Question about Frigidaire FAH106N1 Wall/Window Air Conditioner
Have an electronic window ac in a community cable building which shuts off during power outages. How do I bypass the switch?
    President:
  • 2,559 Answers
Bypassing the switch will not stop it from going out during power outages.
Posted on May 15, 2009
HOW TO LIGHT OVEN WITH A MATCH
Look up product manual on internet.
Look at label located inside oven door, and add .pdf to search parameter to help find manual.
Then read section about lighting appliance.
If power is out, then pilot will not have any gas >> if gas control is electronic.
Many electronic gas controls require electric power to operate circuit board.
In old days, you removed the bottom tray on oven to access burner and pilot orifice. Then you pushed down switch to release gas through pilot tube, and put lit match into the gas stream to light pilot. Hold down switch until pilot flame heated tip of thermocouple which caused magnetic switch to stay open inside gas control. Release switch and pilot stayed lit.
Safety concerns and vast advances in manufacturing cheapness have changed gas appliances so they are more inconvenient for do-it-yourselfers during ordinary power outage.
Cook hamburger over metal bucket with newspaper, and grease on newspaper burns enough to cook hamburger.
People always buy generators and flashlights, but nobody suggest buying barbeque briquets and starter fluid as way to keep warm and cook.
Oct 29, 2012 | General Electric GE 24-Hour Power Strip...
I have a Sharp model LC-42sb45u that will not turn on since power outage.
Voltages sometime increase/decrease during power outages. This mainly afftects the power supply of a lot of electronics equipment.
1. Check the fuse.
2. Check primary components like; Bridge rectifier, filter cap, switching components etc.
3. Check secondary (cold) side once you isolate the primary side to be ok.
Please consult a professional technician if you are not skilled in electronics repairing.
All the best
Rjn
Sep 20, 2011 | Sharp Televison & Video
Our power shut off. AC window unit was on. When power came back on, AC said "E1" Unit model no. HWR08XC7
The "E1" Code indicates a security protection shut down code. Based o what you said about the power outage and the restoration of power, I assume the unit was left ON during the power out and restoration of power. A power surge more than likely caused the error code.
Hopefully irreparable did occur and you can get the electronics to reset by doing the following:
Turn the ON/OFF Switch to OFF and unplug the unit for 15 minutes. After that time has elapsed plug the unit in and turn the ON/OFF Switch to ON. Hopefully, the electronics reset & reverted back to the original factory settings and the error code has disappeared and you can set the controls as you like. If that didn't happen, you should contact Haier Customer Support 1-877-337-3639, as they can tell you which circuit was effected. From there, you can determine if a repair is warranted.
Hope this helped you and thanks for choosing FixYa.
Aug 03, 2011 | Haier Heating & Cooling
I push the power button and nothing happens. It happened previously and a few days later I pushed the button and it came on as mysteriously as it went off. What can I do to troubleshoot or fix the...
Depending on how long the power was off, your desktop power supply circuit capacitors may have fully discharged during the power outage. This will effect how fast your computer will turn on when you press the power button. Turning off the power by pulling the cord, or a power outage while the computer was on will usually result in a message that Windows was not shut down down properly when you try to restart it. Also make sure your computer isn't plugged into a 'switched' receptacle that's wired to turn on a table lamp etc from a wall switch. It's usually the bottom half of the receptacle that's switched while the top plug is always 'hot' or powered and unswitched in a wall switch controlled recepacle situatation.
Jan 16, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
My t3065 e machine was powered down manually 1 week ago when I got back to it to turn it on nothing happens, the power cord and wall plug are fine
Perhaps during the interlude that the eMachines wasn't being used, there was a power outage, or lightning struck nearby.
The first hardware component that I would check, would be the Power On switch, and Power Supply.
Bypass the Power On switch to see if the problem is the Power On switch, or the Power Supply.
If bypassing turns the Power Supply on, the problem is the Power On switch.
If bypassing does Not turn the Power Supply on, the problem is the Power Supply.
Inside the plastic Power On button, is a Power On switch.
It is a Momentary Contact Switch.
Below is one example of a Power On switch, I have found to fit many computers.
http://www.directron.com/atxswitch.html
Bypassing is done with a jumper wire, inserted into the back of the 20/24-pin ATX main power cable connector.
The jumper wire Briefly, touches the Soft Power On wire (Green) terminal down in the connector, and ANY Ground terminal. (Black)
I listed 20/24-pin above, because I don't know if the T3065 uses a 20-pin ATX main power cable connector, or a 24-pin ATX main power cable connector.
