My verbatim 1tb external hardrive when i plug it into my laptop says device is malfuctioning and when i plug it into my desktop it says its installed but nothing shows up at all need some help
  • Chris
    Chris May 11, 2010
    With both units unable to access the drive chances are you either have a failing drive or a failing enclosure.
    I would be happy to help you diagnose either problem. Let me know if you have small hand tools and a spare cable to connect the HDD from inside the shell onto another computers motherboard, or a spare shell on hand.
    Chris
  • 3,866 Answers
You can tske this out of its case and install it into a new case, I may have chatted with you before so just in case its the little board inside that has given out the drive is fine!!! But go get a enclosure for it you be glad you did please rate this solution thanks
Posted on May 15, 2009
Verbatim 1tb external hard drive turning on
Make sure the appropriate drivers are up to date:
http://www.verbatim.com/index/support.php?lang_id=1&cat=9&section=
Try different ports on your machine, reboot your machine, try connecting it to a different computer if possible.
Type in diskmgmt.msc into the search bar, and see if the drive shows up here at all. If it shows up, but doesn't have a drive letter right click and use the assign drive letter option.
Contact verbatim for a replacement cable.
May 29, 2013 | Computers & Internet
Verbatim 1tb 3.0usb hard drive bring up blue error screen when attatched to laptop. Any suggestions?
It has to be something about the speed or the size ..also take a look into its properties and see if it has the possibility to be limited to run on usb 2.0 ..or install the usb 3.0 into the laptop ..This can be the issue it makes it get into error ..I can see no other reason ...maybe the operation system too ..If you have the possibility try to reinstall the laptop ..maybe something on the operation system does not support the hard drive ..(try to install widows 7 if it supports it ..and see how it works after .
Dec 20, 2011 | Verbatim Desktop, USB 3.0, 3-1/2", 1TB,...
My Verbatim model #47512 1tb makes this beeping sound every time i connect it to my computer why?
That beeping signals a failure to communicate between the disk and the motherboard of the pc - the disk is defective. You have a slim chance of recovering what's on it by removing the actual disk from the external case and plugging it in the a desktop.
Jun 09, 2011 | Verbatim 1TB USB2.0 HDD USB 2.0 Hard Drive
When I plug my 1TB WD external hardrive into my laptop the light with the lock on it lights up and my laptop doesn't respond to it at all.
It says it is password protected...
U need to unlock the HDD from the computer which was installed initially...
U need to unlock the drive with the help of the password that is used in the software supplied along with it....
Dec 08, 2010 | Western Digital My Book Essential 1TB...
Verbatim 1tb external hard drive malfunction error message
Try changing the USB cable that connects the hard disk to the computer, this message usually comes when the cable is damaged.
Dec 14, 2009 | Computers & Internet
1tb Verbatim External Hard Troubleshoot
does it work on another pc ok? Do other usb devices work ok? Give me the details and I can help you solve this.
Paul
Aug 08, 2009 | Verbatim VER95327 USB Hard Drive
External hardrive not being reconized by computer
There's are a couple of registry patches for Window's users for unrecognized external devices. Install the patches from the links below.
http://support.microsoft.com/kb/925196#fixit4me
http://go.microsoft.com/?linkid=9643528
For the above link, click on the "Fixit" box to install the patch.
Jul 04, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Lacie 1tb external hard drive into ps3 is not regconised
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone.
Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
Jun 07, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
External hard drive doesn't respond
Shut your computer down. Disconnect you external hardrive. Power up your computer again. Power up the Verbatim and then connect to a USB port. You should hear a very quiet 'ping'.
Go to My Computer, and the Verbatim should be showing as one of your drives (probably Drive D). You should be able to open it from there.
Make sure that you have a Desk Top Icon for opening the hardrive, it makes it so much easier. Hope this helps
Jan 25, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
