Question about Panasonic DVD-RP56 DVD Player
Panasonic DVD player
My DVD player just stoped working it reads HO7 what does that mean?  Can it be fixed?
    Problem Solver:
  • 13 Answers
Re: Panasonic DVD player
The problem with your unit is the "Spindle Motor", this motor is the one that spins the disc so the laser can read it. I sugest you to take your player to a shop, or back for service if the unit still under manufacturer warranty.
Posted on Jun 23, 2008
0 characters
3 Points
Can anyone tell me how to step by step take apart Panasonic DVD-S25 to get to the motor to get the ho7 to popping up the dvd will play thru then stop spinning which wont read dics anymore
hi there it could b a fault in the cpu ..if it is its not worth fixing...have a look on e/bay u can buy them for $10 to $20 dollars working good luck.........
Sep 18, 2015 | Panasonic DVD & Blu-Ray Players
Panasonic DVD Player. Reads DVD then says HO7 and then STOP. PLAY DOES NOT PLAY
Common failure of the spindle motor/laser assembly. Also known as the traverse unit, which can cost more than a new player to replace. Not a consumer-repairable part.
Feb 26, 2011 | Panasonic DVD & Blu-Ray Players
Does not play DVD and displays HO7. We have tried
This normally means the spindle motor is faulty,there is a little coupler and this splits,this will cause the machine not to load.
Oct 07, 2009 | Panasonic DVD-RV32 DVD Player
This normally means the spindle motor is faulty.
Jul 21, 2009 | Panasonic DVD & Blu-Ray Players
HO7 displayed on machine and won't play dvd
email me your email address and i will show pic's how to my email address is plzzz email me i will help but for now i will help step for step.
1)open your driver and pull out the plug.
2)nou the driver is open pull of the cover infront of the dvd player.
3)nou screw open your dvd player and take of the cover.
4)screw of the driver take it out.
5)nou clip of the lazzer and take it out gently.
The top resen of the HO7 is problem is it movement is dry use selicone spray to spray it there will be a thing that makes it spin but for screen shots plzzzz email me.PLZZZ RATE ME FOR NOU BECOUSE THIS PROBLEM IS NO MORE IT IS SOLVE FOR SHORE..
May 05, 2009 | Panasonic DVD-S35 DVD Player
I have a Panasonic DVD player, model no: DVD-RV32, that is displaying the message "H07". What does this mean?
Here's the fix
I've replaced the motor once before on my 5 disk player to fix the HO7 error. The second time it appeared I tried the fix at the above link instead of going thru the hassel of the repair shop.
You may need to apply WD40 multiple times to cure the problem, depending on how stiff the rotation of the spindle feels. After the first application the player ran for about 5 minutes before the HO7 error reappeared. After the second application we watched an entire movie with no issues. we'll see how long this lasts. The fix was simple and hopefully wont have to be repeated soon.
Oct 21, 2008 | Panasonic DVD & Blu-Ray Players
Wont read disc-error message HO7
Please chande your dvd lense you can purchase it from the market please note the lense number and may be the mechanisum problem.
Jun 10, 2008 | Panasonic DVD-CP67 Multi-disc DVD Player
check out this link I think this information will help you.
Sep 17, 2006 | Panasonic DVD-CV47 Multi-disc DVD Player
Getting "HO7" when loading disc
After calling Panasonic, they suggested pressing the reverse skip (<<) button, the pause button and the open/close button all at the same time. The DVD player will then say "initialize." Turn off the player and unplug it for about 1-2 minutes. Plug it back in and turn on the player and load a disc. If the HO7 error code pops back up, you need to take it to a dealership for service. Or, at the price of DVD players these days, just get a new one - which is where I'm going right now.
Aug 21, 2006 | Panasonic DVD-RV27 DVD Player
Awwwww The old HO7 code!! This code means that the spindle motor did not come up to speed and the only way to fix it is to first find out if its the driver servo circuit thats bad or the spindle motor itself is defective. If you know how to trouble shoot a motor speed control servo sure you can fix it, But theres no easy wand waving fix for this unit. Sorry. If its an older unit you want to consider buying a new one as it may not pay to estimate the unit and have it fixed . The balls in your court now my friend. Good Luck
Jul 26, 2006 | Panasonic DVD-RV32 DVD Player
Panasonic DVD-RP56 DVD Player Logo
65 people viewed this question
Top Panasonic DVD & Blu-Ray Players Experts
Are you a Panasonic DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
