Question about HP LaserJet 3055 All-In-One Printer
Black line down right side of paper
I am getting a black line down the right side of the paper - there is no
black line when I print from the flat bed with the glass - only get black
line when printing from top feeder  I have cleaned every roller that I
can find but has made no difference
  • Anonymous Mar 18, 2014
    anything they gets printed has several black lines down the right side of the paper
  • Anonymous Mar 28, 2014
    when trying to print a pic from photo with glass down the way it says refuses it tells me flip photo paper over then prints bt wrong side
On the ADF check the twink mark on glass scanning mirror
Posted on Oct 15, 2007
2 Suggested Answers
  • 5 Answers
SOURCE: HP Officejet 6480 leaves a black line down left
I found the following information on the HP web site, under their support forum.
Clean the automatic document feeder (ADF)
If the product is not already off, press the Power button to turn off the product, and disconnect the power cord from the product.
Remove all originals from the document feeder tray.
Open the ADF cover.
Lightly dampen a clean, soft, lint-free cloth with distilled water, and then squeeze any excess liquid from the cloth.
Use the damp cloth to wipe any residue off the rollers and separator pad.
NOTE: If the residue does not come off using distilled water, try using isopropyl (rubbing) alcohol.
Close the ADF cover.
Step 2: Clean the glass strip in the ADF
Open the ADF cover, and lift the ADF mechanism.
Lightly dampen a clean, soft, lint-free cloth with a mild glass cleaner.
Gently clean the glass strip inside the ADF, and then thoroughly dry it to prevent spotting.
Lower the ADF mechanism, and close the ADF cover
Close the scanner lid, reconnect the power cord to the product, and then press the Power button to turn on the product
Posted on Aug 23, 2010
My HL2040 printer is printing black vertical lines along the right-hand side of the page, about 3" or so. A month ago I took it apart and cleaned the roller. Still doing it.
If the lines go all the way down the page, check the position of the corona wire cleaner tab (blue or green) at the top front of the drum unit. if not parked fully to one side it will create a solid black lines where it blocks the laser. Otherwise look for some other foreign object (or torn paper piece) that may be blocking the laser from the drum. If the lines are thin and shark, check for scratches on the drum (not repairable without replacing drum). If the lines are uneven thickness but in a pattern that repeats down the page every few inches, then the film on the drum is probably worn or wearing away and the drum needs to be replaced.
Mar 04, 2015 | Brother HL-2040 Laser Printer
My printer is printing black horizontal lines down the right side of the paper - what is wrong?
Needs Drum If you pull the drum unit out you will see on the drum different shades of color lighter is wear the lines come from. Buy a rebuilt drum much cheaper and they work, may have to reset the drum count if the change drum lite on...
May 02, 2014 | Brother MFC-8460N All-In-One Printer
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
Black ink cartridge is leaking and black line is running down back of page
if you do your own refill the ink u are using is of the wrong density, get the right ink
May 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
Old canon copier prints thick balck line down right side of paper
tthis is really old 25 years plus. replaced the drun cartridge which also contains the toner good luck canon sr tech
Jan 19, 2009 | Brother MFC 7420 All-In-One Laser Printer
Black Lines running down the right side outside of the print area
It may be the fuser. Take it out and inspect the roller on it:
  1. Switch off the device, disconnect the mains plug and wait for 30 minutes before continuing.
  2. Ensure that the bypass tray is closed, or you will not be able to open the front cover.
  3. Open the front cover by pressing the release buttons as shown.
  4. Pull the front cover down towards you.
  5. Disconnect the green plug - squeeze the sides of the plug and pull.
  6. Push the left and right levers outward to unlock the unit.
  7. Pull the unit towards you as shown and lift it clear of the device.
  8. Check the roller for wear marks, If so replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 21, 2008 | Ricoh Aficio CL3500N Laser Printer
Black Line on Rt side of every printed sheet!
I don't know if this will help but I was getting smears on the right side of the paper where there was no printing. I came acrossed this and it worked for me. Open up the front cover and lift the top cover and remove the drum cartridge. Then with cartridge out remove the left and right screw on the side of the cartridge. This will give the drum belt room without hitting the cartridge case. The cartridges plastic was not formed well.
Skip
Jul 11, 2008 | Dell 3100cn Laser Printer
Konica Minolta Magicolor 2430DL--black line on right side of paper
Sry but you have to change drum cartridge, the line is caused form drums cleaning system, and it cant be repaired.
Oct 18, 2007 | Konica Minolta magicolor 2430 DL Laser...
HP LaserJet 3055 All-In-One Printer Logo
4,548 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
