Question about Performance Teknique ICBM-2400 Digital Monoblock Car Amplifier Car Audio Amplifier
What should the subsonic filter be at
Should the subsonic filter stay off on the performance teknique amp
  • 221 Answers
The subsonic filter is to help your system's overall performance by blocking frequencies that your subwoofer cannot effectively produce. For example, if you have a single 10 inch sub, it's not likely to be able to produce sound much lower than 60-80Hz with any respectable volume. If you have the subsonic filter on and set to 60Hz, it will prevent a 40Hz tone from being delivered to the sub. If the subsonic filter is turned off, your sub will get everything, and it will try to produce every sound. If it gets a 40Hz tone, it will make the sub work extra hard without any audible noise. It'll just degrade the overall so the answer to "shoud the subsonic filter stay off" would be "it depends on your system" but in most cases, you should keep it on, and set it to the low end of your subwoofer or woofer range. This also applies to filters on mids and highs.
Posted on May 15, 2009
What size amp should i get for performance teknique sub-woofers
the amp you have will do the job depending on how may ohm you sub is and can you amp stable to handle low ohm's. you should also check your cabling to make sure its for about a 1500w amp so you dont lose any power
Sep 17, 2009 | Nitro BMW-482 Car Audio Amplifier
What is the subsonic filter for?
Hello luckybear22,
The simple answer is that a subsonic filter prevents frequencies below the threshold of hearing, hence subsonic, from being sent to the subwoofer. Such frequencies result in a loss of available amp power and in the extreme can even damage the speaker.
Hope this helps.
May 15, 2009 | Performance Teknique ICBM-2400 Digital...
What is the subsonic for on the performance teknique amp
The subsonic filter is used to filter out the bass that is too low for the human ear to detect or hear--remember the lower the frequency or bass note that you try to play the harder the amp has to try to reproduce it-so by filtering out the bass that you cant hear it saves life on your amp and subs and your not missing anything anyways cuz ya couldnt hear it to begin with.
May 14, 2009 | Performance Teknique ICBM-2400 Digital...
I got a performance teknique power amp its 1700 rms at 1 ohm i need 1500 rms at a load of .67 will be ok
No, with 1700watts at 1 ohm the max current is 41 amperes, with 1500 at 0.67 the currents is almost 48 ampreres, you will be overdriving the amp at signal peaks.
Apr 08, 2009 | Performance Teknique ICBM-782 Car Audio...
Performance teknique icbm-896 stick on diagnostics
If it's in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Sep 10, 2008 | Performance Teknique ICBM-896 Car Audio...
Performance Teknique ICBM-9550 Amp Problem.
one of the power transistor of your unit shorted check use a tester
Aug 27, 2007 | Performance Teknique ICBM-782 Car Audio...
Car Audio & Video Logo
146 people viewed this question
Top Performance Teknique Car Audio & Video Experts
George Nalley
Level 1 Expert
Radames Pagan
Radames Pagan
Jose Velazquez
Jose Velazquez
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