Below is an example of a 20-pin ATX main power cable, and it's corresponding connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
The photo all the way to the Right, shows the back of the connector.
It is plugged into the motherboard.
The Front of the connector is plugged into the female socket on the motherboard.
The Back of the connector is shown, and this is the area the power wires go down into.
Here you can see the green Soft Power On wire.
ANY of those Black wires are Ground wires.
I have Not detailed this procedure yet.
Do Not attempt it until I do.
I want to know first, if you are interested in doing the procedure, and will also outline any safety issues involved.
Jun 04, 2010 | E-Machines T3065 PC Desktop
Dimmer Switch not working after power outage
It's quite probable these units have gone faulty, due to the "Outage" see my previous post below.. You will need to replace these units, to restore functions. Please, have a read below, it may save you many $$ We have all had them, Power Outages, inconvenient, and also very deadly, well to Electronic equipment anyway. You see when any Circuit, is Made or Broken, at the instant of contact, when reconnecting, the current draw is considerable, also, after the connection has been made, and the "Load" being connected, and the Current draw is large, all sorts of transients, Spikes, Surges, Oscillations, is reflected, up and down the entire network. Now along with this, MOST people do NOT completely remove, the unit from the mains, by withdrawing the plug. nor, probably, even turn it off. This is wrong, ALL/ANY electronic equipment, that is connected to that Grid, will also encounter a phenomenon know as "Inrush Current" Now, this Inrush Current, Can and Does cause a great deal of damage to electronic equipment, the, instant reconnection, without going through an ON/OFF switch, and Power Conditioning Circuitry, well, the initial Current draw for that instant, is incredibly, high, and with nothing between, the current surges in, stressing everything, in the Power Supply, and more. Now along with that, you also have Transients, Spikes, Surges, Ringing, Oscillations, caused by the reconnecting of the Circuits. Joining of Cables, or Contacts. When the Power Goes OFF, you should NEVER leave anything plugged in after a Power outage, you need to withdraw each and every plug, from ALL Electronic equipment, note here, purely resistive, and relay type equipment is usually immune, it must be removed, and it shouldn't be reconnected, until about 5 minutes, AFTER the Power has been reconnected. This is to Avoid, all of the bad things that are caused by the reconnection back onto the Grid. If you do this, you can be assured of you Electronic items, lasting at least as long as they should, and not suffer premature deaths.
May 06, 2010 | Lutron Electronic Low-Voltage...
Garage door opens w/ Power outages
You will need to get a surge protector on this unit first of all. You will have to replace the logic board and maybe the wall button or sensors depending on how bad the surge was. Any time the power goes out the logic board can be affected by it. Thanks BB
Oct 06, 2009 | General Electric GE 13-438 Overhead Garage...
What problems do these technologies solve in UPS?
1. Provide conditioned clean AC power to computers & other peripherals (except laser printers, which should not be powered by UPS).
2. Protect equipment from the harmful effects of brownouts & sags.
3. Supply power to equipment during a power outage for a specific time, either to allow for the graceful shut down of systems, or to keep the systems working during the power outage (depending on the battery capacity).
Jul 17, 2009 | Fenton Technologies Computers & Internet
Emachine Turns Off
This is the best way to tell. If your system is shutting down on you by behaving like your shutting it down thru windows then it could be a spyware, virus trojan issue going on. If thats the case then run your virus program and see what it finds and remove it. If your laptop is shutting down on you where everything turns off right away with no lights, kind of like a power outage then go ahead and remove the battery and only use the ac adapter and see if that solves the problem. If it does solve the problem then you know its your battery that is the culprit. If your only using the ac adapter and the machine shuts off on you like a power outage with no lights then you know its a problem with the motherboard. With just the ac adapter plugged in, wiggle the cord near where it plugs into the laptop and if it shuts off on you like a power outage then you know its a loose DC Jack and it needs to be resoldered back into place. Hope all this helps.
Jun 12, 2009 | Computers & Internet
Electronic AC shuts down during power outage.
When I read this...this only tells me that some people are only as bright as a 15 watt light bulb.
You know they have these things on there to keep you alive, instead of catching on fire and killing you with smoke.
Leave it alone and follow the directions. You will live longer.
May 15, 2009 | Frigidaire FAH106N1 Wall/Window Air...
Frigidaire FAH106N1 Wall/Window Air Conditioner Logo
103 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
