Question about Canon PIXMA MP160 All-In-One InkJet Printer
T same problem.. printer is on maintanence.. code 2,114,0
  • santhoshk757 May 15, 2009
    thanks for your help guys.. i fixed it.. the display in the printer blinks '4' and 'E' alternatively.. this states that the ink is low.. after pressing the start/reset button for 5sec the printer wil work as usual even if there is low ink..
    than you for your support...
  • 29 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prito-i-21
Posted on Sep 04, 2009
  • 696 Answers
This is one of three codes you can see when there is a major malfunction in the printer. Officially Canon recommends taking to an autorized dealer for repair. However about 20% of the time it's just a lockup in the system and can be reset.
So, try reseting it, unplug the power and USB then walk away for no less than ten minutes. When you come back, plug just the power back in and turn it on. If it still has the error code, get it repaired if it's still under warranty or if the warranty is over buy a new one it will be cheaper than repairs.
If the eroor code is gone shut it off, hook up the USB cord and turn it back on. If it works you're good to go, if the error code comes back, take it in for repair, this will be a cheaper repair and might be worth doing even off warranty.
Hope this helps FixYa,
Chris
Posted on May 15, 2009
Will not run
MAINTANANCE CALL (M2)
Jan 24, 2014 | Minolta Bizhub Di1811p Copier
When you turn on the printer, the code 80, code appears to want to reset the wrong network
code 80 is maintanance message askinfg for the fuser charge and transfer roller to be changed. to reset counter hold tick and right arrow will go into config menu you can then reset counter. but if you do not change parts it will start to jam due to fuser at end of life
Aug 15, 2011 | Lexmark T644 Laser Printer
COD ERROR 2,114
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Jul 13, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Keeps jaming,80 scheduled maintanence advised
hello, the maintanence message coming up on your printer is for the fuser and feed rollers, with tranfer roller. i would recommend that you follow this maint schedule. it makes sure that the machine works well at all times. the feed rollers come with the kit, as well as the tranfer roller, for image quality.
Oct 11, 2010 | Lexmark T640 Laser Printer
Displaying error E and 5 (In Blinking) and error code 2,114 while scanning........help me out of this...........thanx
The e2 error os no paper, e5 is improperly or damaged ink carts, as is the e14 error code. Make sure that there is plently of fresh paper, and replace the carts with new canon carts. If you are using refilled carts in this machine, the failure rate of this series of carts is nearly 60%. Last step to try would be to unplug the printer from power and let sit for at least 10 minutes, plug back in and power up.
Sep 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My brother 5480n keeps showing me the message that I need to do maintanence but I can't get to the maintanence screen on my computer? What do I need to download to access the computer maintanence?
Open the control panel ... open printers ... right click on your printer ... select properties ... I think you will find what you are looking for there.
Aug 16, 2010 | Brother MFC-5840CN All-In-One InkJet...
Maintanance required code TA
Ok so the TA code means that the all maintenance counter has reached its limit
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code 04
Then you can select what you want to clear so the maintenance count all
Execute this yes then press the CA key the machine will restart and away you go
I also do advise that you service representative comes along at some point to check the machine it could need parts because if you stretch the life of parts your machine could become unreliable... But that is up to you
May 11, 2010 | Sharp MX-2300N Color Copier
Trouble shooting and maintanance
with brothers all you can really do is buy another drum... if they go bad that is it for the drum...
Dec 23, 2009 | Brother MFC-7340 All-In-One Laser Printer
How to reset maintanance message of sharp-ar 5127
U need to enter stimulation mode:
"C" key->Auto/Text/Photo key->"C"key->Auto/Text/Photo key
*perform above 4 key strokes quicky
Once inside stimulation mode, enter main code "20", then sub code "01" for maintenance counter clear, press "START" key to clear.
Feb 19, 2009 | Toshiba e-Studio162D Copier
Canon 8180C laser Multi Function printer Error Code 078
did you reset the drum unit on maintanance counter of the machine?
Apr 18, 2008 | Canon MF8180C Color Copier
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
161 people viewed this question
old marine
old marine
