Question about GPX PD808B Portable DVD Player with Screen
Goes between play and backwards
I have a GPX PD808B when I insert a disk it comes up with Invalid Key... then it loads the disc, displays "Play" and then it displays "Backwards 2x", "Play" and so forth. If I hold the play button down it will play just fine. As sson as I let go of the Play it will go backwards 2x, 4x 8x and 20x pending on how far back it has to go to get to the next scene.
  • GPX Master
  • 3,866 Answers
This need arepair as the controller board is giving out there is not much we can do here but send you to a GPX autherized repair to have it fixed but these things beeing so cheap now days I would just go to best buy and they will recycle this old one give you a gift cart for whatever amount they think its worth toward a new one..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 15, 2009
Portable GPX 931B dvd player, comes on, load disc, then displays wrong region, will not play the dvd.
Does this happen with every DVD you try to play?DVD's are often manufactured for different regions around the world.
Oct 30, 2013 | GPX Pd931b 9" Portable Dvd Player
E disc it doesn't rI have a gpx DVD player D200B and when I insert thecordnize it. Says
see the next remedies:God bless you
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours
Jul 21, 2012 | GPX Televison & Video
Audio no picture
do you get a splash screen when there is no Disc playing ( something that says something like DVD VIDEO). If not and the scren is just always black then it sounds like the backlighting circuit has failed
Mar 17, 2010 | GPX PD808B Portable DVD Player with Screen
Dvd player does not recognize the disk
If it was a home made disk then your problem is not with the player but with the burning software and or method used used.
If it however does not play a store bought dvd then there will likely be an issue with the player itself
Aug 17, 2009 | GPX PD808B Portable DVD Player with Screen
After loading, disc error is displayed when dvd is inserted
hello i have had the same problem this maybe because of the region that your dvd is made to play.different dvd players play different.region dvd the regions should be on the dvd and the dvd cover.
Apr 25, 2009 | Televison & Video
GPX portable DVD model PD808B - wrong region message
Turn on power. Open lid. Enter 9735 with the remote and press 'enter', you can now choose between regions on the screen. Select the desired region unlock and press 'enter'. This works well!
Benony Jonsson
Feb 20, 2009 | GPX PD808B Portable DVD Player with Screen
Disk rotating and a message "invalid disk"
you can try manually cleaning the laser lens ( gently wipe , do not press down hard , it is suspended by fine wires ) using a q-tip and a drop of that cleaning solution you got with the laser lens disc. ( fluff another q-tip a little ) then dry wipe it with another q-tip and try a disc.
you can look at the laser lens and see if you see the laser come on also to determine if that is working ( do not look directly into the laser ! )
if the laser works but it still does not read discs after cleaning it manually , then there is a problem with the focus coil on the laser or the signal board is bad
Jan 10, 2009 | Coby DVD-211
GPX PD808B Portable DVD Player with Screen Logo
116 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
