Question about LG 42LC2D 42 in. LCD HDTV
Removing the stand off the boton of the TV
How to remove the stand off the bottom of the an LG TV flatscreen
    Problem Solver:
  • 4 Answers
On the bottom of the foot there are some screws that u agve to take out
Posted on May 15, 2009
I would like to remove the pedestal or stand from a LG 42LG70 TV because I want to place the TV on a wall mount.
Usually the safe way to do this is look first at the owner manual but lay set face down on a padded surface so all weight is on the frame around the screen and no weight on the screen itself, exert no downward pressure in that position or screen may be damaged.
Usually pedestal is secured by 4 or more screws that may require the back cover of the set to be removed first, to get at---a careful look with it face down will show if part of the pedestal is under the rear cover of the set or not.
Dec 18, 2012 | LG 42LG70 42 in. LCD HDTV
I don't know how to remove the flatscreen tv from its orginal stand
You need to unscrew the back of the stand it should have 2 screws in 2 small holes
Nov 07, 2012 | Televison & Video
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
I am trying to remove the tv stand base off my 42lg30. Can someone please help!
DETACHMENT
Carefully place the TV screen side down on a
cushioned surface to protect the screen from
damage.
Loose the bolts from TV.
you can view a larger image by clicking on this link then selecting the Manual on the right hand side
the information you will need is on page 13 of the manual
http://www.lg.com/us/tv-audio-video/televisions/LG-lcd-tv-42LG30.jsp
Detach the stand from TV.
After removing the stand, install the included
protection cover over the hole for the stand.
Press the PROTECTION COVER into the TV
until you hear it click.
Dec 03, 2010 | LG 42LG30 42 in. LCD HDTV
HOW DO YOU REMOVE THE STAND ON A LG 32LH20 FLATSCREEN TV
4 BIG headed bolts or screws on back of tv
Nov 05, 2009 | Televison & Video
How to remove Stand and Neck from LG M227WD 22
First remove the stand. Then remove the bottom of the tv carefully by removing the screws. Then put your fingers between the bottom and the tv, and pull carefully. now you can remove the neck.32e1e02.jpg4c05683.jpg2acdd66.jpg
Aug 20, 2009 | Televison & Video
Removal of flat screen pedestal so I can wall mount tv
Had the same issue. I turn the unit upside down and while holding panel down just pulled staight up on the base. The circular base popped off without any damage. I just needed to remove for shipping.so I didn't have to remove the cylindrical post. Once the base is removed you can see a screw that probably attaches that cylinder to the unit. Carefully removing it should work. Good Luck....j
Nov 23, 2008 | Televison & Video
Can't remove stand
there should be a something that you need to push in at the back of the stand that connects to the tele. Someone needs to push it in hard while someone else tilts the tele forward and up or back and up depending on which way the push in part goes. (Presuming this is a flatscreen tv)
Oct 23, 2008 | iLO LCT32HA36 Television
How to remove stand
Just taken the stand off my LG 42LC2D. The stand is made of cast aluminum and has 2 long legs that insert into the base of the TV. So to remove the stand lay the TV on its screen and remove the two screws that are vertically in line next to the power socket the the 2 screws that are vertically in line under the RGB socket. The stand then pulls out from the bottom of the TV.
Dec 16, 2007 | LG 42LC2D 42 in. LCD HDTV
Removing bottom stand Flat Panel LCD Magnavox 32MF605W 32
There are 4 shiny screws at the back of TV just above the stand neck. Unscrew those 4 scrws and then lift the TV up, stand will come out.
Nov 06, 2007 | Televison & Video
LG 42LC2D 42 in. LCD HDTV Logo
1,349 people viewed this question
Computer Repairing
Computer Repairing
