Hoover VHC391 T-80 Dryer Logo
c
clare Posted on Dec 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can u help me
Its not getin hot and comein up with code e08 and all lights r flashing
ernesto cuadra
Level 3:
Top Expert:
  • Hoover Master 12,223 Answers
  • Posted on Dec 18, 2013
ernesto cuadra
Hoover Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4081226
Points
34431
Follow this steps and fix it, use the multimeter . Merry Christmas
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
tip
Xbox 360 RROD E08 / error code 0020
x 360 RROD E08 / error code 0020x 360 RROD E08 / error code 0020x 360 RROD E08 / error code 0020
My hoover dynamic 8+ washing machine Model number DYN8144D-80D displays an E08 error Code
E08 is the motor speed sensor error code. Suggestion: Try a cycle with very few garments and see if it completes the cycle.
Error code E08 hoover tumble dryer
Error code E08 means overloading (too many clothes in the drum). Don't worry, just reduce the load size by removing some of the garments in the drum.
E08 on my dryer
Search online for "error code E08 + your make & model"
Dyson fan/heater stopped working-E08
take it in to guarantee vacuum and sewing center for they will fix it
Mar 20, 2014 • Vacuums
14helpful
2answers
Error code E08 on candy washing machine
Hi.
E08 means that the motor has failed (tachiometer error). Shut down your machine and disconnect power cord for five or ten minutes. If that is not enough to clear the code call the support number listed in your owner manual.
Regards.
Ginko
18helpful
2answers
ELECTROLUX DRYER T4190, error code E08 flashing on panel. have tried turning power on and off, but still flashing. problem?
How to solve this problem
4helpful
2answers
Hoover error E08
hi I had this fault, google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on youtube http://www.youtube.com/watch?v=xYn-f78GB4U and it shows you how to test the tacho and how to change the brushes, hope this helps someone
Top Hoover Dryers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
