Apr 15, 2010 | Husqvarna Rose
General Hardware Question
What is your question? No, these components are not integrated, but everything is attached. If this person cannot find this out for you, do not trust him to upgrade it.
Apr 01, 2009 | Toshiba Satellite A135-S2386 Notebook
Overcoming the 137GB barrier on a hard drive
*********** board have no support LBA 48bit adressing.
If you want to use so big HDD, you must to upgrade bios (for LBA 48 bit) or change motherboard for new one.
Mar 30, 2009 | EliteGroup ECS L4VXA2 (CDL4VXA2)...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
