Question about SanDisk 2GB microSD Memory Card
Removal of miniSD memory card from Alias Samsung phone using fing
How do I remove microSD from Alias Samsung phone to insert it into mini reader to transfer photos to my pc? Do I grasp with my fingernails? Is there a "rejedt" command?
  • 51 Answers
Generally it should easily be pulled out with your finger nails....but dont try too hard as it may spoil the slot..
Posted on May 15, 2009
Unlock software
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the microSD/miniSD adapter. The SD adapters will also have a lock switch.
Sep 12, 2013 | SanDisk 2GB microSD Memory Card
I can't format my new micro sd card
The Samsung Alias works with microSD cards. Your 8GB card is actually a microSDHC card and will not work in devices not designed to work with them. You need to use a microSD card, 2GB or smaller.
Jan 19, 2013 | Samsung SCH-u740 Cellular Phone
Where do I insert my microSD memory card or does my computer have a slot for it?
Here are the ways for you to insert your microSD to your computer
1. Use "memory card reader" (this is probably the best way)
find the slot that says "micro sd" that's where youre going to insert the microSD
2. Use the internal memory card reader of your pc ( if your computer has it)
it is located in front of your desktop. The find the slot that says "micro sd" and insert it.
Sep 13, 2011 | SanDisk 2GB microSD Memory Card
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
Jun 18, 2011 | Samsung Star GT-S5233 Cell Phone
I have ordered a Dynex 6 in 1 . It has only two slots for memory card to go into. where are the other 4?
Check out the "quick setup guide" here: http://www.dynexproducts.com/products/computers/DX-CRMN1.html
You'll see that those 2 slots are capable of reading Secure Digital, SDHC, miniSD, MultiMediaCard, Reduced Size-MultiMediaCard and microSD formats.
Hope this helps! If it did, feel free to rate me. Thanks for using FixYa.
Mar 16, 2011 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
Was inserting a camera memory card into Right slot but it appears to have been swallowed by the PC and not connecting as it should
Most likely you inserted a MicroSD or similar memory card into your card reader. The problem is that the card reader was designed for MiniSD or MMC (for example) memory cards, which are bigger. In order to read a MicroSD card you will first need to put it in an adapter from MicroSD to MiniSD. In order to remove it from the slot, power down your machine and shake it a couple of times with the slot facing down. If it doesn't get out, try to manually remove it using something similar to a blade.
Mar 01, 2010 | E-Machines Computers & Internet
Why wont my sidekick format my memory card? I have a MicroSD in a MiniSD adapter. I've also tried a second MicroSD that I happened to have laying around...Do I have to have a MiniSD by itself or do I have...
Hello , Welcome
# Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Aug 07, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Removal of microSD from Alias Samsung phone to transfer to pc - u
Tow locations where it would be on the side under a plastic flap that says SD card or something tothat effect or under the battery in ehter case it slides out.. then u put it into the big adaptor and put it into your reader or simply hook you phone up to your computer and transfer away make sure you download the drivers for the phone..
May 15, 2009 | SanDisk 2GB microSD Memory Card
Cannot format memory card
The Samsung Alias can only use up to 2gb microSD cards. I had this same problem after purchasing a 12 gb card only to discover that I could not use it with this phone. Hopefully this will be fixed when they make the Alias 2.
Apr 13, 2009 | Verizon Communications Samsung Alias Cell...
SanDisk 2GB microSD Memory Card Logo
75 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
