Question about Dell UltraSharp 2001FP 20.1" LCD Monitor
How to disassemble monitor Dell 1800fp ?
Remove the base by the button release or 4 screws on the back. On the bottom of the monitor near the corners you will find two thin slots where you can insert a thin wide blade screwdriver or pry tool. Very gently pry the back from the bezel toward the center from both of these slots until the bottom is seperated, then contilue from the slots around the corners and up the sides until you have seperated the entire back from the bezel. Lay the monitor on the bezel and remove the back ( do not try to remove the bezel, at least not yet). Lift the tape that secures the ribbon cable from the bezel buttons to the logic board. Unplug the ribbon cable from the logic board by pulling on the connector (not the cable). Remove the cable covers from the back of the case (one has a screw, the other has a lift tab) and disconnect the lamp connectors and ribbon cable connectors (do not pull on the wires). remove four screws and lift the metal back from the screen.
Posted on Jul 15, 2009
    Scholar:
  • 47 Answers
Remove the base - either button release, or 4 screws. If there are any other screws in the monitor case, remove them. Depending on how old this model is, Dell monitors usually need to be pried apart, the front coming off and separating from the back. If this is the model with the vents on the top and bottom, this is a good place to start (separate the front from the back by prying it gently all the way around) If it's a newer model, similar to a 1905FP, the front bezel needs to be pried away from the back. The front bezel piece is only about 1/4" think, and you may be able to start opening it with a very thin but wide flat screwdriver.
Posted on Jun 05, 2009
Does ultrasharp's 1800fp monitors have built-in speakers?
No built in speakers. There is a sound bar that you can get the attaches to the bottom of the screen to add speaers to the unit but it is sold separately.
Sep 26, 2012 | Dell UltraSharp 1800FP 18.1" LCD Flat...
My dell monitor model #1800fp diplay is elongated for all pictures I display on the screen. How do I correct this
should be on the menu on front of monitor ,,with options to change that,,and check control panel on cpu,,make sure its set rght,,for widescreen or regular
Nov 03, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Green tint
Sounds like the monitor cable has a short or loose connection at computer or monitor side.
May 24, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell 1800FP
change the power cable then check, if the problem persists take it to the service technician the fault may be in the power supply
Jun 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell Ultrasharp 1800FP Power Saving Mode
go to control panel>power option>power scheme.
adjust the hard drive to 30 mins and everthing else 20 minutes.
also, go to display and adjust the screen saver to be longer. up to 9999min.
Jun 30, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell 1800FP has slight yellow cast
Your Display cable (inside your monitor) needs to be replaced. (Or reseated)
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
Mar 04, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell 1800FP
What's wrong with your monitor?
Feb 10, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 2001FP 20.1" LCD Monitor Logo
3,172 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
