Question about HP PSC 1315 All-In-One InkJet Printer
Scanner, scans and then re-scans.
I use an hp scanner/all in one jobbie. i also have one at home (slightly diff model name [1310 vs 1315)/ totally different driver. dunno why)
Anyway, at home when i scan something, i get a preview window. if i like what i see, it's all done: save to computer, on to next job.
At school, the hp photosmart studio app opens when i push the button on the scanner. then, laborious preview. if i like what i see, i 'accept' and then have to wait until the scanner really laboriously re-scans the doc and saves to somewhere on the computer.
Why can't i just scan/save once? why do i have to preview then accept, then accept again?
    Problem Solver:
  • 6 Answers
Re: Scanner, scans and then re-scans.
You can go direct open my computer then you will find in the my computer window icon for HP officejet 4300 if you press it you can go ahead with wizard that let you scan your photo or document fast you can even send short cut to this icon at the desktop so you can reach it faster
 OR   ~~~~~~  another solution
when you open the hp software press the scan botton then will open another window has two option choos scan and then choos scan again in the other window
Please rate me if this solution was ok thank you
Posted on Oct 24, 2007
0 characters
3 Points
No problem iwant install hp psc 1315 all-in-one printer-scanner-copier
Hi There,
Please follow the below link to install the HP PSC 1315 All-in-One Print/Scan/Copier on to your computer.
Please download the user Guide which reads " HP PSC 1310 series all-in-one - (English) User Guide "on the page.
Enjoy your installation and enjoy printing......
Please vote for me if you think your issue is resolved....
Oct 28, 2010 | HP PSC 1315 All-in-One Printer
The printer 1310, won't scan after installation
First the printer is hp psc 1315 not 1310, my mistake.
I think the problem arose because of the order in which I was installing the cartridge. Instead of waiting for the printer to print out the test sheet, I was placing a test sheet, of which I have a number of copies, in the printer immediately after installing the colour cartridge and then pressing 'scan'. Nothing seemed to happen. I then tried waiting for the printer to produce a test sheet. This took a surprisingly long time. However after placing the test sheet which the printer had just produced in the printer and then pressing 'scan', the scanning operation was completed successfully. Problem was probably caused by my not reading instructions carefully. Roland Bishop
Dec 31, 2009 | HP PSC 1315 All-in-One Printer...
How do I get the scanner in my HP Psc 1315 to work
You can scan with out any HP software also using the below steps.
Make sure that the printer is connected to the computer perform the following steps;
Steps for scanning in Windows XP: 1. Click the Start (Windows) icon.
2. Click All Programs.
3. Click Accessories.
4. Click Paint.
5. Click File and then click From Scanner or Camera.
6. Click Scan.
Steps for scanning in Windows vista:
1.Click the Start (Windows) icon.
3. Click Windows Photo Gallery.
4. Click File and then click Import From Scanner or Camera.
5. Click Import.
6. Click Scan.
Sep 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
Lost software disk to install hp psc 1310 printer model hp 1315
Hi saljcartagen, yes you can download the HP PCS 1310 printer drivers for free. There are two way to get these drivers. Left click on the HP link below:
Connect the printer to your PC/notebook & make sure the printer is turned on. From the link above. Step 1, click once in the empty circle to the left of " Download drivers and software (and firmware) ". In step 2, type in " HP PCS 1310 all-in-one ", than click the, Start Detection button. HP will scan your system & find your printer. Allow HP to run the scan. HP will than start downloading & installing the proper software for your printer.
Another way to download the software for the HP 1310 all-in one printer would be to left click on this next HP link:â»
Click on your operating system from the list provided by HP.
You can choose to Run the software or you can save the software so you can make a driver CD later. Create a folder on your desktop & name it HP PCS 1310. Download the driver software into that folder. The driver software is a *.exe file. You can right click on the *.exe file & from the pop-up list choose to uncompress here. All the driver files will uncompress within the HP PCS 1310 folder.
Or you can just run the *.exe file. Either way the HP PCS 1310 driver software will install its self.
Thats it, good luck saljcartagen!
If you find this to be helpful, please vote.
Mar 08, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 and Vista, to scan a text, not a picture
Just to try....
The Scanner software should have an option to choose image or text, image and text etc.. Look for that first.
Do a scan but before you do and run through the process as you normally would.
Put the printer/scanner CD in the carriage cancel auto-start. My HP different type but... does not always see/grab ALL of the scanner files on an install. Sometimes however, it will go looking for the files it needs and grab them off of the CD when it actually NEEDS them. When you try to actually to the scan. Otherwise the printer probably works perfectly right.
If you want to check it out just for the sake of it. Look in Windows explorer - control panel and see if there is actually a scanner listed or just a printer? Good luck!
Feb 20, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315, scanner and Mac os
To scan documents on Mac OS X using your HP PSC 1315, you need to download HP's "Device Manager" software which is available here :
I just installed the software and am now scanning problem-free.
Oct 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Need to reinstall hp psc 1310 series all-in=one printer/scanner/copier
try going to the HP website
sometimes they have more than one driver, so if one is not working you can try a different version.
Jul 30, 2008 | Printers & Copiers
Scanner hp 1315
Hi -
I don't have a Mac, so not entirely exact on your solution. But, I do have a suggestion to try -
if you use a scanner, you probably have a photo editing software of some kind (like Photo Shop, Paint Shop Pro, etc etc). Within that program, there is an option to obtain the image from a scanner. You should be able to use that function instead. I know that with my WinXP, I could import from the scanner in Paint Shop Pro MUCH easier than trying to use the actual HP buttons on the 1315.
Please note that the 1315 will also only scan flat items well. If it is 3D, like jewelry or oddly shaped objects, you'll only get fuzzy-edged pictures. The 1315 has no depth perception, no matter what setting combination you use. Not HP's finest moment, for sure. I had this printer for a month or two before I was fed up, and went back to a separate printer and scanner! : /
May 16, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
66 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
