Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
Bill Green Posted on Dec 17, 2013
How much does a compresser for kenmore side by side cost/
gmonett
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Jan 16, 2014
gmonett
Contributor
Level 1:
New Friend:
Answers
18
Questions
Helped
3977
Points
18
Before you replace your compressor, make sure the condenser coils are clean. I thought our compressor was going out, but it turned out to be the coils needed cleaning.
1helpful
How do i replace my compressor on a kenmore 592.52679200 refridgerator?
You will not be able to do this as you need special equipment and refrigerant and to buy this equipment just to do the job will out way the cost of a new fridge
My kenmore refrig. isnt getting cold? the fan works i think the compresser sounds like its working . wont get cold
Try cleaning the coils usually located at the rear of the unit. If the coils are not clean the compressor will not be able to work properly.
Unit is running but compressor is short cycling and amping too high 15.5 amps full load is 6.5
I would try a new compresser overload relay. This is what starts the compresser and they have issues with them. Also some have a capatator that may need changed also. Some applance stores have what called 3n1. Which has all the things you need. I hope this helps.
1helpful
We also have a 10 year old Kenmore side-by side that has stopped cooling. The compressor continues to run (does not turn off after a few seconds). Worth repairing???
well to be honest its a "no, no" a 10 year old unit is not very good and is costly to run to fix it would cost half the price of a new one, and by now you must have had your money's worth out of it, so its best all round to buy a new one to fix your unit it would need a new compresser a re,gas and maybe a thermostat as well, ,,see what i saying,,,lots of money for an old unit
My kenmore side by side/ model 55771/ is having the same problem.
Is the fan running by the compressor and are your coils clean under refrig ? also make sure the cardboard panel is on the back of the refrig .
1helpful
Compression check
The compressions you mentioned...Good?
No. Not at all.
Those compression reading indicate either really bad/worn piston rings, or valves that are not sealing properly, or both.
Normal compression readings should be at or above 140 PSI, +/5 5 PSI difference, no more.Save your money, and look for another unit. This engine is going to cost you a lot of money to make it right.
Kenmore side by side md#253.4430303401
maybe compresser hi- limit on the compreser.
Kenmore freezer and fridge is not cold - not frost build up - compress anf fans are all running
You need a qualified technician for this problem.
- Your unit may have leaking try to check for oil traces.
- The system maybe restricted, system reprocess is needed for this unit.
- If the unit is no frost try to check if there is an air circulation inside the unit. If no air is present then check your fan motor inside.
3answers
Dishwasher installation problem
I have had this problem in the past as well. They state that you have all the parts you need to install the dishwasher, however that is assuming that it is under ideal conditions. You will need an adapter to attach to the fill line to make it match the size on the diswasher. They usually only cost about $3.00.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
