Question about Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt
Cable broke off in the input jack
The tip of one of my cables broke off in the guitar input. amp works just fine but cables don't plug in all the way
  • rjivaro May 11, 2010
    That's because the tip of one of your cables broke off inside the jack. Remove it or have it removed.
    President:
  • 1,138 Answers
I'm pretty sure t6hat the output jack is a sealed unit(contacts inside soldered to the surface of the circuit board. You may be able to grasp the center shaft of the plug with a thin jawed hemostat or really skinny long nosed pliers and pull it out that way. Make sure the amp is off and unplugged from the wall. If that doesn't work you will either have to get it removed at a shop or disassemble the amp to remove the circuit board and unsolder the jack and replace it or get the broken plug out of the jack once it is unsoldered. I've never had a Line6 apart yet but thats probably the type of jack they used. Thats because it has to be electronically isolated from the chassis. Hope this helps.
Posted on May 15, 2009
Input and/or Output for pedals not passing sound through
I will answer this assuming you have connected the inputs and outputs of both the pedals AND the amplifier/guitar properly. Double-check your connections! ;)
Otherwise...Have you checked all the patch cables to make sure they're ALL working properly? That's usually the culprit in a situation like this, all other things being equal. Cables take the majority of abuse in your signal chain and also happen to be the weak link in the signal chain as well. It only takes one bad patch cable in a series to interrupt the signal.
I would take a pedal with perfectly functioning inputs and outputs and use it to test each cable yer using. If you verify all the cables are in fact working properly (and you are 100% certain everything is connected correctly), that indicates there might be an issue with the pedalboard's onboard electronics. At the most simple, the "From Guitar" or the "To Pedal" or the "To Amplifier Input" jack might be bad. One or more them, in fact, but it only takes one to entirely interrupt that signal chain. The loop section is less straight-forward in that if one of the loops has a bad input or output jack, that shouldn't affect the overall signal chain, nor the inclusion of the other pedals in said signal chain.
So, I think it's one of three things:
1. The pedals, guitar, or amplifier are not properly connected;
2. You have a bad patch cable;
3. Something has gone wrong with the electronics onboard the pedalboard, and this will probably require service.
Hope that helps.
Johnny
Nov 30, 2017 | SKB Corporation Skb Ps-45 Professional...
Danelectro Hodad Mini Guitar Amplifier - no sound output
Do the cables have the right length plug/jack ends? There are 5 different lengths in use. Some will short the inputs completely.
Do you get noise floor from the amp when turned full volume? if so, it is an input/mute issue. The switches these days are rather cheaply made and prone to dirt or corrosion. Try cycling the switches repeatedly. The same with the jacks.
If there is no warranty left- pull the chassis out and under a regular flourescent light, noise test each part of the amp with an insulated screwdriver- just make a contact on discrete transistors, or on the inputs of the IC's and work back towards the input. If it is clean all the way back-it has to be the cable, cable ends or the guitar.
Jan 30, 2012 | Danelectro Hodad Mini Guitar Amplifier
I have purchased 2 Ibanez TS8DX Tube screamers. Both are broken right out of the box. I plugged a cable into the out jack and into my amp. I then pluggen my guitar cable into the IN jack. Pushed the pedal,...
The input cable MUST be a TS (unbalanced cable) to turn the unit on. The sleeve of the input cable is what connects the battery. If you use a TRS cable at the input it likely will not turn on. A TRS cable has a tip, ring AND sleeve like many 1/4 inch stereo cables.
Sep 15, 2011 | Ibanez Ts9dx Turbo Tube Screamer Overdrive...
Marshall mg100hdfx head. I get no sound whatsoever plugged into the guitar input but the controls seem to work as I can hear changes in the light ambient static. I will get sound however if I plug directly...
You MAY have a broken input jack. If you can hear changes from the overdrive gain control, that control is just one stage away from the input jack. Also there is a capacitor C60 that is for RF bypassing and if that shorts that will kill the audio. Yes, inout jacks get destroyed by tripping over guitar cables... that is why you run the cord through the amp handle before plugging it in. Of course verify your guitar and cable is good using another amp.
