Question about Dell Inspiron 6400 Notebook
Facing problem with battery of Dell Inspiron 6400
Facing problem with battery of Dell Inspiron 6400 getting message system cannot communicate with the battery
  • Dell Master
  • 1,183 Answers
1. Shut down the system, remove the battery and the Ac adapter from the computer.
2. Press the power on button for 10 seconds
3. Reinsert the battery
4. Power on the computer and as soon as you see the dell logo press the f2 key a couple of time
5. Using the up down arrow keys , go to the option that says battery info. If there is an error message listed kindly post it back
6. Otherwise shut down the computer reconnect the ac.adapter and check if the problem is solved
Also the battery has a diagnostic lights on it , remove the battery from the computer and press the button on the battery a set of lights would glow. If they are steady and come in a series the battery is good , If some lights are missing the battery is bad and may need replacement
Thanks
Proton
Posted on May 15, 2009
I would like to get a password to have access at a BIOS Dell Inspiron 6400.
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-6400-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Jul 14, 2011 | Dell Inspiron 6400 Notebook
I have "INSPIRON 6400" and
The best and cheapest solution is probably for you to purchase one of the aftermarket batteries you have been researching. While they may be physically compatible, original Dell components are often designed to identify themselves, and they tend to resist being mixed-and-matched. Aftermarket manufacturers have developed strategies to avoid the authentication process.
Before you give up, though, be sure to try this trick: simultaneously press Fn and either F2 or F3 (which ever one has the battery icon printed on it). If you've unwittingly pressed this combination, you may have disabled the charging process. Try it with BOTH batteries--the battery that originally shipped with the Inspiron 6400 may not be dead after all!
Mar 27, 2011 | Dell Inspiron 1525 Laptop
Using Dell laptop Vostro 1500, but battery cannot communicate with the system
There might be a possibility that the battery is not making good contact with the laptop's charging circuitry. To eliminate this possibility as a root cause of the battery not charging, turn off and unplug the laptop, take the battery off the laptop, and using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self. When done, put the battery back into the laptop, plug it, and turn it on.
Oct 24, 2010 | Dell Inspiron 6400 Notebook
Multiport communications port(COM4)
Unless it's affecting something directly you can just leave it be. It's probably just a simple driver issue.
If you do in fact want to "fix" the problem I'd start with just uninstalling the device in the device manager and then reboot the computer.
Did you recently re-install windows? When did you notice this problem?
Nov 28, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 freeze after startup
do a system restore before it started doing it.
Nov 08, 2009 | Dell Inspiron 6400 Notebook
Dell Latitude system cannot communicate with battery
may be some failure in os re-install and try it again if he problem is still their check the battery with other similar laptop or your battery sensor inside laptop may have some problem take it to the service center
Oct 19, 2009 | Dell Inspiron 6400 Notebook
DELL LAPTOP INSPIRON 6400 MY LAPTOP BATTERY IS SHOWING STATUS ( UNKNOWN ) ON WINDOWS & ON BIOS IT SAYSS BATTERY NOT INSTALLED
Here are my recommendations for this issue:
1. Reseat the battery.
2. Remove All External Components
3. Check the battery connectors on the battery and the system. Examine the connector on the battery and the system. Make sure that there is no physical damage and that it is clear of debris.
4. Remove All External Components
5. Try a known-good battery in the system, if available.
Jun 09, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 system responding very slow on ac adaptor
FIRST REPLACE YOUR BATTERY, THEN ALSO CHECK VIRUS WITH AN UPDATED VIRUS CLEANER.
Nov 20, 2008 | Dell Inspiron 6400 Notebook
Power problem
i think this is battetry r adapter problem
Oct 23, 2007 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
516 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
