Question about Maytag Dependable Care LAT9706
Blowing lid fuse. Lid switch tested fine. Other Ideas?
With lid open all lights work. If I shut the lid the lid fuse blows. Lights still work. I took the wires off of the lid switch and tested it with an ohlm meter. It appears to be fine. No fried wires, no weird smell. Any other ideas?
  • hunnybunnyhe May 15, 2009
    You know what? I think I might have found it. I just tested the check switch that connects to the lid switch and I'm not getting a reading from one of the wires that connects the two together! Hooray!...maybe.
  • 144 Answers
You might want to test the inlet valves for a very low resistance reading or a dead short Also check the motor etc for a short to earth using a Insulation Tester. Does it pop the fuse while it's meant to be filling up or while it should be spinning or washing? Cheers
Posted on May 15, 2009
Why don't the reverse lights on my 2001 Impala wok?
It could be the back up lights since you didn't say if you check them. or a reverse switch. as for your trunk lid not poping open with switch it could be a fuse
Sep 06, 2014 | 2001 Chevrolet Impala
Machine won't start, lights are all on and ready to wash
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Goodluck.
Jun 06, 2008 | LG WM-1832C Front Load Washer
KEEPS BLOWING FUSE WHEN I CLOSE THE LID
its in the lid switch safety assembly,there is a glass cartridge fuse on this board and if the lid switch sticks it will blow this fuse to power down the machine to protect the uses from it spinning with the lid open this board is available from most maytag dealers or appliance parts dealers
Dec 11, 2012 | Maytag LAT2600A Top Load Washer
2000 camary rear tail lights keeps on blowing my fuse
ck all four marker lights first than concern your self with the wires that run along trunck lid hindge ,, where tere flex at or pinch . replace fuse trunk open then do wiggil test on wires untill it blows fuse to locate short.
Feb 01, 2011 | 2000 Toyota Camry
Machine won't run and all lights are flashing
Hello there
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Dec 09, 2010 | Washing Machines
The washing machine doesn't come on when switched on at power point. No lights or sound at all. The fuse to the power point is all good. Machine was working fine the last wash load. Tashina
No power
Lid switch
check out this.
Jul 14, 2009 | Fisher Paykel EcoSmart GWL15
MAYTAG MAH5500BWW
No power
Lid switch
May 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Brake lights don't work
2004 Rx8 kept blowing 15amp brake light fuse. Solution: wire going to rear lights was worn and frayed where it feeds through the left trunk lip on left side of trunk. This can be seen when you open the trunk lid. The wire routes by the trunk lid hinge. If the support connectors come loose, the wires are crunched by the hinge or lid. Re-splice, insulate, zip-tie, replace fuse and replace any blown bulbs.
Apr 13, 2009 | 2004 Mazda RX-8
No parking lights, fuse keeps blowing.
There is a ground not connected or a wire open that is causing it to blow
Mar 08, 2009 | 1999 Pontiac Montana
Hi, my simpson eziset 550 washing machine wont start, I press power on then the start button and beeping alarm starts with the three water temp lights flashng, this has happened intermitantly in the past...
5 beeps with the 3 temp lights flashing means lids not closed. or lid switch not working
i just fixed this problem. the magnet in the lid had come loose. I undid the two screws on the side of the lid put the magnet back where it should sit then i poured candle wax over it to hold it in place and working fine now.
Nov 30, 2008 | Washing Machines
Washing Machines Logo
73 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
