Question about Dell Wireless Keyboard Optical Mouse w0147
Mouse problem everytime i use the mouse the arrow just stops. you then have to click the button on the right and after a window comes up click it again, then it will move again for a few seconds. really really frustrating.,,ugh...
    Problem Solver:
  • 30 Answers
Re: mouse problem
You mouse may need to have the batteries changed. Try changing that batteries, if this does not work, post again and I will help you further. Have a good day!
Posted on May 01, 2008
0 characters
3 Points
M705 wireless mouse. Why doesn't right click work as it should?
this may be a misconfiguration, in windows control panel, open mouse config windows and there you can see what actions are binded to each mouse buttons. If all is ok there than you may have some malware bugging normal mouse function.
Sep 19, 2015 | Logitech Keyboards & Mice
After restarting my computer the cursor stopped responding to the mouse.
You're probably running Windows, and that's a common problem, and usually very easy to fix. If you are using a wireless mouse, remove the USB receiver, wait 10 - 20 seconds and put it back in. If that doesn't work, remove USB rec. , shut off mouse and go through a restart. Try restarting with them removed, if it doesn't work, try restart with them in and turned on. You can use keyboard commands to do this next part If that doesn't work, go into the Control Panel, system, device manager, mouse, right click ( lined square to right of space bar ) then properties, reset to default - The windows symbol beside space bar is the start menu, the arrows control scrolling through options or moving the page, TAB changes what the computer is focused on, ALT and F4 closes whatever program you're focused on - pressing it twice will cause a restart. And if your comp ever jams up, press CTRL, ALT and DELETE at the same time, opens task manager and unjams,,, usually. Hope some of that helped. Grimm
May 01, 2015 | Keyboards & Mice
What do the buttons on the side do?
the buttons on the side of a 5 button mouse are forward and back when looking at web pages. that's what mine does. try looking at a web page and click on a link as normal, make sure it doesn't open in a new window. when the new page opens the back arrow in your browser bar, normally top left or right, should be highlighted. if the back arrow is highlighted try clicking one of the side buttons and see what happens. one should take you back to the previous page, and the other will bring you back.
Dec 13, 2013 | Avenues In Leather, Inc Wenger The Diablo...
Arrow does not move on screen with remote mouse
you might have to uninstall the mouse and its drivers then restart your computer then reinstall the mouse and its drivers
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have the options update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
hope this helps
Feb 20, 2011 | Logitech Cordless Mouse
On Saitek eclipse II illuminated keyboard: What is function of the 1 (above the f8), the A (aboveF9) and the down arrow between F10 and F11) Also the function of the dey on bottom row between the windows...
The 1, A and down arrow represent the usual Num Lock active, Caps Lock active and Scroll lock on option available on all keyboards out there.
The 'dey' key on the bottom between the Windows Key and the Ctrl acts as a right mouse button, as in opening the menu you would open with the right mouse click.
Hope it helps.
Dec 31, 2010 | Saitek Eclipse II Illuminated Keyboard
Unable to right click to delete item
The clicker on the mouse has a plastic mount, if that breaks it stops registering the clicks. The plastic doesn't glue well and the part is not worth replacing. It's maybe a $10 mouse.
You can however reverse the buttons using the mouse option in the control panel of Windows and use the left mouse button instead to get by. At least until you get around to buying a new one. The enter key also often works in lieu of a right click when opening programs and Windows.
May 07, 2010 | Logitech Cordless Mouse
Left click on mouse pad doesn't work!!!
i think u must have switched the primary and secondary buttons on ur mouse.i assume ur using windows.goto control panel-->mouse-->choose buttons tab-->u'll see a check box which sud read switch primary and secondary buttons.remove the check mark from here.sud solve ur issue...
Jun 22, 2009 | Dell 2 Button Mouse 6u226
Touchpad and cursor keys quit working
I used to get this problem. It is VERY annoying as you must know. try pushing the windows icon button in the top right corner of your keyboard(thats where it is on my keyboard)then use your arrow keys to scroll up to control panel, select mouse by using arrow keys and then use the tab and arrow keys to open the mouse keypad pagetab and push enable and enter key to turn it on.
IF WHEN YOU DO THAT AND your in the touchpad properties but there is no 'enable' and it says no hardware detected, then go into the same mouse window from the control panel and go to the hardware tab and either try to update driver or use the trouble shoot button.
Hope this helped =]
May 27, 2009 | Dell F3534 Touchpad
Want a left handed mouse
To change mouse settings in XP for left-handed users:
Click Start and click Control Panel.
Double click the Mouse applet.
Verify that the Buttons tab is selected.
Select the Switch primary and secondary buttons option is selected.
Click OK.
May 07, 2009 | HP Wireless Optical Mouse
Logitech mouse problem
I assume there is no second mouse on the system and you are using keyboard commands. Try the following in the device manager..
  1. Press Control-Esc or press the Windows key on your keyboard to bring up the Start menu.
  2. Using the up arrow key, highlight "Settings."
  3. Right arrow key to "Control Panel" and press the enter key.
  4. Use the arrow keys to highlight the System icon and press the Enter key.
  5. Use the right arrow key to select the Device Manager tab. (For Windows XP/2000 , use the right arrow key select the "Hardware" tab. Now use the tab key, select the "Device Manager" button and press the enter key.)
  6. Use the "Tab" key to select the "Computer Icon" at the top of the list of device icons.
  7. Use the down arrow key to highlight the Mouse icon.
  8. Use the right arrow key to open the mouse icon and verify there is a mouse icon that states, "HID-compliant mouse," and another entry that states the name of your USB device.
  9. If there are any errors reported on these icons by exclamation points or red X's, highlight these icons using the arrow keys and "Tab" to the "Remove" button and press the enter key. (For Windows XP/2000 , highlight these icons using the arrow keys and then press Alt-A keys. From the "Action" menu, highlight "Uninstall" and press the enter key.) When the "Confirm Device Removal" box appears, press the enter key.
  10. Once these icons have been removed, use the Tab key to get to the "Refresh" button and allow Windows to re-detect the pointing device. (If u r using Windows XP/2000 , press the Alt-A keys. From the "Action" menu, select "Scan for hardware changes" and press the Enter key.)
  11. Use the arrow keys to open the Mouse icon again and verify that there are no errors reported.
  12. Power down the computer system and restart Windows.
Apr 16, 2008 | Logitech diNovo LX300 Keyboard/Mouse
Dell Wireless Keyboard Optical Mouse w0147 Logo
Top Dell Keyboards & Mice Experts
 Mike M
Mike M
Are you a Dell Keyboard and Mice Expert? Answer questions, earn points and help others
