Question about Phase Linear PCD120UCS CD Player/Receiver With Detachable Face
I have a Phase Linear BT1611 MP3 WMA Receiver without the manual and would like to know how to use the blue tooth. I don't have the code so what code could I use? Also I need to know where to go and down load the manual
4 Suggested Answers
SOURCE: Jensen Phase Linear car radio
Take off the face plate and it is located in the lower left corner
Posted on Mar 31, 2008
SOURCE: phase linear UV7i makeing the dvd player without useing parking
There is a pink wire that goes to the parking brake. It connects to the ground wire on the parking brake that makes the brake light come on the instrument panel.
connect the pink wire on your stereo to a frame ground.
Posted on Dec 28, 2008
  • 69 Answers
SOURCE: I need the code to disable to parking break to
you will need the remote control to do so.
1.turn the radio on and select the setup menu.
2. while in the setup menu, use the remote and press 5-4-3-2-1-0, this should access another service menu.
3. from there, you will see a brake override option.
4. and your done.. hope this helps
Posted on Aug 17, 2009
Testimonial: "worked like a charm. thanks much for the help!"
Free manual for mosfet phase linear upa424 240watt amplifier
You do have 12 volts connected to the remote connection, correct?
Dec 11, 2013 | Phase Linear UPA424CS Car Audio Amplifier
I have the phase linear UV7i I was trying to put in the overide
reset it,try with out the remote and change the remote battery,put in dvd wait for the blue screen,then press stop 2x then enter 1264 then,if you have a up,down,l/r control on the deck press down 1x then press play,you dont even have to use the ground wire then go to the rest, when you can see the menu,i dont know if it will work but u can give it a try
Jun 18, 2009 | Phase Linear UDV9010 Car DVD Player
How do i get radio station name instead of frequency numbers p9800bt stereo thanks
Here's a link to the manual, all you need will be in there.
http://akamaipix.crutchfield.com/Manuals/130/130DEHP980.PDF
Jun 12, 2009 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
No cd audio from my phase linear uv8
It sounds like you have a factory amp in the vehicle. Check behind the radio to see if you have the blue wire from the deck hooked up to anything. You probably do. So take the blue with white stripe wire coming from the deck and hook that up instead of the solid blue wire.
Jan 20, 2009 | Phase Linear UDV9010 Car DVD Player
Want dvd to play while driving its played before i hit reset button now it does'nt play
You need to hook up the pink wire to a power wire. I myself have a switch in my cig outlet (which ran blue lights i had inside my car) running it so if i ever got pulled over i just pull out the switch and they cant prove i was playing a movie.
Oct 19, 2008 | Phase Linear UDV9010 Car DVD Player
Setting stations
The only way I know how is to use the remote. Manually set your station using the multi function button(the larger round one). then press and hold one of the number buttons on the remote until it beeps. Usually two seconds. your station should be set. Then adjust and repeat.
Aug 09, 2008 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
Pioneer DEH-P9800BT with Nokia N95 8GB via Bluetooth
Sometimes the call is diverted to the phone, so the deck stops playing. Happens to me too
Jun 20, 2008 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
Mar 17, 2008 | Phase Linear 160W AM/FM/CD Receiver W/...
Car Audio & Video Logo
405 people viewed this question
Top Phase Linear Car Audio & Video Experts
Lyle Siemens
Lyle Siemens
Jaime Hernandez
The Audio Lab
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
