Home | Copiers | Sharp AL1631 Copier Int...
Copiers
Problem for Copiers
Generic problem for all Copiers
Sharp AL1631 Copier Intermittent Problem
By veegee on Oct 15, 2007
I have an intermittent problem with my copier. Sometimes when I turn it on the Ready Light above the Copy Button keeps blinking and there is a very faint clicking sound. The copier does not respond to the Copy Button. There is no error code in the display. It just sits there in this mode until I turn it off. Sometimes when I turn it on it works like it is supposed to.
I have recently replaced the toner cartridge but it did this before replacement too.
Same Problem
Mar 04, 2008
-   The machine has a loud clicking sound, different from the toner clicking sound, it sounds like a gear might be slipping, then the paper gets jammed in the drum area. We have replaced the toner cartridge.-   conped
Best Solution
posted on Oct 17, 2007
Very Helpful)
gradracer16
Rank: Master
Rating: 90%, 17 votes
There are several reasons this could be happening.
1. If you are not using Sharp Genuine products
2. The toner cartridge might not be fully seated
3. Voltage for the specified plug may be incorrect voltage or overloaded.
The faint clicking sound is most likely the machine stirring toner. I have seen where a sensor that detects toner level inside the developer unit get covered in a sludge, but if you just replaced the TD unit it should be okay.
Was this helpful?
Yes
No
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
conica minolta bizhub 35o vs kyocera in same price range
Answer
Why does the Sharp MX 4501N go into a "clear data" mode for over an hour? No printing or... (More)
Answer
I am trying to set up the printer remotely and would like to do it via web browser . Can I set up... (More)
Answer
folder error #17 how can i fix it?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Copiers:
Top Copier Experts
Rank: Guru Guru
Solutions: 721
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
