Question about Samsung LNT4669 TV
TV selection button on remote is broken and lost
TV button broken on SamSung Remote
  • Samsung Master
  • 3,866 Answers
A replacement remote for that tv at www.remotes.com will help you in this manner
or call 1-800-remotes they will find you a factory remote as they have them and you be glad you did.
Posted on May 15, 2009
We have a Model un40eh5300fxza tv, where on the remote is the OK button
    images for where on the remote is the OK button
    More images for where on the remote is the OK button
    RC: Tv code so i can use ok/select button on comcast remote
    www.remotecentral.com > ... > Consumer > Original Equipment Remotes
    Mar 3, 2010 - 13 posts - ‎7 authors
    I have the comcast dark grey remote and a vizio lcd tv .when i press the tv button i then can press the menu button it brings up my tv menu and ...
    Button Functions by Remote ' MyDISH ' DISH Customer ...
    https://www.mydish.com/support/.../remotes/button-functions-by-remote
    Register, Button, Button Sub-Category, Function, Condition ... on screen menu/pop-up, -. 2, Color Buttons, -, -, Function varies by screen and customer selection.
    Select/OK button doesn't work when Using Comcast remote with ...
    www.avsforum.com/...remote.../1533595-select-ok-button-doesn-t-work...
Jan 07, 2016 | Samsung Televison & Video
Need code for sky remote control for samsung model ps51d450 51inch plasma tv
Hello
Sky remote codes for Samsung TV are:
065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088
646
672
642
Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 30, 2011 | Samsung Televison & Video
I can't control the HT-C6530 unit with the remote. The remote is controlling the TV instead of the samsung HTS and i can't seem to switch it back. Seems to be something to do with the BDReceiver/TV button...
hi,
press bd receiver / tv button to select the remote for any one. u can use the same remote for tv and blue ray receiver. when u want to control blue ray with the remote, select remote for the same by pressing bd receiver / tv button and wise versa.
ok
Dec 27, 2010 | Samsung HT-C650W Theater System
Samsung Remote Control not working
any samsung remote will work any samsung television. Samsung use the same code for all television's as do Sony
Samsung remotes are quite expensive you could always buy a Sky digibox remote and tune that in to work you tv that would be a cheaper option.
how to tune in the sky remote to work your samsung tv
TV,
RED + SELECT ( blinks twice)
TV,
0060
TV,
SELECT.
Job done
Hope this helps you out.
Cheers
Little Dish Fitter
Sep 02, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Remote tv compatible codes
the default for the rh7823w remote is to operate lg tvs. Popping out the batteries should reset the default. my manual saysto select a different tv hold down the tv power button, press the number buttons for the manufacturer code then release power button.
codes are
LG/Goldstar 1(default), 2
zenith 1,3,4
samsung 6,7
sony 8,9
hitachi 4
good luck
Apr 04, 2009 | Televison & Video
SKY REMOTE
Press TV
Press and hold Select & Red until the LED blinks twice
Press TV
Type in code 0 0 6 0
press the Power button on the remote, if the TV turns off press the select button and everything should work, if the TV stays on press the TV button on the remote then the Power button again, keep doing this until the tv turns off, when it does press the Select button and all should be ok.
Feb 01, 2009 | Toshiba MR120 Remote Control
Sky remote code fo LCD LE40A456 TV
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Jan 26, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Configuring Sky remote
3. Press tv again
Samsung Code: 0060
Sep 20, 2008 | Samsung AH5900092W Remote Control
Sky remote tune to samsung
3. Press tv again
Samsung Code: 0060
Aug 13, 2008 | Samsung WS32Z308P 32" TV
Samsung LNT4669 TV Logo
79 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
