Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Drum light stays on and wont let me start it again. Its dead but has light.. I have to power down the entire house to get it to start again
When my LG WM2482HWM finishes the wash the drum light will stay on and then when I try to use the control board the machine wont turn on.. It also happened another time when the machine was off and no lights , it wouldnt turn on.. I have to go to my circuit breakerand power down the house to kick start the washing machine
I had the same problem. LG addressed the problems as follows:
1. Unplug the unit 2. Press and hold the power button for 10 seconds. 3. Plug the unit back in.
It WORKS!! It's like reseting your computer or alarm clock. You've got to kill the power and press and hold the on button while it's still unplugged.
Hope this works for you.
Posted on Nov 21, 2009
  • 3 Answers
This solution worked however not fully. The same problem would occur after I turned the machine off or I ran a load and the machine powered down. It did correct itself however after I unplugged, hit power for 10 seconds, plugged back in, hit the power button, then walked away. When I returned, the lamp was off and I was able to turn on/off the washer on command. Hope this works for you as well.
Posted on Jan 02, 2011
Thanks for the info, I have the same problem with the drum light. I will try that and see if it works. That is a lot more helpful than someone I found that just said "buy a new washer".
Posted on Jul 15, 2010
What is the issue with LG washer
LG WM2277HSW XL Front Load... Repair Questions - Fixya
www.fixya.com/.../p95436-lg_wm2277hsw_xl_front_load_stackable
Recent LG WM2277HSW XL Front Load Stackable Washing Machine questions, problems & answers. ... My frontloader washmachine will not turn on · LG ...
LG WM2277HSW XL Front Load Stackable Washing ... - Fixya
www.fixya.com/search/p95436-lg_wm2277hsw_xl_front_load.../open
LG WM2277HSW XL Front Load Stackable Washing Machine, open related issues. Get free ... Wait 5 secs after turning off door release should open. If this does not ... OE error message won't open door, won't spin out water What is filters & open it are my problemsDue to that I cann't ... Where is it sticking and how do I fix it?
LG Tromm WD 12270 RD washer and dryer 'LG ...
Dec 19, 2015 | LG WM2277HSW XL Front Load Stackable...
WM3885hcca. Why does the drum light stay on?
Door switch or control boards bad .
Poss. stuck button on interface control
LG OEM Part #EBR64144901 main board
Pcb assembly, display
OEM Part - Manufacturer #EBR64736201
Jul 22, 2015 | LG Washing Machines
Rinses light flashing fast and wont drain drum and finish wash
Try checking the filter for a blockage or pump being jammed with a button , disconnect drain hose at sink hold a few feet off ground over a bucket should pump/ flow quite freely if not then check filter and pump. good luck
Oct 13, 2014 | Miele Novotronic Premier 500 Front Load...
How do I fix an error code LE on an LG washing machine
We have experienced the LE light for the past several months on our LG Tromm 2277. We replaced the Hall Sensor and it worked for about 4-5 washings. We unplugged and turned the drum 4-5 times in each direction. Replugged and it would work for 4-5 times. When that stopped working, we ordered the Stator Assembly. Same thing. It would wash 4-5 times and the LE light would return. Finally, the washer tripped the breaker and there was no power anywhere. My husband traced power up to the Main Control Board. He noticed the red light on the board was no longer on. The Main Board costs about $150. It arrived (ordered from Sears Parts Dept) and he replaced it in about 10 min. Take a picture of it before you remove so that you will have a guide to re hook. Three days and six washings later, it is still working. If I can get another 3-5 years out of this washer, I'll be happy. I have mastered the musty smell. I use a cleaning tablet "Affresh" designed for cleaning the drum periodically and keep the gasket as dry as possible after final wash using a towel and leave the door open. I love the low water consumption and low detergent use. If you use more than 2 Tablespoons of detergent, you are using too much. I also use a 1/2 teaspoon. of oxy clean when washing whites and towels. Here are two sites for installation reference:
http://www.youtube.com/watch?v=J11Thy0vW0Y
How to Fix an LG Front load washer machine that wont spin Post Comment On Buck Up Chinny
Good Luck! Kathy in Georgia
Sep 09, 2014 | LG WM-2277HW Front Load Washer
I have a LG Tromm with an LE error code. I just replaced the hall sensor
With a digital volt meter you need to measure the ohms value of the hall sensor. It has 4 wires. White red blue and gray. With the meter set at 20k ohms check hall sensor at the control panel. From white to blue you should read 9.5 K ohms. Same with white to red. If u get 9.5k ohms on both readings u have a bad main board. However to me I think your pump is bad. LG washers will not spin if they don't drain.
Apr 03, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg front wont finish wash resets to spin cycle
Sounds like the programme software control logic circuits are playing up. This is a job for a qualified Technician only. The control board may need replacing.
Pay for a service call and just get a quote to fix it.
If it's within your budget, fix it oherwise replace with another machine of your choice of brand and features.
Poppa
http://www.cdbaby.com/cd/poppamadison
Apr 06, 2013 | LG WM2277H Front Load Washer
Lg washing machine drum light stays on and wont let me turn the
Solution. Unplug the machine. Hold the power button for 10 seconds. Plug back in. Push the power button and the washer should turn on. Walk away leaving the machine on. When I did this, I came back to find the drum light off and machine would start on command now. Good luck.
May 15, 2009 | LG Washing Machines
LG WM2487H*M Drum light stays lit after each load is completed
Feb 12, 2009 | LG WM2487HA Washer
Hotpoint WD440
Bad door latch or Control board is bad
Apr 28, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
4,971 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
