Question about Maytag Refrigerator Light Switch - C3680310
Frig stopped cooling. Bad condensor Fan Motor.
Frig stopped cooling. Bad condensor Fan Motor. Changed condensor fan motor. Restarted frig. Works great but has not stopped running for 8 hours. Condensor cool, Compressor hot, but not hot enough to shut down for overheating. How long will it have to run to cycle out? This is a Maytag side-by-side Refrigerator Model No. MSD2748DRW
  • 1 more comment
  • pep57chev May 15, 2009
    No, I have not ruled out a bad thermostat. What are the chances of two unrelated parts failing at the same time. I told my wife it has to be the thermostat but did not test for it. Hopfully that is the solution,
  • badenhop
    badenhop May 11, 2010
    One failure would have caused the other. If it's a bad thermostat making the pump run non-stop, that could cause things to break. That said, unless your refrigerated compartment is always freezing things, you may be low on coolant. You could also have a bad compressor.
    You may want to call the maytag man to get your unit serviced. If it's older, it may be most cost-effective in the long run to just replace the unit.
    Have you verified that the external radiator is clean? Does it have enough "breathing room"?
  • badenhop
    Have you ruled out a bad thermostat?
    Champion:
  • 225 Answers
Sounds like a bad thermostat,that tells unit when to kick on and off.
Posted on Jun 14, 2009
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
Samsung rs2630Ww. internal refrig fan blower not working and water dispenser not working.
This problem could be caused by the motherboard having defective relays, bad fan motor=> DA31-00103A Fan Motor Sounds like someone will need to examine the fan motor and test the voltage to the fans inside and outside the refrigerator. You will need to have this done to eliminate what the cause is. Both condensor and evaporator fan motors are the same part=> DA31-00103A Fan Motor Let me know and I will explain how to remove, test or replace the freezer/evaporator fan motor, wiring or motherboart. Thanks Sea Breeze
9_16_2012_3_30_31_pm.jpgDA31-00103A
Sep 14, 2012 | Samsung RS2630WW Side by Side Refrigerator
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
Hi we have a GBS22HCPABB fridge and the motor runs, frezzer works but fridge will not get cold just stopped
you have a few possibilities 1. a defrost problem restricting air flow from freezer to ref. 2. a bad freezer fan motor 3. a damper issue not opening to allow air to flow from freezer to frig. most all refrigerators generate the cooling from the freezer to the frig via the freezer fan motor
Mar 06, 2010 | Refrigerators
Fan underneath frig is running but no cold air is coming into the frig or freezer
The fan that is under the frig is the condensor fan(the fan the cools the condenser coils and the compressor. It does not have a direct effect on the chilled air circulation inside of the frig. The evaporator fan is the unit that circulates the chilled air thru your freezer and frig. I am not sure what make model unit you have, but I have found that this fan motor is 90% of the circulation problems i have seen.
Jul 31, 2009 | Refrigerators
Fridge is warm
Hi!!! you have 2 problems that are causing your frig not to cool.First one is a seal seal problem,make sure that the compressor is running and the inside fan motor and the condensor fan motor locaated behind the frig..if the are then you have a seal system problem ,most likely a freon like or restriction..Second you could have a defrost problem open the freezer door and look bank on the wall of the evaporator if you see frost or ice then you have a defrost problem..Just replace the defrost timer and you should be fine..remember to defrost frig when installing defrost timer.Good luck.
Jan 04, 2009 | Refrigerators
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
JCD2389GES SIDE BY SIDE
hi thanks for the question if you say that the fan is not working replace the fan thanks the appliance doc
Aug 23, 2008 | Jenn-Air JCD2389G Side by Side...
Maytag Refrigerator Light Switch - C3680310 Logo
247 people viewed this question
Top Maytag Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Maytag Electrical Supply Expert? Answer questions, earn points and help others
