Question about Brother LS-2125 Mechanical Sewing Machine
Homemaker sewing machine. i cant remember where a part fits back in. the small metal plate that sits somewhere around the plastic section where you thread the cotton at #3
Took my sewing machine apart to fix a problem but now cannot remember how one of its parts goes back together
  • Dave May 11, 2010
    Without knowing what parts you took out and from where, there is no way to be able to give you the instructions as to where and how to put those parts back in.
    Problem Solver:
  • 13 Answers
Where do I find the model and serial # for an older brother machine
You'll have to look around. On older machines, that information is usually on a plate, perhaps somewhere near the plug or the back of the neck. However, there are some machines that it is stamped into the metal on the underside of the machine.
Oct 14, 2016 | Brother Sewing Machines
How do I change the bobbin in a Janome sewing machine?
There is a small plastic plate where the needle goes down through the foot, remove this cover and you will see the bobbin. Remove the bobbin and refill or selecting another bobbin turn it so that when you pull the thread the bobbin turns anti-clock-wise, slip the bobbin into the black plastic casing, pulling the thread towards the small red arrow at the bottom of the casing, slip the thread between break in the silver metal sleeve pulling it to your left between the 2 pieces of metal this is where the tension on the thread is. You have now changed your bobbin. With the plastic plate still off, hold the top thread with your left hand and with your right slowly turn the wheel, this will send the needle (holding your top thread) down into the bobbin casing and will pick up the bottom thread, pull on the top thread and bring the bottom thread up through the hole in the plate. Replace the plastic plate and recommence sewing. Good luck
Sue
Sep 24, 2014 | Janome Sewing Machines
Thread keeps wadding around the metal post at the back and above of the bobbin case
Sounds like there is fuzz trapped somewhere around the bobbin or race. That often happens when you clean a machine. You may need to take the face plate off and gently remove thread or fabric that might be hung inside. Look carefully in and around the bobbin and race and gently remove any debris you find.Count to 10 and grin.
Jul 05, 2014 | White Sewing 1740 Mechanical Sewing...
MY BOBBIN CASE FELL OUT TWO PIECES HOW DO I PUT IT BACK TOGETHER
I assume you actually mean the metal ring that holds the small round case that the bobbin itself sits in. There are usually two arms that swing in to hold that larger metal ring in place and then there is a plastic and metal piece that sit behind the large metal ring. fit the plastic piece that may look somewhat like a scoop next to the metal piece that usually has the post the the bobbin fits onto and has a quite sharp tooth on it. The metal ring then goes on to hold those two pieces in place and the two arms swing in to hold the metal ring into place. The bobbin or bobbin case now can be put back in. Hint on metal ring placement: they almost always have a notch that goes at the very top where the arm on the bobbin case sits in when it is in place. You may find it easiest to do this with the machine laying on its back so you don't have to have 4 hands to hold everything in place while putting everything back in.
Feb 22, 2011 | New Home HF-2022
Feels like it seized up. Turns hard
You could have some cotton wrapped around your take-up arm. If you remove the cotton it should go again.
It could be needing oil on the upper shaft bush close to your flywheel. Maybey a drop of oil behind your bobbin case.
Does that model have a plastic or metal Bobbin case?
Jun 23, 2009 | Elna Quilter's Dream 6003Q
Installing the hook and bobbin assembly.
The plastic bobbin case should sit on top of the raceway, it should slot in quite easily, once the bobbin case is in put the small metal clip at the top over to hold it in place.
May 27, 2009 | Singer Sewing Machines
Plastic casing around the bobbin
That piece is a sweep that helps keep the hook clean. It is not necessary for the machine to use, I have thrown away many of them. If you can get your hook put back in you should be ready to go.
good luck!
Jan 30, 2009 | Necchi 3101 Mechanical Sewing Machine
The red plastic is a device to assist clearing lint build up and is not critical for the operation of the shuttle (esp if you perform normal housekeeping and clean this area regularly, as you should)
Check there is no damage to the surface of the red plastic, as this will cause problems if not smooth (jamming)
It fits between the fixed half moon metal shuttle and the outer body.
There is a small notch which locates it into position.
Tilt the machine back 30 - 45 degrees to make the insertion easier, then fit the hook then the collar....flick the retaining clips to secure.
I always find this easiest with the machine tilted back......reduces the chances of bits falling out while you put the next piece in.
This is for front loading bobbin..........
The Shuttle hook will look very much like this, and marries this to the "half moon" of the fixed shuttle.
The retaining collar ring that holds it all together has a plate like protrusion (like bull horns), this faces to the top and to the back.......there should be a small lug (or two) with corresponding small hole or slot on the fixed housing (hook race) that locates the ring tightly in the correct position.
There should be 2 swivel arms (black plastic at 4 o'clock & 8 o'clock)) that move to hold the whole thing together by clipping onto a small lug on each side of the ring.
If you tip the machine on its back while you do all this, it makes the process easier, as things are less likely to fall out.........support the back with a soft object for convenience (tissue box, pillow etc)
The bobbin case goes in after the housing is assembled, if you try to do it first, it will prove more difficult.
If this is not quite accurate for your model a photo of the bits would be helpful
The finished assembly looks like this: 3fe6ddb.jpg
Mar 08, 2008 | Sewing Machines
Singer 9410 Bobbin
I had the same problem and after looking on here and finding no answer I went back to my machine and found out what the problem was...ok, where the bobbin case sets in,the metal plate beside it needs to be fitted right close to the bobbin case, so loosen the screws(just two of them) that are in the plate(DO NOT REMOVE JUST LOOSEN) and slide the metal plate over some just enough to fit snug...NOT TOO TIGHT... if its seems to sew too tight loosen it a bit It worked for me, GOOD LUCK
Nov 11, 2007 | Yamata FY700 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
218 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
