Question about Star Office Equipment & Supplies
LED 2 flashing red and won't go away
Hi, One of our Star TUP900 printer has the LED2 flashing red. it won't go away. It won't print Selt Tes page as well when I use the Configuration Utility. Thanks, Arnold
SOURCE: Flashing red light on display
I have this problem everytime I leave my d5160 off for a prolonged period, sollution: flicking the cd tray up and down untill it registers that it is actually shut! - hope this helps
Posted on May 05, 2008
SOURCE: RE: Epson TM-U200 printer with error (2 Flashes)
http://www.icscale.com/TECH%20MANUALS/TMU220_TRG_RevD.pdf
Posted on Dec 04, 2008
masterminds
  • 51 Answers
programmer can be used. example Makefile is included for LED flashing sample project in ..... but gives no such newsgroup error after specify the title. ...... Uses two-wire serial data communication through printer port. ...... The simple emitter-follower does not have a gain of exactly one,
Posted on May 27, 2009
komguy
  • 2306 Answers
SOURCE: All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Posted on Jun 26, 2009
bhagyavichar
  • 414 Answers
SOURCE: 1.As I give print command the printer head takes
seems a case of carriage jam n needs servicing..
howevr, do it if ur printer is out of warranty and u r a professional..
check for loose/faulty carriage-belt and the drive-assembly..jammed/sticky cleanser-unit (esp the rubber, gears n base)..
also chance of defective/faulty photo/opto-coupler 'sensor(s)'..the diodes and resistors in dis section..
always better to hv professional supervision, contact ur system admin/vendor....
Posted on Nov 06, 2009
Red LED keeps flashing
Hi
I've been stuck with a flashing red paper light for a while. The printer could print from the manual tray and could also print test or diagnostic pages.
So I thought it might be driver related, and indeed it was.
There's a nasty setting in the printer properties that makes the printer go woo-hoo. So go to printer properties > tray settings. Check the "paper size" of "Tray 1". If it's set to "undefined", change it to your corresponding paper format. Click Update, Apply. Now print happily.
I still wonder why that setting magically changed. Hope this helps someone.
techbelkin
Dec 28, 2010 | Brother HL-2070N Laser Printer
The orange lights are flashing, is there something wrong?
Try:
1 Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
2 PPM print speeds are based on the highest speed printer driver mode. Photo print speeds are based on the default mode driver setting using Canon Photo Paper Plus Glossy paper. Print speeds will vary depending on system configuration, interface, software, document complexity, print mode, types of paper used and page coverage. CPM copy speeds based on fast mode setting using plain paper. Copy speeds may vary based on document complexity, copy mode, page coverage and number of copies.
3 USB 2.0 Hi-Speed requires Windows XP, 2000 or Mac OS X operating systems. For Windows 98, Me and Mac OS X v.10.2 to 10.2.6 operating systems, the printer will operate at USB 1.1 specifications.
Oct 22, 2010 | Canon PIXMA MP150 All-In-One InkJet...
No video and red led lights up
Try a isolation test.
Remove MB from case and put on a piece of cardboard, then hook everything back up to it and see if it powers up.
You have 2 LED's
LED1 Onboard 3VSB LED for SDRAM
LED2 Onboard Power LED
Look @ page 19 & 20 of this manual..
I hope this helps, if so please rate our solution.
Mar 14, 2010 | EliteGroup P6VAP-A+ Motherboard
Kodak easyshare keeps printing test page
hi waht test page are you reffering about is the windows tes page or the demo page? If the demo page you can just turn off the printer if the windows test page. you need to go to control panel and click for printer and faxes, now right click on the icon of the printer and choose properties. Now under that properties settings you can cancel the query printouts for your printer
Nov 07, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Jun 26, 2009 | Brother HL-2170W Laser Printer
Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
  1. Turn printer off.
  2. Press and hold the feed button down. And switch printer on.
  3. Release the feed button when the LED flashes red.
  4. When the LED flashes green, press down the feed button.
  5. When the LED flashes amber release the feed button.
  6. Try printing now that the printer is back in page mode which is used for print your labels; line mode prints the labels code.
  7. Do this fast or else it wont work if you are slow.
Jan 13, 2009 | Zebra LP 2824 Printer
Epsom TM-U220 Error Codes
From the manual its probably one of this item.
-printer temp is too high
-cover is not properly closed
-print head is not in the correct position
-paper cutter is not in the correct position
-paper jam
Try turning off the printer, remove the power cable, turn it on again for 5 seconds to reset it. Connect back power cable, press the feed button and turn it back on. The printer should do a self test, turn it off and on again after the self test. It should make the red light go away.
Oct 27, 2008 | Epson TM-U220 Matrix Printer
Red light on my hp photosmart 7850 keeps flashing
Same problem red light flashing and a picture of a little box with an arrow pointing right in the screen??? what the hell does that mean?
Nov 22, 2007 | HP Photosmart 7850 InkJet Printer
There is a red light flashing
From the OKI site, I found this information. My problem is a Flash 2 Blink, which is a problem with the cover or minor error, whatever that means. I can't figure out how to fix it. Any suggestions greatly appreciated!
Flash type Ready LED (Green) Manual feed LED (Amber) Error LED (Amber) Meaning Flash 1 -- slow blink X ecblank.gif ecblank.gif The printer is processing data when printing has been suspended. ecblank.gif ecblank.gif ecblank.gif X The image drum required changing or toner is low. Flash 2 -- blink X ecblank.gif ecblank.gif The printer is receiving and processing data during printing or the printer is resetting itself. ecblank.gif ecblank.gif X ecblank.gif The printer is requesting manual paper feed. ecblank.gif ecblank.gif ecblank.gif X There is a printing error, problem with paper or a cover open. ecblank.gif X X X There is a minor error with the printer. Flash 3 -- rapid blink X X X There is a major error with the printer.
Oct 27, 2007 | OKI B4250 Led Printer
Printronix P5412 Do not Print
Sounds like this unit has some electrical (minor) damage.
Sep 07, 2007 | Printronix PrintNet Print Server
50 people viewed this question
Top Star Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
ray gallant
Jean DeLauche
Jean DeLauche
Are you a Star Office Equipment and Supply Expert? Answer questions, earn points and help others
