Question about Euro-Pro EP923 Canister Steam Vacuum
I lost my attachments
I move about 2 times since I got my steam cleaner, and I lost most of my attachments, do enyone know where can I buy them??? if you are intersted on selling your attachments please contactme cynthia_go@comcast.net
  • cynthia_go May 15, 2009
    well I try that before with no luck, they don't have that model!!!! they should but they don't, and I need the attachments, that is why I need someone that had the steam cleaner that is no longer using or is not working, to sell me the attachments if possible!!!! if you know somebody please let me know!!!!
    President:
  • 2,559 Answers
Go here and order what you need or copy and paste this address into the search bar www.sharkvac.com/home.aspx
Posted on May 15, 2009
No steam comming out of my h2o x5 cleaner
see the causes and proceed with common sense. and fix it. God bless you
If the spray function has quit working on the carpet cleaner, check to make sure there is a full tank of water. If the water level is adequate, check the position of the gasket on the bottom of the water tank assembly. The gasket can become lodged, damaged, or removed. If this has happened, fix the gasket to the proper position according to the user manual, or replace the damaged or missing gasket.
  • 2 Change the belt on a steam cleaner that has inoperable brushes. From time to time, belts on carpet steam cleaners become worn, and you must replace them. If the brushes on your unit have stop moving or do not turn on, you may have a damaged belt.
    Replace a belt at home easily with little expense. Refer to your user's manual for replacement instructions and the part number for purchasing the belt. Remove and replace the belt according to the model of steam cleaner you own. Purchase a new belt at home improvement stores or directly
  • Sep 22, 2012 | H2o TR220002 Steam Cleaner
    Lost manual. How do i hook up the suction part of the furniture upholstery attachment? I know where to plug it in to spray cleaner on the furniture but where does it plug in to **** it up? Model...
    on the attachment where you put the attachment remove the lid, then remove the back panal, and slide the suction thing down not much pressure, re apply the lid then put back in vacuum, turn on and there you go...
    Sep 02, 2011 | Hoover F5906-900 Upright Steam Vacuum
    How to hook up tool to clean upholstery
    Keep your upholstered furniture looking fresh by vacuuming it regularly with the upholstery tool attached to your vacuum's hose. Prevent the fabric from fading (or at least delay this) by keeping your furniture out of direct sunlight -- close blinds, shades or curtains when the sun shines most directly through windows closest to the upholstery. And remove stains by blotting them with a dry cleaning solvent. Before steam cleaning your upholstered furniture, read the piece's cleaning code label to determine whether or not it is safe to do so. Then rent or buy a steam cleaner (also called an extractor) and follow the directions below.
    1. Rent a steam cleaner or purchase one; buy steam cleaner solution.
    2. Step 2 Vacuum the upholstery on the furniture you wish to steam clean; use the upholstery attachment to most effectively **** up loose debris.
    3. Step 3 Test the steam-cleaner solution on the upholstery in an inconspicuous place to ensure the color won't be steamed out or drastically altered.
    4. Step 4 Attempt to remove any stains with a stain removal or dry cleaning solution. Follow the directions that come with the product you choose for the best results, and allow the stain remover to dry before you begin steam cleaning.
    5. Step 5 Remove cushions and, if necessary, arm covers.
    6. Step 6 Gently apply the steaming water and cleaning solution in straight lines across the upholstery one section at a time.
    7. Step 7 Use the cleaning extension on the steam cleaner to **** up as much water as possible. The dirt will come out with the water.
    8. Step 8 Clean one side each cushion (then allow it to dry) before cleaning the other side. If the cushions are permanently attached to the furniture, clean them last.
    9. Step 9 Allow the furniture to dry completely before repeating the steam-cleaning process or replacing the cushions.
    Jun 19, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
    Where can I buy a Saeco 00095 Piccolo Steam Cleaner?
    Hi!You can buy from the following links---Product 4 Homes website--http://www.products4homes.com/eh2.php?cat=Household_Cleaning&subcat1=Vacuum_Cleaners_and_Upholstery_Cleaning&subcat2=Saeco_Steam_and_Vacuum_Cleaner&page=0ebay website--http://www.products4homes.com/eh2.php?cat=Household_Cleaning&subcat1=Vacuum_Cleaners_and_Upholstery_Cleaning&subcat2=Saeco_Steam_and_Vacuum_Cleaner&page=0Please do rate the solution as FixYa and using FixYa as well.ThanksRylee
    Jun 11, 2009 | Saeco 00095 Piccolo Canister Steam Vacuum
    Help with steam cleaner
    DId you push the little button located at the rear of the attachment on the top? It is gray and part of the hose peice. It is what holds it the attachment to the tube
    Jan 31, 2009 | Bissell 1699 ProHeat Clear View Upright...
    Bare floor attachment for Hoover steam vac with surge clean
    According to www.vacuumpartstore.com, for model #'s F5903, 5904, 5905, 5906, 5910, 5912, 5914, and 5915, you need Hoover SteamVac Bare Floor Cleaning Attachment (old # 48417003). You can get it at www.amazon.com for $7.99.
    Oct 28, 2008 | Hoover F5906-900 Upright Steam Vacuum
    Need manual for Hoover steam vac. F5910-900
    For an appliance or any kind of electronic,
    I would try http://userguides.50webs.com/
    Aug 20, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
    Euro-Pro EP923 Canister Steam Vacuum Logo
    233 people viewed this question
    Top Euro-Pro Vacuums Experts
    Dennis Key
    Dennis Key
    Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
