Question about Refrigerators
Freezer holds temp. refrigerator does not
Refrigerator side is heating up. I adjusted the temp button and unplugged to reboot. After rebooting the frig side defalted to 80 degrees. I set it to 34 degrees so far its dropping slowly and is at 78 degrees. Before I rebooted is was around 38 and I adjusted it to 34. When it hit 34 the display started to flash. Thats when I rebooted. upon powering up the display went to 80.
  • 159 Answers
Low gas in the system
Posted on May 15, 2009
Where is the reset button on a hottpoint side by side refrigerator.
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
Read more: http://appliancejunk.com/forums/index.php?topic=10408.0#ixzz3VIqUINVz
Feb 27, 2015 | Hotpoint HSS25GFT 25.0 Cu. Ft....
MY FRIDGE THE FRIZER WORK GREAT,BUT THE FRIDGE BOTTOM NOT
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 22, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
The fridge has been unplugged for about 6 months due to renovations. When plugged in only the freezer works. The fridge section will not kick in. Is there a reset button? Thanks Cindy
Mar 30, 2011 | Kenmore Top Freezer Refrigerator
I have a GE Profile refrig with bottom freezer.Today, the power company turned off the power to the streey and when power came back on, my display in the left refrig door is brinking 88 on one side and the...
I had this issue after a power outage with our GE Profile Model GFSF6KKY Dispenser Model. No solution that I could find online helped me so I started trying different button combinations. Pressing Adjust Freezer and Adjust Refrigerator buttons at the same time and holding it for at least 10 seconds worked for me.
Nov 19, 2010 | Refrigerators
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
• Enter code 1 6 to exit diagnostic mode. GSS manual
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore refrigerator Freezer is cold but fresh food side is warm
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Jan 26, 2010 | Kenmore 57029 Side by Side Refrigerator
Freezer side is working very cold the refrigerator side is only cool. Air does not seem to circulating properly.
Oct 16, 2009 | Kenmore 57029 Side by Side Refrigerator
Maytag RSW24EO refrigerator not cooling
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 14, 2009 | Refrigerators
Appliance: Frigidaire 3.1 Cu. Ft. Compact Refrigerator Problem: How do I adjust freezer temp in my mini-fridge with top frost free freezer, has turn dial for refrigerator but no turn dial for freezer and...
The turn dial that controls your fridge temp also controls the freezer temp. The freezer air is directly forced into the freezer compartment and then sent to the reigerator. Adjust the dial for the fridge not to be so cold and it will adjust the feezer also. Allow about 24 hours for any noticeable change.
Apr 19, 2008 | Refrigerators
Refrigerators Logo
154 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
