How do i get to the aux channel on a Sansui TVM131AD
I want to play my video game on the tv but the aux channel comes up when you press a button key on the tv and i dont know which ones to press to get to the aux channel also i dont have a remote.
i'd all ready tried channel set up
    Sergeant:
  • 273 Answers
If your tv doesn't have an AV button either buy a all in 1 remote or a RF cable compatable with your game console and tune the tv manually as you would tune tv stations
Posted on May 15, 2009
When I try to play a cassette the cassette clicks on and turns normally. However, all it transmits to the TV is wavy lines and no picture of sound. The TV does not show the play, stop,etc. indictators when...
The TV channel should be set on Chanel 3 or Chanel 4.
Use the remote control of the TV to set it.
You can also use the AUX ports (to TV) on the VCR and connect the three wires to the AUX ports on the TV (TV input). The two audio wires are to be connected to Audio in and the Video signal to the Video input.
If you get a garbled picture you can use press the tracking button on the VCR. Usually you press the Channel Up arrow, or Channel Down arrow to adjust the picture.
Dec 22, 2013 | Goldstar Televison & Video
I can;t find the channel so i can play video games
Try pressing the input, game, or aux button on your remote. If that doesn't work try a channel like 2, 3 or 4.
Feb 28, 2010 | Symphonic ST420FF 20" TV
Input select sttting
Normally, your TV or VCR is probably set to display the television channels you watch, through a standard cable input. In order to play your Nintendo using the A/V cables, we need to tell your TV or VCR to switch from the normal tv channels, and instead display the signal coming in from the A/V cables of your Nintendo system. There is no one particular way to do this, as it varies between brands, but below is some information that may help.
Quick Tip: Grab the original remote control for the TV or VCR you have plugged your Nintendo into, and look for a button that could be labeled:
  • TV/Video
  • Input Select
  • Line or Line In
  • Source
  • AUX (auxiliary)
  • EXT (external)
  • any other button that seems to indicate it would switch between the TV signal and the game system.
If the above tips did not help, it is possible your Input Select is a little more difficult to locate. Here are some other common ways to access an Input Select:
  • A button on the front of your TV or VCR located behind a door or a hidden panel, or located on the original remote control that came with the device. If you are using a universal remote, it may not work when pressing the "input select" button. If it does not work, try to locate the original remote.
  • A high or low end channel. Try channel surfing through every channel, even the ones that do not normally broadcast a TV show. Many times the input select is a high channel such as 90, 91, 92, 93, 99, or even 999. You should also try low channels such as 0, 00,001, 1 or even 2. For some televisions, you may need to manually select these channels by using the keypad on the TV or remote control.
  • Found within an on-screen menu. Search the menu for words such as Input, Setup or Source. Select one of these words, and another menu will usually appear that asks you to select between TV and either AV, AUX or Line. Select AV, AUX or Line to display the Nintendo game.
If you are still unable to find your input select, you may want to consult the operation manual that came with your TV or VCR, or contact the manufacturer directly.
Nov 19, 2009 | Nintendo Wii Console
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How to switch to dvd mode
If you can provide the RCA remote model # I can be more specific (it should be located on the back or inside battery case.
Anyway depending on whether your remote uses 3 digit codes or 4 digit codes the Sansui TV code is usually 191 or 1191.
  1. Press and hold the TV button on the remote. LED will stay "ON".
  2. Enter the code for your brand of TV into the remote while continuing to hold the TV button down. LED will go out during number entry and turn back on when the last digit is entered.
  3. Release the TV button. LED will flash and go out if number is entered sucessfully, or flash 4 times if it detects an error.
  4. Press Channel up or down to see if this has worked.
You can also use the code search function.
  1. Turn on the device you wish to control.
  2. Press and hold "CODE SEARCH".
  3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
  4. Release "CODE SEARCH".
  5. Press ON/OFF repeatedly until the device turns off. You may have to do this up to 100 times.
  6. When the device shuts off press and release ENTER.
  7. Try using the remote. If it does not function repeat steps 1 through 6.
Mar 21, 2008 | Sansui H TV2600 TV
I cant get aux on my symphonic tv to play
Try Channel down from 2 or up from 99.......T.
Jan 22, 2008 | Televison & Video
No Aux Channel but I have the yellow and White plugs in the front!
Take out the channel up button and use a small, long object (like a pencil or pen) and repeatly press the button under until AUX comes up.
Nov 21, 2007 | Orion1934 19" TV
Aux channel
Press channel down until you get to channel 1 then press channel down one more time ,this should give you your AUX.If it doesnt try going into the menu and doing an autoprogram with the video game hooked up and turned on.
Nov 08, 2007 | SansuiM1315 TV
Televison & Video Logo
242 people viewed this question
Top Televison & Video Experts
Electro Med Services...
