Question about Maytag Performa PAV2200
Spin cycle The drum keeps banging all over the place in washmichine during spin cycle
  • rbtmr Nov 09, 2007
    drum rattels very during spin checked spring,tub and shaft everything looks fine. I have a maytag performa washer.
  • 240 Answers
This is a repeat, but maybe the same result.  Remove the front cover (usually two clips between the top and the front, move it around) and check each of the springs that hold the unit to the base.  Have found that just one spring would cause a out-of-balance condition.  When you open the lid, does the basket seem to be leaning one way or the other?  If so, look on the side that shows more than the other.  Also, reach in and grab the inner basket to see if it seems loose.  Have had the basket drive mount break halfway through and caused it to roll really bad.  Let me know what you find out, or if you need futher help.  Jim
Posted on Oct 18, 2007
My kenmore 417 wahser making too much noise, it looks like the inner tub hitting the outer plastic housing. How can I fix it?
Have you tried moving the clothes around in the drum to balance the drum BEFORE you was them? If that works, you have solved the problem! Most people forget that when cloth gets wet it gets heavy so leaving the clothes unevenly placed in the drum dry will make a real problem when they get wet!
Dec 26, 2012 | Kenmore Washing Machines
Kenmore 43142 front loader bangs during spin cycle any ideas on what the problem might be?
always check the load to the drum is not to heavy on one side, this could cause it to bang.
Aug 25, 2012 | Kenmore Washing Machines
Whirlpool Duet Washer Model WFW9400SZ00 bangs only during spin cycle.
Yes you are exactly right, these bearings have failed & are causing the noise very common problem with whirlpool front loaders. very expensive to repair worth while looking into replacing instead of repairing as it will just happen again.The new LG machines are the best in my opinion.
Feb 06, 2012 | Whirlpool duet Washing Machines
The washer shakes uncontrollably during the spin cycle also a loud banging noise is heard during the spin cycle.....
If front load check the inner drum If it is loose at all you have a lot of problem . Very expensive.
Nov 17, 2010 | GE Washing Machines
Loose drum bangs during spin cycle turn by hand with nothing in drum and still bangs?
your front drum support blocks have failed. remove the tub and, replace or, rebolt them in place so they hold the drum front in place.
Jan 25, 2010 | Frigidaire 14 Cycle Tumble Action Washer
GE WSXH208A makes a lound noise during the spin
check to see if the washer is balanced (cloths are evenly placed in drum) if it sounds like banging noise
Jan 20, 2010 | Washing Machines
In spin cycle, there is a loud metal on metal sound. could it be a bearing going out? the machine still spins but much slower, and the banging sound occurs in one place every revolution during the spin...
Hi
Remove the drum belt, and spin drum by hand.
If it feels rough, or it is noisy, then drum bearigs have failed.
Please rate my solution.
thanks.
Jul 24, 2009 | Whirlpool Washing Machines
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
Dec 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
125 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
