Getting to the aux channel
Im trying to turning to turn my Sansui TVM131AD to the aux channel without a remote, how would i go about doing so?
    Genius:
  • 1,148 Answers
MENU,,CHANEL SETUP
Posted on May 15, 2009
I am trying to get the aux outlets to work on the tv how do i do that?the universal remote i have is not putting the tv on that channel and i have the red white and yellow jacks installed in fron of the tv...
Try using the channel buttons on the front of the tv to go below channel 1. If this doesn't work you will need the original remote or you could try a different universal remote. You can use an RF modulator, available at walmart or radio shack, to feed the signal through the antenna jack on the back of the set.
I hope this will help you.
Bobya.
Mar 07, 2011 | Sansui DTV2700 27" TV
Can't find the aux channel on the TV and have lost the remote. I have also mangaed to deleat channels one and 2. I need the aux to link up to the playstation. what can I do?
the only thing you can do is get a replacement remote. the chepest alternitive would be to go for a universal one but dont be fooled into bying a cheap one if your tv is a sansui /you can also find secound hand electronics parts dealers on the net they should have a cheap origanal remote
Apr 02, 2010 | Sansui 27" TV
How do i get to the aux channel on a Sansui TVM131AD
if your tv doesn't have an AV button either buy a all in 1 remote or a RF cable compatable with your game console and tune the tv manually as you would tune tv stations
May 15, 2009 | Televison & Video
Sansui SV 2102 GOT SOME PROBLEM PLEASE HELP TO FIND OUT A SOLUTION OR KINDLY INFORM ABOUT THE SANSUI HELP NO.
on some tv's you can get to the menu by pushing both the channel up and down buttons at the same time.
May 04, 2008 | Sansui COM311AD 13 in. Combo
How to switch to dvd mode
If you can provide the RCA remote model # I can be more specific (it should be located on the back or inside battery case.
Anyway depending on whether your remote uses 3 digit codes or 4 digit codes the Sansui TV code is usually 191 or 1191.
  1. Press and hold the TV button on the remote. LED will stay "ON".
  2. Enter the code for your brand of TV into the remote while continuing to hold the TV button down. LED will go out during number entry and turn back on when the last digit is entered.
  3. Release the TV button. LED will flash and go out if number is entered sucessfully, or flash 4 times if it detects an error.
  4. Press Channel up or down to see if this has worked.
You can also use the code search function.
  1. Turn on the device you wish to control.
  2. Press and hold "CODE SEARCH".
  3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
  4. Release "CODE SEARCH".
  5. Press ON/OFF repeatedly until the device turns off. You may have to do this up to 100 times.
  6. When the device shuts off press and release ENTER.
  7. Try using the remote. If it does not function repeat steps 1 through 6.
Mar 21, 2008 | Sansui H TV2600 TV
Aux channel
Press channel down until you get to channel 1 then press channel down one more time ,this should give you your AUX.If it doesnt try going into the menu and doing an autoprogram with the video game hooked up and turned on.
Nov 08, 2007 | SansuiM1315 TV
Sansui TVM1316
try channel 65 and connect via antenna cable.
Jan 04, 2007 | Sansui TVM1316 13" TV
Televison & Video Logo
315 people viewed this question
Top Televison & Video Experts
Electro Med Services...
