Question about Whirlpool WED5521SQ Electric Dryer
Heat element whirlpool does not heat
If you have no heat - always start with the thermal fuse. I found mine after removing the back panel. Unplug the power to the dryer! Test to see if the fuse has continuity, if not it must be replaced (they can't be repaired). If you don't have a continuity tester, use a jumper wire to close the connection between the two wires coming to it. Plug your dryer back in and if your dryer heats normally you've found the problem and it's a very inexpensive item (I found one on eBay less than $4.00). The dryer can be operated for a short time with the jumper you just used, until the part arrives. But, don't leave the fuse off, it is a very important safety feature, to detect overheating and avoiding a potential fire!
Posted on Jun 01, 2009
    Scholar:
  • 43 Answers
If your dryer isn't heating, it's possible that your heating element needs to be replaced.
are either of these pictures of your dryer?
Whirlpool dryer 1
whirlpool dryer 2
Posted on May 16, 2009
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
Not heat when washing
replace heating element
Apr 07, 2015 | Whirlpool Dishwashers
Whirlpool dryer
if everything else works and only no heat it's probably the heating element. you can find instructions on the Internet on how to access the heating element. Test it with a multimeter on Ohms (resistance) setting. Touch the two probes of the multimeter to the two legs of the heating element. If the meter shows no continuity, element should be replaced. How that helps.
Dec 26, 2013 | Whirlpool Dryers
My whirlpool ADG 7540 dishwasher is not heating the water but is running through the programme
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 16, 2011 | Whirlpool 24 in. ADG7540 Built-in...
Replace heating element for Duet Dryer GEW9200LW1
First disconnect the power to the dryer by unplugging it from the wall. Then remove the 3 screws on the lower panel of the dryer. This should expose the heating element in a metal housing on the right side of the dryer. Disconnect the 2 wires going to the heating element and slide it out of the housing. The heating element part number is 3387747.
May 25, 2010 | Whirlpool GEW9200L Electric Dryer
Whirlpool dryer not heating up checked heating element have continuity arcroos coil connectors
Check the thermostats. Unplug one wire and test for continuity across the thermostat terminals.
Jan 03, 2010 | Whirlpool Dryers
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
New Element, still no heat
Jan 07, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool WED5521SQ Electric Dryer Logo
144 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
