Question about Intex Pool & Spa
Threw away old pool liner and forget to remove parts
We have a 15 ft x 48 intex we had to buy a new liner and forgot to take the parts off the liner and we got a new liner and have no clue what connectors we need or parts. specifically the hose connectors to hook up to the pool. If I knew what we needed I wouldn't have to ask lol, so I am hoping someone can help us thanks
  • 323 Answers
Patchy,
Click on this link and it will show you every part made for your pool. Good luck,
Sirwriter
Posted on May 16, 2009
How do I fold my intex 15' X 36" round pool liner to put away for the winter?
fold carefully youll never get back in original box wrap in a tarp
Sep 17, 2014 | Intex Easy Set Pool 15x36
What would be the best automatic pool cleaner for intex 18 x 48 easy set
the vacuum you are using is probably the best for the system you have. if you want a REAL pool vacuum, get a REAL pool. there is a reason that these are considered disposable pools. dont get me wrong, any way to cool off is great and these pools allow people this 'luxury' at a reasonable cost but they are assembled with low end, non standardized equipment that doesnt match with traditional pool equipment.
Sep 09, 2014 | Intex 18 ft x 48" Easy Set Inflatable...
try to get the vacuum that works with the garden hose they work ok for the small pools
How many gallons of water the intex 15x36 pool holds?
Depends ... 15 feet round? 36 inches deep? = 3976 gallons
15 feet by 36 feet rectangle, how deep? if 5 feet deep = 20,250 gallons
Hope this addresses your question.
Thanks for your interest in FixYa.com
Jul 10, 2011 | Intex Easy Set Pool 15x36
15 by 48 pool i upgraded the filter too the 2500 gallons per hour and saltwater system cannot fit the in and outtakes throught the pool liner what do i do
Get replacement ports of the proper size from your pool supply house. Dont use adapters as this constitutes a restriction and will lead to troubles. If you cannot find the correct diameter - I suggest you add a second suction and a second discharge of the size you can get and pipe them together outside the pool ... put the two suctions/dischargees on a pipe that will fit your new pump.
Aug 06, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Intex changed product materials of pvc pools
You would think that two tarps would be enough, lol
I would get weed killer and kill the grass or put sand over it. the last suggestion is diggin it up and then putting sand over it to level it back up.
Please rate and let me know if it helps.
thanks and God bless
Jun 25, 2010 | Intex "" Metal Frame Pool Set (56998e)...
How deep can we dig for oval deep-end pool
This blog has information about sinking an above ground pool. It is normally recommended that you do not sink the pool entirely into the ground becuase of pressure concerns and the risk of collapse. Generally, you leave 1-3 feet of the pool above the ground and install a deck or similar feature to make the pool appear to be in the ground. The type of pool liner that you have (expandable) is best for this practice, but it can be done with overlap or regular beaded liners also.
http://backyardcity.wordpress.com/2009/06/02/the-above-ground-pool-goes-underground/
May 08, 2010 | Intex 18 ft x 48" Easy Set Inflatable...
I have a 15 ft by 48 inch intex pool and i just
The most obvious thing besides not having salt in the pool has no stabilizer in it. This is a chemical that has an affinity for chlorine ions and if it is not there the chlorine can be disipated in a few hours when the sun hits it. Another name for it is Cyanuric Acid. It can be purchased in granular form at many pool supply stores or in a liquid form at Leslies. In order to get your pool blue you need to have the chemistry checked at a pool store or with a test kit (either liquid or strips). Don't buy everything a pool supply tells you to buy but start out with vinyl safe shock, stabilizer and salt. The pool store should be able to help you determine the dose. The following is what I would do:
1. Make sure salt is at the recommended concentration.
2. Shock the pool to recommended dose to start killing the algae.
3. Place the recomended dose of stabilizer in the pool.
4. Make sure pump and filter are working properly.
5. Check the pool chemistry on a daily basis until it is ready for swimming.
6. Check the chemistry on a weekly basis and clean the pool and equipment according to the pool instructions.
Smile, you are a pool manager.
Aug 10, 2009 | Intex Automatic Salt Water System for ...
I have an intex 15 x 48 pool. The old pump wasnt
check the intex site for adapters and other parts you might need.
I don't think you should buy new pool .
Jun 28, 2009 | Intex 4000 GPH Filter Pump
Pool & Spa Logo
131 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
