Question about LG 42PX5D 42 in. Plasma HDTV
Vscan voltages on LG Plasma
I have seen a post on your website that suggests changing the voltage by 10v on the power supply to cure sparkles. Do you know if this actually works?
  • Anonymous Feb 21, 2009
    where is the vscan pot on LG plasma tv
    42PC3D
  • greg420blues May 11, 2010
    Any idea how hard it will be to get a hold of the firmware update? My local repair guy said that sometimes LG won't provide that. Any suggestions .. AND ... any idea how much the average cost to have this procedure done is?
Are your sparkles mainly red pixels flashing randomly over the TV screen, especially over darker areas? If so your sparkles are I believe a discharge problem, and can be fixed with a firmware upgrade, which I think resets and corrects the voltage and removes the sparkles, which is caused by misfiring of the gases produced with plasma TV's. I have had my TV repaired with a firmware upgrade, which takes only 10-15 minutes and is reasonably cheap repair, and now the TV looks great, no more sparkles. Don't play around with the voltages let the pros fix it, also beware! leave this too long and it can become permanent, and need a new screen which is half the price of the a new TV.
Posted on Nov 05, 2007
I´ve just fix my 50" inch LG plasma by turning the VSCAN voltage thats at the back of the tv. I did go several times with my vendor and he only said the red dots were dead pixels and the guarantie didnt cover that. So I went to the magic of google and found out that it was as you all said "a voltage problem" and it could be solve by turning the VSCAN switch. I did took a lot of care, cause if you touch anything that you are not supposed to you can frie your tv. I am now whatching it and so far so good.. I guess better than when it was new.
I'll give you the link i used for it.
http://jopezu.com/plasma.htm
Posted on May 22, 2011
  • 105 Answers
Yes it actually works but i wouldnt do it unless your a trained professional. this really shouldnt be done without an oscilliscope.
Posted on Oct 16, 2007
42" plasma worked fine this
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Sep 15, 2011 | LG 42PC3D 42 in. Plasma Television
Pop heard lost picture still have audio
Hi
Hope this help in solving the problem....
May 07, 2011 | LG 42PC3D 42 in. Plasma Television
Plasma Television won't turn on
Hi
if otherwise the power supply board is faulty you can try websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this helps
Jul 02, 2010 | LG 42PQ30 42 in. Plasma TV
LG PLASMA TV MADE A LOUD POP NOISE NOW PICTURE IS SNOWY
A common problem for these is bad capacitors in the power supply, Remove the back from your TV and look at the power supply on the left hand side.
Hope this helps
Jun 16, 2010 | LG 42PC3DC 42 in. Plasma HDTV
LG 60PC1D making clicking sounds
Hi
Hope this helps
Please rate my reply ++++
Apr 05, 2010 | LG 60PC1D 60 in. Plasma Television
Error diffusion on Samsung 50" PLASMA TV
Yes the diffusion problem on your tv is due to the pdp panel aging. What you can try is readjusting the VSCAN voltage, there is a test point marked VSCAN using a DVM you can first check the voltage, should be around -- 190 turn the adjustment counter clockwise this should reduce the voltage, watcthing the picture turn control untill the sparkling pixels stop. That should do it. The panel is starting to age this may occur again until you can't adjust it out meaning a bad panel.
Dec 08, 2008 | Samsung HP-S4253 Television
Plasma tv
ned to adjust the VS-voltage or the VSCAN-voltage
Jul 17, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
Coloured sparkles appear in dark areas of picture
Sometimes just adjusting the VSCAN voltage inthe set will cure it. Other times it will be a faulty panel. Either case requires a technician to do the repairs.
Jun 10, 2008 | LG 42PX5D 42 in. Plasma HDTV
Lg plasma problems
Try to reduce the Vs voltage about 5-10V below its spec value. Vs is from the Power Supply board. The spec value of Vs was printed on the back of PDP panel. (You need to open the back cover)
Jan 24, 2008 | LG 42PX4DR 42 in. Plasma TV
V scan voltage
Try to adjust the V scan voltage down about 5-10V. If still not working, also try to adjust the Vs voltage down about 5-10V.
Dec 02, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
LG 42PX5D 42 in. Plasma HDTV Logo
2,069 people viewed this question
