Question about Frigidaire FEF355 Electric Kitchen Range
How to operate self cleaning stove
Require an operating manuel
  • 4 more comments
  • needhelpnaw Dec 13, 2007
    can not get the cooker to work the grill does but the oven will not get to temp i have set the clock and tried all setting but need a solution or a manual
  • Anonymous Jun 04, 2008
    have the frigidaire elite series///cannot get the self cleaning to work.......very frustrating ....have read the manual over and over again
  • claudette922 Oct 18, 2008
    I have a crosley electric range and I do not know how to work the self cleaning over. Could you please help me
  • pepermint Dec 10, 2008
    I don't have a manual for for the Frigidaire Elite and there was no instructions on how to even turn the oven on.
  • Anonymous Apr 30, 2009
    Went to start the self cleaning cycle on this oven but did not have the door closed. The locking latch engaged and now I cannot close the oven door even after letting it sit for two days. The word "locked" is in red on the screen and will not change even when the oven is cold. How can I get the safety latch to return to its non-cleaning position and allow my oven door to close. thank you
  • thomsbar May 11, 2010
    have frigidaire model FEF355ASC with no manual. how do i self clean?
How can i operate an oven
Posted on Jul 19, 2008
How do you start the self cleaning oven process on a kenmore stove purchased from Sears in 2009?
  1. Empty the Oven
    • Take everything out of the oven. Remove the racks and clean them with soap and water in the kitchen sink. Look for any loose debris such as foil or charred food and remove that as well.
    Oven Cleaning
    • To operate the self cleaning mode, find the switch on the range marked "Clean." The oven door will lock once the cleaning operation has started. Do not open the door until after the self-cleaning process has completed. It will take between two and three hours.
      During the cleaning process, you may see and smell smoke. This is normal because the oven is operating at a higher temperature than when it is cooking. The high temperature is reducing all the organic matter in your oven to ash. You will also sometimes hear popping sounds from the oven that is caused by the expansion of metal under extreme heat. This is normal for a self-cleaning operation.
      After the oven has completed the cleaning cycle, allow it to cool for a couple of hours. Once cool, take a damp dish cloth and remove the ash from the bottom of the oven. Wipe down the interior of the oven door and around the seal. Be careful around the seal so you do not damage it. Replace the racks back in your oven, and the cleaning operation is complete.
    Other Considerations
    • Clean your oven at least once every three months. If your oven gets heavy use, consider cleaning it once a month. Always run the self-cleaning cycle when you are home. Because it uses intense heat, it is best to perform this operation later in the evening or early in the morning.
Aug 10, 2011 | Microwave Ovens
How do you operate the self cleaning option on a GE Talisman Royale Stove that's quite old
Before you try to run the self clean feature read this tip...
Mnay problems are cuased by the high heat of the self cleaning...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
Heatman101
Mar 12, 2010 | Frigidaire GLEB27S7A Electric Single Oven
Unable to clean my 5 yr old self clean Crosley oven
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Aug 31, 2009 | Crosley CE35100AA Electric Kitchen Range
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Stove cleaning
The filter in the jenn air can be run through the dishwasher. clean the outside of the oven as best as you can before you start the self clean cycle. NEVER!!! use oven cleaner inside a self cleaning oven. or on the gasket. . You can use a degreaser or oven cleaner on the cooktop on any stainless steel, procelain or chrome surface. Don't get oven cleaner on painted or aluminum surfaces. Rinse off very well.
Jul 05, 2008 | Kitchen Ranges
Frigidaire Self Cleaning Stove
Yes you have to set the timer. If it is like my stove/oven you have to set the time to start and the time to complete. normal cleaning 3 hours heavy cleaning 4 hours light cleaning 2 hours.
May 29, 2008 | Kitchen Ranges
VDSC307-4bss how to operate self-cleaning oven
I continued a search and found a manual on line... simple process to turn on self-cleaning operation... close the door and set to "clean" ... timer on this model is automatic... runs for 3 1/2 hours.. fan continues for an additional 30 minutes ... open the door and the oven is clean. Thanks
Mar 28, 2008 | Viking VCSO244 Dual Oven
Stove manuals for Crosley Electric Stoves
how do I operate the self cleaning function on my stove model
cs37500-1
Nov 12, 2007 | Crosley CE35100AA Electric Kitchen Range
Frigidaire FEF355 Electric Kitchen Range Logo
645 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
Sal De
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
