Question about Microsoft Windows XP Professional
My monitor displays no signal, i tried to tighten a display cable but the problem persit, i put my monitor to another pc it works fine, later i decided to remove the ram and see if the computer will alert with the corresponding beep, forunately it does then I re-inserted the ram to another bank slot and swith on the pc. Oh my monitor displays as usual ! Basically I don't know what causes that problem ?
  • 291 Answers
If you have a built-in video adapter, that is, installed on the mother board, you will be having no way to fix it, but in the hands of the computer aided soldering machine that can remove it and solder it back, or in the hands of a young technician whose hand is not shaking, just buy new one and insert it to the spare slot that the mother board provide you with expansion. But make sure to remember this, select with the two slot, PCI or AGP. PCI is automatically installed, and AGP, before you can make it work, you need to install the driver and enable both slots on your CMOS setting.
good luck.
Posted on Nov 03, 2014
  • 173 Answers
Hi! In your case, if you already check all the connections, the problem is in the display card adapter pls check your VIDEO card if its properly inserted, if it does. Then you have a defective video card. GOOD LUCK thanks
Posted on May 15, 2009
It was working fine yesterday. Today is states VGA no signal. What is the problem.
A number of things can cause "No Signal" on a monitor
1) Check the cable between the monitor and PC is properly connected
2) If the PC has more than one display port try changing the display port the monitor is plugged into
3) Try an alternative cable between the monitor and the PC
4) Check that the correct input is selected on the monitor
Dec 17, 2010 | HP w17e Monitor
LG LCD Monitor won't exit Power Saving Mode
Does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your LG monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PCs video card/motherboard, not the monitor.
Hope that helps. Good luck
Feb 15, 2010 | LG Computers & Internet
What does the red light mean next to the power button?
The red light next to the power button is usuall the hard drive led which should blink every time the hard drive is in use, there is normally a green or yellow light for the power that shoukld stay on constant when the computer is on.
Feb 09, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
No display no beep sound
you need to check your memory RAM of your PC. if it is ok or not. try to swap to another pc or tighten it.. cheer ^^
Jul 20, 2009 | XION II Mercury (XON102) ATX Mid-Tower...
NO SIGNAL PROBLEM
Please check whether the monitor is set to the correct settings. If you feel its incorrect, most LCD/TFT monitors come with an auto set up button which will restore the display to one that usually works. In case it still doesnt work, you might need to connect your pc to a different monitor and check the display settings. You could also try to download the drivers for this monitor and then re-connect the monitor and see if it works.
Jun 02, 2009 | ASUS VW192S Monitor
Message: check your PC and signal cable
That Means the Monitor Does Not Detect Your PC..Check The Video Cables And See If they Are Fully Connected
Apr 01, 2009 | Computers & Internet
Samsung 17" Flat Screen PC Monitor
Problem from motherboard side.
- No display from motherbaord circuit (Display IC)
- Try to figure out with PCI Display card or
- Try to connect different monitor or this monitor to different computer to cross check your dignosis
Jun 02, 2008 | Samsung Computers & Internet
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
No display
Your monitor's signal cable is loose.Tighten the screws of the cable....
Oct 12, 2007 | E-Machines T2615 PC Desktop
Check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Feb 05, 2007 | IBM E74 17" CRT Monitor
Microsoft Windows XP Professional Logo
132 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