Aug 30, 2011 | Music
What kind of cable do you need to connect a Kurzweil K2500S to the amp?
Hi. You can use standard 1/4 inch jack to jack audio cables (ordinary guitar leads will work fine) to connect the MIX outputs to a keyboard combo amp. If the amp only has a mono input, just use one cable from the MIX output marked L to make the connection. Remember to keep the amp volume turned down until you have plugged in the cable(s) from the K2500S. All best.
Apr 09, 2011 | Music
How do you use the mixer with a regular combo amp and stereo mic cable?
This is not hard to do, but it will require some adapters. Hosa company makes adapters to accomplish this. For example, if your Stereo mic has "1/4 inch male phone plugs" Hosa makes and adapter that has 1/4 inch female plug to Male XLR connectors. The Mackie, and just about every mixer in the world these days has Female XLR connectors for it's microphone inputs. So that will handle tha.
I'm not sure what you mean by the "combo" amp. If it has XLR inputs you can use Tip Ring Sleve male output jacks to the output. If your amp as conventional 1/4 inch female input jacks. Than a simple
1/4 inch Male to Male Guitar Cable will work fine. DON'T USE A SPEAKER CABLE as it is uninsulated and you will get 60Hz hum.
I hope this helps,
That looks like a great quality mixer you have!
Happy New Year,
Mark
Jan 01, 2011 | Mackie 402vlz3 Mixer 402vlz3 402vlz3 Vlz...
Bass Guitar Keeps sound keeps cutting in and out.
There is an inconsistency in your text. You indicate that cables were swapped and problem still existed...
You said:... "i have tried using it on a different amp and still fine".
If you tried it on a different amp and it was still fine then the guitar is probably OK.
THEN your amplifier is in question as the root of your problem.
What is the amp you have? The guitar is the CB-42, but what amp do you have?
MANY intermittent problems with amplifiers are often with the input jack itself. These jacks are easily broken by tripping over a cable plugged into them.
Jan 04, 2010 | Fender Rumble 100 Bass Guitar Amplifier
How do i plug my eletric guitar into an amp
Connect a 1/4" instrument cable from the guitar's 1/4" jack to the amp's 1/4" input.
Oct 02, 2009 | Dean Guitars Dean Ml79 Electric Guitar
Generates buzzing noise even when only cable is connected to it. No cable - no noise.
If you are saying that you are plugging a guitar cord into an input on an amp without the guitar on the other end and you are getting a hum or buzz with the volume turned up ; that is normal. If you are getting the same results with a guitar plugged in it means the ground wire to your output jack on your guitar is broken. Check your cord with a volt ohm meter for continuity on the tip on one end to the tip on the other end. Do this for the sleeve on one end to the other. If you were getting the buzz without a cable it would mean that your input jack in your amp has a broken ground connection. Hope this helps.
Jul 04, 2009 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Static Noise from guitar amp.
I take it you have made sure that both the cable to the distortion box from the guitar and the cable to the amp are both good. From the description you give, it sounds like there is no signal getting to the pedal. If the cable is good, then the next likely suspect would be the input jack on the fuzz box. Try wiggling it a little with the guitar cable in place to see if it is loose. Some input jacks are unbelievably cheap and flimsy. A crackling sound (static like) is almost always a bad connection. If it was the output jack, I would think that the guitar signal would come through a least a little bit, but you might want to try wiggling that one, too, if the input jack isn't the culprit.
Another possibility to check is the battery, but this doesn't seem as likely. Some effects units devour batteries, especially units that use 9V batteries. I have a multi effect pedal that kills a 9V in about an hour.
Jan 22, 2009 | Epiphone Les Paul Studio Electric Guitar
Open Questions:
See all Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Questions
Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt Logo
906 people viewed this question
Top Line 6 Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Larry Stiles
Larry Stiles
Are you a Line 6 Music Expert? Answer questions, earn points and help others
