Question about Refrigerators
Dometic DM 2862 Too Cold Freezing Everything Running About 26Deg. F In Lower Compartment Just Restarted After Winter Shutdown. Doesn't Matter If Running On Gas Or 110V
    Sergeant:
    Champion:
  • 214 Answers
Don't worry! just switch off your refrigerator for 8hrs than switch it on......place the thermostart at 3 point......i'm sure that your problem will be solved. if not than replace your thermostart..................have a nice day:-)
Posted on May 15, 2009
Dometic rm 2862 freezes everything in the refridgerator
move temp sensor to inside of coils if same replace temp sensor
Mar 17, 2013 | Dometic RM2652 Refrigerator
Items in the lower refrigerator compartment arefreezing
Hi, Sounds like the damper or damper belt may be at fault. The cold air enters the refer compartment through the damper in the back. If that damper is not controlled to close/open as needed it is likely stuck fully open all the time. That will let cold air in no matter what the t-stat says. See if you can view with a mirror and see if the damper "blinds" are fully open. If the t-stat is turned all the way down the dampers should close, as less cold air is needed. Then, as the t-stat is turned up, the dampers open to let in cold air from the freezer compartment.
Take care
Jul 23, 2010 | Magic Chef CTB1922 Top Freezer...
A dometic #2862 rv refrigerater which is freezing everything
This one is easy your thermostat is gone. You may notice the unit never shuts off.
Jan 13, 2018 | Dometic Refrigerators
Refrig cooling
Sounds like the evaporator fan is not working. Check to see if you can hear the fan running in the freezer. If not running, try removing the panel in the back of the inside freezer and manually spin the fan blade . This sometimes works.
Jul 03, 2009 | Refrigerators
Everything in frig is freezing no matter what setting we put it on
It looks like the refrigerator won't stop running not matter what temperature you set the cold control and that is the problem ,its need to be replaced.
May 01, 2009 | Refrigerators
RV ice box freezes everything
if it have a timer board change it
Mar 31, 2009 | Dometic Refrigerators
Refrigerators Logo
187 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
