Question about GE WDSR2080D Top Load Washer
I have a GE washing machine the model number is WHDSR209DZWW. It will not agitate during the wash cycle. It will also not stop filling with water during this time. The water leaks out of the bottom. The other cycles are fine. It spins and drains normally during the rinse. Please Help!!!
  • 144 Answers
You need to check to see if the pressure tube and switch are ok this is how the machine detects it;s water level. Eg the tube may have just popped off or there could be a hole in the Pressure tube. Any questions feel free to ask Cheers
Posted on May 15, 2009
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
Nov 28, 2015 | Roper Washing Machines
General Electric Washing Machine want agitate. The washer fills, spins, drains but simply stops agitating or washing during different cycles. I have checked the lid switch, coupling under the agitator and...
The water level switch may be going bad. As the water level rises to the proper level, it switches a set of contacts inside to stop the water fill and cause the machine to start agitation. Make sure machine is empty before you replace the water level switch---it works off of air pressure from a small hose attached to it.
Feb 16, 2015 | General Electric Washing Machines
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
GE Spacemaker Washer/Dryer. Model # DDPI380GAMWH. Water won't stop filling. It continues to fill during all cycles. Fills during agitation. Agitates inproperly. It agitates in short pulses as water...
Thanks for choosing FixYa and welcome. This sounds like a problem with the water level switch in the washer. It controls the amount of water entering the tub. It is probably defective. You may want tomake sure the switch is getting power first by testing the wires with a voltage meter.
Jun 18, 2011 | Washing Machines
No water during any cycle.
if no water is coming in how is it agitating?is it filling at the beginning,then it starts to wash the clothes,now does it drain and then it won't fill again,send the model number and more info,
Jul 02, 2010 | Kenmore 24032\24036 Top Load Washer
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Mar 23, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
Mar 21, 2009 | GE WCXR1070A
GE WDSR2080D Top Load Washer Logo
287 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
